(2020-12-11, 18:56)nazim12 Wrote: [ -> ]After reset .
I think first thing is to settle . Bingie skin helper should recognise " Resume progress " whatever played on Kodi local either movies or shows even we play direct or by searching links using addons . (right now it's working)
Secondly skin helper should also synced with trakt Movies and TV shows Progress on auto basis (which is lacking right now)
Thirdly tmdb addon can reflect Trakt Progress Movies and TV Shows BUT it doesn't recognize Kodi Local played items which should be synced with Trakt in Progress Items .
Continued Watching episodes Red Bar doesn't appearing on Clear Logo area.
https://i.postimg.cc/qR2cR98Z/image.png
All ( In progress Movies) showing 0% played , which is wrong .
https://i.postimg.cc/4xt8gdX9/image.png
every progress movie showing 0% played
Is that library content u have because the only time I get 0% is on non library widgets from addons
(2020-12-12, 02:18)mathu204 Wrote: [ -> ] (2020-12-11, 18:56)nazim12 Wrote: [ -> ]After reset .
Contents are local from library but using an addon for ( In progress movies) widget .
And if i use default playlist (in progress movies) it doesn't synced with Trakt only local just like i said above
(2020-12-12, 03:39)nazim12 Wrote: [ -> ] (2020-12-12, 02:18)mathu204 Wrote: [ -> ] (2020-12-11, 18:56)nazim12 Wrote: [ -> ]After reset .
Did u install Trakt addon and set the. Settings? For me it won’t sync playback progress but it will sync watched statuses.
Also again if I back up the progress is saved to the library so it works, there is just a bug with the trakt addon I believe bc every time I run a trakt sync it wipes playback progresses among episodes.
(2020-12-12, 06:58)mathu204 Wrote: [ -> ] (2020-12-12, 03:39)nazim12 Wrote: [ -> ] (2020-12-12, 02:18)mathu204 Wrote: [ -> ]Is that library content u have because the only time I get 0% is on non library widgets from addons
Yes using Trakt to sync with Kodi progress , Trakt need Auto sync with Skin helper always otherwise it wont reflect progress movies ( Right now it wont syncing )
Hey all have a question so I was looking at cart and original bingie and saw that the search lists he has looks like there’s a lot more, I kinda remember the discussion I had with Hugo and maybe Achilles about how the search lists are contained in an xml, so my question is is it possible to get the one from his Titan bingie and just drag and drop it in bingie mod and it would work or would more work need to be done on my side?
Also
https://github.com/trakt/script.trakt/issues/518
In here he mentions that trakt addon only ever sets progress does not go about removing, do u think it is possible (I’m not sure if it even is that a skin could do something to interfere with the addon but hey never know) that there is a bug in Titan bingie mod making it so that episodes progress keeps getting wiped on a. Trakt sync?
Hi, love the skin, just had a few questions.
Is there some steps to make the imdb and trakt ratings work? I have trakt installed and connected to my account.
Is there a way to remove the Netflix logo on the bottom right of screen ?
Can I change the exit Netflix to just exit ?
(2020-12-13, 09:34)Rustdroid Wrote: [ -> ]Hi, love the skin, just had a few questions.
Trakt ratings aren't implemented yet. It will be in the next update. For IMDB and other ratings check here:
https://forum.kodi.tv/showthread.php?tid...pid2760870
Remove Netflix logo in Homescreen Options.
Change power menu label in Configure shortcuts>Customise Power menu.
Can Ratings instantly show on widgets ? right now when I scroll movies horizontally then each movie rating come after 10 second but once it appears then it doesn't take time to load but at first it take time how to reduce time?
I have previously asked but could not find on my own , New Footer Ratings icons are small in size compare to default older Ratings icons of Bingie can someone make new Ratings icons size equal to default one ?
Reducing the size of new footer icons not a good idea , kindly keep in mind for next update if possible.
Older Footer Ratings icons
https://i.postimg.cc/DzfJPpJ8/image.png
https://i.postimg.cc/dQhQvccq/image.png
New footer icons are not Polished as well .
I have selected Marvel Movies playlist on spotlight when I select trailers to play on spotlight , it does play trailer of spotlight movie BUT when it play, movie name and rating switched to next movie of spotlight playlist but trailer keep playing of previous spotlight movie . which is odd and not syncnrize details and trailer.
About to play Dr Strange trailer
https://i.postimg.cc/W12nKvhn/image.png
when it play trailer then details of movie switched to Avengers but trailer is of dr strange
https://i.postimg.cc/FHDZXBSQ/image.png
(2020-12-13, 19:22)nazim12 Wrote: [ -> ]I have selected Marvel Movies playlist on spotlight when I select trailers to play on spotlight , it does play trailer of spotlight movie BUT when it play, movie name and rating switched to next movie of spotlight playlist but trailer keep playing of previous spotlight movie . which is odd and not syncnrize details and trailer.
Yep. That’s been mentioned many times since OG Bingie 1.3. I’ve never looked into because I doubt I’d solve it and I don’t even have auto trailers enabled.
(2020-12-13, 20:01)HugoL Wrote: [ -> ] (2020-12-13, 19:22)nazim12 Wrote: [ -> ]I have selected Marvel Movies playlist on spotlight when I select trailers to play on spotlight , it does play trailer of spotlight movie BUT when it play, movie name and rating switched to next movie of spotlight playlist but trailer keep playing of previous spotlight movie . which is odd and not syncnrize details and trailer.
It was solved Cartman did a pull request to merge the fix into kodi's master but the powers to be denied it even tho it was flawless and caused no errors anywhere that could be found after nightly testing. Nazim if you want to fix this problem you will have to merge the code into a clone of Kodi and make your own APK. Don't ask me how I have no idea.
here I talked about it a while back
https://forum.kodi.tv/showthread.php?tid...pid2974425
(2020-12-14, 00:51)cscott1 Wrote: [ -> ] (2020-12-13, 20:01)HugoL Wrote: [ -> ] (2020-12-13, 19:22)nazim12 Wrote: [ -> ]I have selected Marvel Movies playlist on spotlight when I select trailers to play on spotlight , it does play trailer of spotlight movie BUT when it play, movie name and rating switched to next movie of spotlight playlist but trailer keep playing of previous spotlight movie . which is odd and not syncnrize details and trailer.
here I talked about it a while back https://forum.kodi.tv/showthread.php?tid...pid2974425
I’m having an issue of my own now. I’ve lost my IMDB top250 meta for TV shows.
Anyone else experiencing this?
