2020-12-21, 20:43
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166
2020-12-21, 21:02
(2020-12-21, 20:43)Blackysb Wrote: [ -> ]"for result links using Prime Minister"
What's that? Is it just an add-on?
its just like we have A.M for morning and PM for afternoon and night .
2020-12-21, 21:06
(2020-12-21, 20:07)knowellnoel Wrote: [ -> ]Hello guys I've been using Kodi for awhile now but gotta admit still a noob at it, so I spent the entire day today fixing this but I couldn't.I can't get any ratings to show up other than tmdb.Please any help would be highly appreciated.
Ratings Meta (and API keys in general)
For ratings from IMDB, TMDB, TVDB, Rotten Tomatoes and Metacritic
1) Make sure they are enabled in 'Media Library Views' tab under 'Media Flags, Ratings ......' (they should be ON by default)
2) To enable them in BINGIE views, go to homelayout tab and enable them under 'Footer' header (tick OFF the setting 'Disable ratings flags in bingie views...')
To enable them in libraries, in 'Media Library Views' tab, tick off the setting 'Do not show footer in views'
3) [THIS IS DONE PRIOR TO LIBRARY SCAN] Use scrapers and set in there settings to get ratings from IMDB & TMDB for movies (e.g Universal scraper). and TVDB & IMDB for tv shows (e.g TVDB Scraper).
4) Go to Skin Settings -> Supported addons -> select 'Metadata and Artwork Module', switch to 'API Keys' tab, and fill with your API keys.
For Rottern Tomatoes & MetaCritic you'll need to have an OMDB key - you can get it from here https://www.omdbapi.com/apikey.aspx
for TMDB Key - www.themoviedb.org
Fanart key is not important for ratings but is for fanart images in the skin, get from https://fanart.tv/
2020-12-21, 21:08
Getting the Ratings to show up has been discussed multiple times in the last few weeks scroll back and read the last 10 pages of this thread and you will learn all you need to know.
Edit*** or just read the last post by neurosis lol
2020-12-22, 03:19
Hello again friends,
Unfortunately, I'm still having issues using BINGIE and BINGIE MOD skins on my Raspberry Pi 4 with Kodi 18.7, and I'm still seeing a black screen when I try to use BINGIE or BINGIE MOD.
I tried to uninstall both skins and reinstall them, but I'm still getting the black screen.
Could the problem be related to error messages I'm seeing for the Skin Helper Service and the Skin Helper Service Backgrounds service when Kodi is first turned on?
Also, when I checked the dependencies lists for both skins, I'm saw wrong version numbers for a few of the installed dependencies. For instance, as you can see in the screenshots, Skin Helper Service and the Skin Helper Service Backgrounds are showing as if version 1.0.0 is installed, and not their actual version number. Could this mistaken identification of the installed dependencies versions lead to the black screen?
2020-12-22, 11:22
(2020-12-22, 03:19)mjeshurun Wrote: [ -> ]Hello again friends,
You haven’t mentioned any of the steps I’ve asked you to take.
2020-12-22, 11:54
(2020-12-22, 11:22)HugoL Wrote: [ -> ](2020-12-22, 03:19)mjeshurun Wrote: [ -> ]Hello again friends,
Sorry, @HugoL. I tried the steps you mentioned, but they didn’t help.
Is there a terminal command that removes all Kodi relevant files?
Maybe i didn’t uninstall it correctly.
2020-12-22, 12:12
(2020-12-07, 21:51)HugoL Wrote: [ -> ]@mjeshurun(2020-12-07, 21:04)mjeshurun Wrote: [ -> ](2020-12-07, 16:17)HugoL Wrote: [ -> ]Is this a fresh install that has had no other skins installed apart from bingie and bingie mod?Hi @HugoL , many thanks for replying 🙏
Other than Bingie and Bingie MOD, I also installed Estuary Leia Mod, Amber and AppTV skins, but I deleted Amber and AppTV.
Ok. In either bingie skin, reset menus to skin default by going
skin settings > configure shortcuts > restore menu items.
Also do the below option > Restore Default Widgets in Hubs.
And for good measure, go to
Back up and restore > Reset the skin to default settings.
Failing this, you can try a fresh Kodi and bingie install. Bingie 1.03 for the dependencies and then the bingie mod 1.09 skin.
Please read the steps again. Note that the last option is a fresh Kodi install, not just a fresh bingie install.
2020-12-22, 14:12
(2020-12-21, 21:06)neurosis13 Wrote: [ -> ]I've been at it for the last 10 hours and I can finally get some peace of mind.Thanks to you I've done it but I have a really minor problem and hoping it will be fixed asap,it's just imdb and tmdb rating is showing instantly but metacritic and rotten tomatoes aren't showing for all the movies I've just added a little over 10 movies and it's only showing rotten tomatoes and metacritic for just one and not showing for others.What do I have to do to fix this?(2020-12-21, 20:07)knowellnoel Wrote: [ -> ]Hello guys I've been using Kodi for awhile now but gotta admit still a noob at it, so I spent the entire day today fixing this but I couldn't.I can't get any ratings to show up other than tmdb.Please any help would be highly appreciated.
2020-12-22, 14:44
(2020-12-22, 12:12)HugoL Wrote: [ -> ](2020-12-07, 21:51)HugoL Wrote: [ -> ]@mjeshurun(2020-12-07, 21:04)mjeshurun Wrote: [ -> ]Hi @HugoL , many thanks for replying 🙏
I tried your suggestions except for “Also do the below option > Restore Default Widgets in Hubs.”, because I didn’t find the command in the settings.
I checked the Kodi.log for clues of the problem, and it shows errors for Skin Helper Service and Skin Helper Service Backgrounds.
How should I share the log?
I understand I shouldn’t add it into the forum.
2020-12-22, 15:01
(2020-12-22, 11:54)mjeshurun Wrote: [ -> ]After uninstalling kodi on my android devices I always power off the system for a few minutes before reinstalling because there always seems to be some leftovers. Just curious why are you using a ras pie? They are so flaky, they might be fun to build and tinker with but not the most reliable streamer. There are a lot of affordable options right now. I Just purchased a Dynalink Android TV box for $29.50 from walmart runs official Android TV and Android 10. I have kodi 18.9 with the Bingie mod installed on it along with the official Netflix, Amazon Prime, Hulu, and many more, I highly recommend it I barely notice a difference between it and my Nvidia Shield.(2020-12-22, 11:22)HugoL Wrote: [ -> ](2020-12-22, 03:19)mjeshurun Wrote: [ -> ]Hello again friends,
2020-12-22, 15:10
(2020-12-22, 15:01)cscott1 Wrote: [ -> ](2020-12-22, 11:54)mjeshurun Wrote: [ -> ]After uninstalling kodi on my android devices I always power off the system for a few minutes before reinstalling because there always seems to be some leftovers. Just curious why are you using a ras pie? They are so flaky, they might be fun to build and tinker with but not the most reliable streamer. There are a lot of affordable options right now. I Just purchased a Dynalink Android TV box for $29.50 from walmart runs official Android TV and Android 10. I have kodi 18.9 with the Bingie mod installed on it along with the official Netflix, Amazon Prime, Hulu, and many more, I highly recommend it I barely notice a difference between it and my Nvidia Shield.(2020-12-22, 11:22)HugoL Wrote: [ -> ]You haven’t mentioned any of the steps I’ve asked you to take.
Hi @cscott1
I bought a Raspberry Pi 4 (4GB) to use as an OpenHAB smart home system. And since I already have the Raspberry Pi, I figured I’d use it also for Kodi.
Is there a particular terminal command to completely uninstall kodi with all its dependencies and addons?
2020-12-22, 15:24
(2020-12-22, 15:10)mjeshurun Wrote: [ -> ]Honestly I'm an Android and Windows guy not really familiar with ras pi operating systems. Have you tried using OSMC instead of Kodi from the little bit I have read that seems to be the go to system for ras pies and all kodi addons are compatible with it.(2020-12-22, 15:01)cscott1 Wrote: [ -> ](2020-12-22, 11:54)mjeshurun Wrote: [ -> ]Sorry, @HugoL. I tried the steps you mentioned, but they didn’t help.After uninstalling kodi on my android devices I always power off the system for a few minutes before reinstalling because there always seems to be some leftovers. Just curious why are you using a ras pie? They are so flaky, they might be fun to build and tinker with but not the most reliable streamer. There are a lot of affordable options right now. I Just purchased a Dynalink Android TV box for $29.50 from walmart runs official Android TV and Android 10. I have kodi 18.9 with the Bingie mod installed on it along with the official Netflix, Amazon Prime, Hulu, and many more, I highly recommend it I barely notice a difference between it and my Nvidia Shield.
Hi @cscott1
2020-12-22, 15:38
(2020-12-22, 15:24)cscott1 Wrote: [ -> ](2020-12-22, 15:10)mjeshurun Wrote: [ -> ]Honestly I'm an Android and Windows guy not really familiar with ras pi operating systems. Have you tried using OSMC instead of Kodi from the little bit I have read that seems to be the go to system for ras pies and all kodi addons are compatible with it.(2020-12-22, 15:01)cscott1 Wrote: [ -> ]After uninstalling kodi on my android devices I always power off the system for a few minutes before reinstalling because there always seems to be some leftovers. Just curious why are you using a ras pie? They are so flaky, they might be fun to build and tinker with but not the most reliable streamer. There are a lot of affordable options right now. I Just purchased a Dynalink Android TV box for $29.50 from walmart runs official Android TV and Android 10. I have kodi 18.9 with the Bingie mod installed on it along with the official Netflix, Amazon Prime, Hulu, and many more, I highly recommend it I barely notice a difference between it and my Nvidia Shield.
Hi @cscott1
Thanks for the tip about OSMC, but I’m not sure it’ll be a good solution for me.
First and for most, I need to use Raspberry Pi OS to power my smart home system.
I understand OSMC is an alternative full OS that supports running apps, but, reconfiguring my smart home systems OSMC might be problematic.
Therefore, I prefer to stay with the official Raspberry Pi OS.
2020-12-22, 16:07
(2020-12-22, 15:38)mjeshurun Wrote: [ -> ](2020-12-22, 15:24)cscott1 Wrote: [ -> ](2020-12-22, 15:10)mjeshurun Wrote: [ -> ]Hi @cscott1Honestly I'm an Android and Windows guy not really familiar with ras pi operating systems. Have you tried using OSMC instead of Kodi from the little bit I have read that seems to be the go to system for ras pies and all kodi addons are compatible with it.
Do you have another device to set up kodi on? I was able to set up kodi with the Bingie mod on my windows laptop then by copying the Apps and Userdata folders and paste them into a fresh install of kodi on my android devices essentially copying the build. I'm not sure you can do the same on the ras pie because I dont know how easy it is to navigate the file system on the ras pie operating system but its the only idea I have left.
