(2020-12-14, 22:34)minhgi Wrote: [ -> ] (2020-12-14, 20:37)HugoL Wrote: [ -> ] (2020-12-14, 03:02)trkselim Wrote: [ -> ]Same here for movies and tv
For movies too? That’s weird. When did you notice the problem?
Following your guys about comment about top 250 not appearing, I clear the simplecache and reload the skin. Ugh. Got every rating except for that. IMDB show but not Top 250. Restore the from backup. Good find about the issue.
I think top250 were need to enabled while scraping in universal movie scraper other wise it won't display.
(2020-12-14, 23:16)nazim12 Wrote: [ -> ] (2020-12-14, 22:34)minhgi Wrote: [ -> ] (2020-12-14, 20:37)HugoL Wrote: [ -> ]For movies too? That’s weird. When did you notice the problem?
That’s for movies. Top250 for tv shows come from Skin Helper. It’s not scraped by Kodi scrapers.
(2020-12-15, 00:53)HugoL Wrote: [ -> ] (2020-12-14, 23:16)nazim12 Wrote: [ -> ] (2020-12-14, 22:34)minhgi Wrote: [ -> ]Following your guys about comment about top 250 not appearing, I clear the simplecache and reload the skin. Ugh. Got every rating except for that. IMDB show but not Top 250. Restore the from backup. Good find about the issue.
OK, one more thing can skin helper associate with trakt account to show watched or watching or progress media?
Is there a way to stop the movie rating coming up when I press play. It says Rated PG or Rated R. It also dulls the screen, that's what I don't like about it.
(2020-12-17, 12:30)Rustdroid Wrote: [ -> ]Is there a way to stop the movie rating coming up when I press play. It says Rated PG or Rated R. It also dulls the screen, that's what I don't like about it.
Yeah, that’s quite annoying. I’ve remove the diffuse image behind it. It may however make the MPAA certification text harder to read depending on the background.
I’ve also added certification logo for users of the UK certification logos. I can’t update yet though because I’m in the middle of a few other edits too.
So working on my build and I deleted my simplecach and I lost my top 250 tv show meta skin helper widget and all. Luckily I was able to restore the deleted .db file and it fixed the issue. Looks like Nazims outline is is the only way to get all your meta after a simplecach delete so don't do it unless you want to rescrape everything.
(2020-12-17, 17:18)HugoL Wrote: [ -> ] (2020-12-17, 12:30)Rustdroid Wrote: [ -> ]Is there a way to stop the movie rating coming up when I press play. It says Rated PG or Rated R. It also dulls the screen, that's what I don't like about it.
Is there a way for me to delete the image behind it to stop the dull affect ?
It would be good to have a option in the future to turn that rating off completely or just do it once at start of movie.
I'm not that experienced with this skin but have it setup good now. That's only thing I'd like to change.
(2020-12-10, 21:37)AchillesPunks Wrote: [ -> ] (2020-12-10, 11:45)nazim12 Wrote: [ -> ] (2020-12-10, 06:23)mathu204 Wrote: [ -> ]My movie progress works but none of my episodes progress I’ve been goin back and forth on the GitHub but so for nothing. The episodes watched statuses update, but no playback progress, Idec if it’s off by a few minutes or so but none of my progress gets updated
Yes Bingie default playlist " In progress TV Shows " wont work for Library items , but Skin helper Playlists "In progress TV Shows or continued watching episodes " which is directly linked with Trakt live ( Very Slow) work for TV Shows & Episodes .
ok sorry I don't use anything but local media. So does in progress TV show, and Movies show in progress percentage?
Edit : Progress percentage not working , its showing 0% to all at least for me and red bar not working as well. Even Red bar on Continuous watching episode not showing on spotlight area Under Clear Logo.
(2020-12-18, 08:44)nazim12 Wrote: [ -> ] (2020-12-10, 21:37)AchillesPunks Wrote: [ -> ] (2020-12-10, 11:45)nazim12 Wrote: [ -> ]Yes Bingie default playlist " In progress TV Shows " wont work for Library items , but Skin helper Playlists "In progress TV Shows or continued watching episodes " which is directly linked with Trakt live ( Very Slow) work for TV Shows & Episodes .
This issue exists for a long time now. This is the only issue that annoys me and wasnt able to fix it.
(2020-12-18, 20:59)ronnel Wrote: [ -> ] (2020-12-18, 08:44)nazim12 Wrote: [ -> ] (2020-12-10, 21:37)AchillesPunks Wrote: [ -> ]ok sorry I don't use anything but local media. So does in progress TV show, and Movies show in progress percentage?
Do you have this with library content bc for me it wasn’t a bug more just that bingie doesn’t support addon content as much as library, as well as the fact that addons use their own resume points rather than Kodi library ones where Bingie sets and draws from. Once I switched to library integration it was all smooth sailing.
(2020-12-18, 23:23)mathu204 Wrote: [ -> ] (2020-12-17, 17:30)cscott1 Wrote: [ -> ]So working on my build and I deleted my simplecach and I lost my top 250 tv show meta skin helper widget and all. Luckily I was able to restore the deleted .db file and it fixed the issue. Looks like Nazims outline is is the only way to get all your meta after a simplecach delete so don't do it unless you want to rescrape everything.
What was Nazims fix?
He restored the simplecache database with the working top 250.
(2020-12-18, 23:22)mathu204 Wrote: [ -> ] (2020-12-18, 20:59)ronnel Wrote: [ -> ] (2020-12-18, 08:44)nazim12 Wrote: [ -> ]Edit : Progress percentage not working , its showing 0% to all at least for me and red bar not working as well. Even Red bar on Continuous watching episode not showing on spotlight area Under Clear Logo.
I do have this with library content. In fact, I tried it with both, local library and addon, both showed this bug.
HugoL @
AchillesPunks I found a couple of bugs. Spotlight sometimes plays the wrong trailer. For example, Dr. House appears and then start trailer for some Japanese movie called House. I noticed that they are not the same trailers when you go for information and then trailer and the ones that are released on the spotlight. Also with the spotlight, while the current trailer is running and before it is finished, a clear logo and information about another movie appear. When the trailer ends, the one that appeared doesn't start, but a third movie appears and then the trailer starts from it. The font from the skin does not work with all languages, for example Russian. Some characters appear instead of letters. And a small request, please enlarge a little the MPAA and movie studios logo icons. The icons are too small especially for a movie studios. It looks bad especially on TV.
