(2020-08-11, 19:39)shkop Wrote: [ -> ] (2020-08-11, 19:01)spinecho Wrote: [ -> ] (2020-08-11, 10:41)AchillesPunks Wrote: [ -> ]Let me know what you think.
- ClearLogo still small and my UK ratings are the same monochromatic as original version.
same with me
I've rolled back to Version 1 of the Mod as this new version is making my Kodi crash :-(
same with me
I didn't add the view to the UK version yet. I'm still getting all the bugs out.
(2020-08-12, 07:28)shkop Wrote: [ -> ] (2020-08-12, 05:23)AchillesPunks Wrote: [ -> ] (2020-08-11, 19:39)shkop Wrote: [ -> ]same with me
thank you for your work
At work right now can check it out right now.
Hi guys
I have a problem with the icons in the side menu. Sometimes they are and sometimes they disappear. What to do to fix it? Can you disable these icons completely?
screens:
Screen1
Screen2
(2020-08-12, 14:55)xsynapse_ Wrote: [ -> ]Hi guys
screens:
Screen1
Screen2
Not sure you are using the bingie mod skin. Yours has a line on the side menu. That was removed from the texture.xbt, are you using Titan mod or bingie skin?.
(2020-08-12, 14:21)trkselim Wrote: [ -> ] (2020-08-12, 14:15)AchillesPunks Wrote: [ -> ] (2020-08-12, 13:53)trkselim Wrote: [ -> ]Check your email
And tell me what you think
What xmls were edited?
IncludesBingie
IncludesHomeBingie
IncludesHomeWidgets
Thank you. I'll test it out in a bit. I'm going to go to sleep now and give it a try when I get up.
