(2020-12-30, 22:24)mathu204 Wrote: [ -> ] (2020-12-30, 13:21)HugoL Wrote: [ -> ] (2020-12-30, 11:31)mathu204 Wrote: [ -> ]Bump on this, any thoughts @HugoL ?
Also have a new suggestion, I was messing around with my other Auramod build that I know really just use for testing before importing stuff into Titan Bingie, but I noticed that instead of TBM where all the episode counts (or remaining episodes to watch) are on the corner of the posters. Auramod shows them only on the one you are highlighting which i think is better Bc you can see the posters and stuff a lot better when its not on all of them, IMO.
https://imgur.com/a/2I0hZSk
What do u think?
1. No idea about wrong episodes showing up on Next Episodes widget I'm afraid.
2. Achilles tried to add movies to the Continue Watching widget in order to get the progress bar for them. It worked for him, didn't work for me. Maybe something to do with using .strm files but I'm not sure.
3. There's no "New" poster tag for movies, only episodes. I don't think there needs to be a new tag on posters for movies. Taken is also a TV series, maybe you got confused and saw the new episode tag for the Taken TV series or maybe it's the film but the info was scraped incorrectly as a TV show.
4. No idea, never seen this. None of my seasons have names. Pretty sure you got an answer for this already, something related to your addon.
5. Probably possible, but wouldn't be high on my list. If you want to guarantee a default rating, best to switch your default rating to IMDB or TMDB. With the new footers that utilise TMDB helper, you won't need to set RT audience as default anyway.
As to your suggestion, that's a good idea. I've never liked or use the poster tags (apart from New Episodes) but if they're just on focus it would be much better.
I would prefer to have the poster tags smaller personally like Auramod does, but if we can get the only on focus to show up it would be much better alreaady as you said.
1. That sucks I guess for now not much I or we can do about it. It is what it is.
2. Do you or Acchiles use the .strms where it doesn't show up? I actually ran into a huge issue with my .strm library where progress bars and stuff were not showing (but it was for my episodes). and someone over on the Trakt github who was a godsend helped me figure out the problem! Try this fix with the movie progress bar one more time bc it might fix it for you or acchiles whoever uses the .strms, using SQL DBBrowser, navigate to userdata/Database/MyVideos116. Open it and then go to browse data, choose the movies table, and then check the table c11, which is runtime. If the movies in question that dont show progress have 0 it means it wont show up. You either have to manually put them in or create new nfos with something like tinymediamanager that has the runtime hardcoded in, and then set content to none, then back to movies for your movies folder to force a rescan.
3. I can understand your opinion if you dont wan't to put the New tag in, I was in the movies section so the Taken you see is a movie; you are right however in that I added Taken series and the Taken movies in at the same time so maybe it was a mix up. But if you dont add New as a tag for movies, it is still a very small (not important) visual bug that sometimes makes New Episodes appear for movies.
4. As I mentioned earlier the picture was not from an addon, remember addons cannot use the integrated season view it was from my Library where the show was scraped in using TMDB. The seasons are named like so over here: https://www.themoviedb.org/tv/12971/seasons , if you could test by integrating DBZ through TMDBHelper, scanning it with TMDB you could see for yourself.
5. Alright understood, yea i will most likely switch back to IMDB or TMDB with the new update. I do have a new idea tho that I'd like to suggest:
5A: So if you remember how I asked if you could make it so when Top 250 appears on the details row it doesn't appear on the footer? Or atleast an option for it? Can you also make it so, or an option where the default rating doesn't also show on the Footer? Example:
Movie is Avengers Endgame/ Details: Top 15 on IMDB, Liked by 88% (TMDB default).
Footer: Top 15 on IMDB, TMDB 8.8, IMDB 9.2, RT Critics 7.8, RT Audience 9.5, MC 8.5. I feel like the footer can be used for all the ALTERNATIVE ratings, instead of showing 2 ratings that are already shown on the Details panel.
5. I don’t think so. If you want ratings on home and views you’ll have to accept some redundancy.
All the ratings on the footer are from skinhelper (and soon to be tmdb helper). The rating on details row is the default scraped rating. There’s no way (I can think of) for the footer to know what rating your default rating is displaying and then exclude it.
The only thing I could do is provide a setting to individually disable ratings and then, if you know what default rating you scraped (and it’s the same default for all of your titles - which is unlikely in most cases) you can then disable that rating in your footer.
Users may well have various rating providers assigned to default depending on title, especially differing TV and a film rating defaults.
(2020-12-30, 23:14)HugoL Wrote: [ -> ] (2020-12-30, 22:24)mathu204 Wrote: [ -> ] (2020-12-30, 13:21)HugoL Wrote: [ -> ]1. No idea about wrong episodes showing up on Next Episodes widget I'm afraid.
Ah I see, ill give up on it then. The setting to individually hide ratings on the footer would be nice to achieve this doesnt have to be a priority thing. If I disabled it on the footer, would it still show up in x% liked as the default? Would it be possible to have 2 different settings for TV and Movie footers so i could hide different ones for each? If not its probably a bust but now that uve explained everything to me anyway Im probably fine with just leaving it how it is.
(2020-12-30, 23:32)mathu204 Wrote: [ -> ] (2020-12-30, 23:14)HugoL Wrote: [ -> ] (2020-12-30, 22:24)mathu204 Wrote: [ -> ]I would prefer to have the poster tags smaller personally like Auramod does, but if we can get the only on focus to show up it would be much better alreaady as you said.
Yes, % liked would not be effected.
I’m reluctant to add these individual settings at the moment. Especially creating them for both tv and film separately. 6 ratings for films, 4 ratings for TV shows. That’s 10 extra settings to add the settings menu.
(2020-12-30, 23:59)HugoL Wrote: [ -> ] (2020-12-30, 23:32)mathu204 Wrote: [ -> ] (2020-12-30, 23:14)HugoL Wrote: [ -> ]5. I don’t think so. If you want ratings on home and views you’ll have to accept some redundancy.
Completely understandable, since I took in your explanation of it all its honestly no big deal to me. I can live with it
I been using the Titan Bingie theme for some weeks now, and recently updated to this Mod 1.0.9., and I absolutely love it. However, in the regular 1.0.3 version the tagline (from movies) were sitting nicely between the clearlogo/title and the plot text. But in this new Mod, it disappeared. It was visible in "media library views" and I believe also in the Spotlight section on the Home screen.
I been trying to figure out if there is a way to toggle it back on in settings, but I havent succeeded finding a solution.
So my question is. Is it possible to get it back, and how would I do it? Is it possible to simply edit a template file?
I am adding screenshots below of my Homescreen and Media library views.
https://i.postimg.cc/DfHKkL5s/screenshot001.png
https://i.postimg.cc/7h3vnQ7k/screenshot000.png
(2020-12-31, 11:09)ascaaear Wrote: [ -> ]I been using the Titan Bingie theme for some weeks now, and recently updated to this Mod 1.0.9., and I absolutely love it. However, in the regular 1.0.3 version the tagline (from movies) were sitting nicely between the clearlogo/title and the plot text. But in this new Mod, it disappeared. It was visible in "media library views" and I believe also in the Spotlight section on the Home screen.
It was removed. More often than not, the tagline was truncated to fit, depending on where you scraped the tagline from.
However, if you want it, search for the following in includesbingie.xml
<variable name="BingieSublabel">
and replace the first value condition directly underneath it with the following line
<value condition="!String.IsEmpty(ListItem.TagLine)">$INFO[ListItem.TagLine]</value>
mathu204 Probably of interest to you too, I seem to remember you wanting something to always appear as a sublabel.
As always, fantastic work and a fantastic skin!
One question that I may have asked before (apologies if so) but on the homescreen widgets is it possible to show moviesets mixed with the movies?
Currently I have to make a separate node/playlist widget for single movies and another node/playlist widget to display moviesets, otherwise the movieset doesn't display, rather it shows as separate movies.
Sorry, don't think I'm explaining it well.
Can we have 8 entries on main window left sidebar instead of just six?
How can we increase vertical high of sidebar menu?
Thanks for your work
(2020-12-31, 19:23)redglory Wrote: [ -> ]Hi,
You can have as many as you like. It will still only show 6 at a time.
As you scroll, they will become visible.
(2020-12-31, 19:37)HugoL Wrote: [ -> ] (2020-12-31, 19:23)redglory Wrote: [ -> ]Hi,
I know that, I just prefer to have more show.
I've found it how to tweak the height on "IncludesBingie.xml" file:
<control type="list" id="900">
<top>145</top>
<width>bingie_menu_width</width>
<height>800</height> <!--default = 680-->
It looks like this
i have a serious problem, on android box, suddenly on bingieview for library items, i don't see the duration of film under the title (i see as normal imdb rating, year)
on the other side, on home widgets, i can see normally the duration.
if a change to other view, i can see as normal the duration of film, so it's a known attribute of the items. i have searched on settings and i have cleared cache etc, restared etc but no solution.
how to solve this problem?
thanks for any help.
Would it be possible to re-activate the option to have different widget types that was previously available in the original Titan mod ? I prefer the customisation of having poster / landscape and square as options rather than the one option throughout
Cheers
(2020-12-31, 21:26)sasquatchjaques Wrote: [ -> ]Would it be possible to re-activate the option to have different widget types that was previously available in the original Titan mod ? I prefer the customisation of having poster / landscape and square as options rather than the one option throughout
Cheers
Disable fixed focus and fixed frame and you can chose widget layouts individually.
I’ll try that 👍🏻👍🏻
Thanks and happy new year
(2020-12-31, 21:37)HugoL Wrote: [ -> ] (2020-12-31, 21:26)sasquatchjaques Wrote: [ -> ]Would it be possible to re-activate the option to have different widget types that was previously available in the original Titan mod ? I prefer the customisation of having poster / landscape and square as options rather than the one option throughout
Cheers
