Full Version: Titan BINGIE MOD v1 (UPDATED - 07/24/2020)
(2020-12-31, 21:39)sasquatchjaques Wrote: [ -> ]I’ll try that 👍🏻👍🏻
Thanks and happy new year
(2020-12-31, 21:37)HugoL Wrote: [ -> ]
(2020-12-31, 21:26)sasquatchjaques Wrote: [ -> ]Would it be possible to re-activate the option to have different widget types that was previously available in the original Titan mod ? I prefer the customisation of having poster / landscape and square as options rather than the one option throughout
Cheers
Disable fixed focus and fixed frame and you can chose widget layouts individually.
No problem, happy New Year!
(2020-12-31, 11:49)HugoL Wrote: [ -> ]
(2020-12-31, 11:09)ascaaear Wrote: [ -> ]I been using the Titan Bingie theme for some weeks now, and recently updated to this Mod 1.0.9., and I absolutely love it. However, in the regular 1.0.3 version the tagline (from movies) were sitting nicely between the clearlogo/title and the plot text. But in this new Mod, it disappeared. It was visible in "media library views" and I believe also in the Spotlight section on the Home screen.
I been trying to figure out if there is a way to toggle it back on in settings, but I havent succeeded finding a solution.
So my question is. Is it possible to get it back, and how would I do it? Is it possible to simply edit a template file?
I am adding screenshots below of my Homescreen and Media library views.
https://i.postimg.cc/DfHKkL5s/screenshot001.png
https://i.postimg.cc/7h3vnQ7k/screenshot000.png
It was removed.  More often than not, the tagline was truncated to fit, depending on where you scraped the tagline from.
However, if you want it, search for the following in includesbingie.xml
<variable name="BingieSublabel">
and replace the first value condition directly underneath it with the following line
<value condition="!String.IsEmpty(ListItem.TagLine)">$INFO[ListItem.TagLine]</value>
@mathu204 Probably of interest to you too, I seem to remember you wanting something to always appear as a sublabel.
If I put this in there would it replace the top150 IMDB and Watch Season 1 Now? If i put this I would only want this to appear when none of the options are available
(2021-01-01, 02:59)mathu204 Wrote: [ -> ]
Top 250 takes priority. Taglines are only for films as far as I can remember so it wouldn’t replace Watch season x x sublabel.
(2021-01-01, 03:17)HugoL Wrote: [ -> ]
(2020-12-31, 11:49)HugoL Wrote: [ -> ]It was removed.  More often than not, the tagline was truncated to fit, depending on where you scraped the tagline from.
Thank you, and happy new years to everyone here!
happy new year and hope to have health ths year.
I noticed also that although on widgets of home screen, if I go to info details (I use bingie info and no extended) , I can see actors, on media library if I go to info details I cannot see the actors (the option is enabled in settings).
I cannot understand why there are these problems in media library only and how fix this.
has any face any similar problem?
(2020-12-31, 20:35)georgew21 Wrote: [ -> ]i have a serious problem, on android box, suddenly on bingieview for library items, i don't see the duration of film under the title (i see as normal imdb rating, year)
on the other side, on home widgets, i can see normally the duration.
if a change to other view, i can see as normal the duration of film, so it's a known attribute of the items. i have searched on settings and i have cleared cache etc, restared etc but no solution.
how to solve this problem?
thanks for any help.
Happy New Year to everyone.
@HugoL @AchillesPunks I have really good news. The latest version of tmdb helper includes all metadata (movie duration, mpaa, fanarts ...). I think now the implementation of tmdb helper in tbm will be even easier. Now it works great and I guess it will be even better.
In some rare places, clearlog is missing, raitings not showing... For example poster row view, poster shift... but only on tv shows, not on movies.
It appeared in some places, such as here only in the first season.
In general, I think it needs to be fixed some views. Poster shift missing background and there is an option to turn off the background. In same view mirror effect give other poster... But in any case, I think everything is slowly going in the right direction. Just keep going guys in the new year still such a good job. All the best guys in 2021. :-)
(2021-01-01, 16:05)matke Wrote: [ -> ]Happy New Year to everyone.
Thanks for the heads up! Is there any documentation or discussion on the new release ?
@HugoL Only our discussion on github. Based on my request, our friend jurialmunkey did this. There are some more announcements for improvements. It also speeds up content loading time. There are really a lot improvements. Download the latest version from githuba.
F**k!!! I just lost the top 250 tv show meta. It was there last night and it's just gone today on both my TV and my laptop. The tv build is just copied from my laptop so it has to be something like a hard limit that each user has for how many requests can be made for that info or something of the sort.
Edit*** after a reboot of both systems it's back confused but relieved.
@HugoL I noticed a couple of bugs. First, sometimes in the library or addon missing movie run time. When I delete kodi cache, it returns to its place. Secondly when I turn on the UK mpaa will not always show me a circle with a rating it remains the default mpaa, rating pg or some other. I also noticed when I watch a movie and I use tmdb helper, in tmdbh it shows me the progress or that I watched a movie but not in the widget. But that I think is up to the integration of tmdbh into tbm or I am wrong?
(2021-01-01, 23:37)matke Wrote: [ -> ]@HugoL I noticed a couple of bugs. First, sometimes in the library or addon missing movie run time. When I delete kodi cache, it returns to its place. Secondly when I turn on the UK mpaa will not always show me a circle with a rating it remains the default mpaa, rating pg or some other. I also noticed when I watch a movie and I use tmdb helper, in tmdbh it shows me the progress or that I watched a movie but not in the widget. But that I think is up to the integration of tmdbh into tbm or I am wrong?
1. Not sure what causes this bug. Library bingie view does sometimes miss run times but a restart tends to help.
2. Regarding UK age cert. icons, in TMDB helper settings, remove the MPAA prefix. Just bare in mind, any title that's already been cached would still not show the UK icons.  You'd need to refresh them individually.
3. I don't think so.  Probably related to your addon player.
(2021-01-01, 16:52)matke Wrote: [ -> ]@HugoL Only our discussion on github. Based on my request, our friend jurialmunkey did this. There are some more announcements for improvements. It also speeds up content loading time. There are really a lot improvements. Download the latest version from githuba.
Just tried it and it's working, thanks!
(2021-01-02, 02:43)HugoL Wrote: [ -> ]
Download the Trakt addon to sync watched statuses for problem 3.
(2020-12-29, 15:58)HugoL Wrote: [ -> ]
(2020-12-29, 11:45)georgew21 Wrote: [ -> ]hello, great skin. i would like to change the animation time of change beetween director/genres/actors red circles under plot.
could someone help what changes need to make to code? i have search for a lot hours, but i cant find this.
thanks a lot!!!
This isn't an animation.  It's a list of variable conditions to make the "more details" section appear random.
You can find the variable in includesbingie.xml by searching for this line
<variable name="BingieMoreDetails">
Whatever conditions you change here you should also change in the accompanying "BingieMoreDetailsImage" variable which is found directly below the "bingiemoredetails" variable.
 I'm actually in the process of reworking this whole section though, the idea being to make it appear more dynamic and extend the information provided.
Extended genre details to make it appear more as Netflix categories style rather than just the current "genre/genre/genre"  (There's also a sneak-peek on a new critics + count/votes footer I'm working on here)
More info section displaying Rotten Tomatoes critic consensus.
More details section constructing a nice organic looking paragraph with title, Network (if applicable), condensed genre, creator/director followed by any awards.
Regarding this I feel like more info on the plot could be shown what do u think? I guess u could just press info too but I think an extra line would benefit so u could get some more of an idea of the show or movie. It really works well only for the short plots imo like the one that only has 1-2 sentences (Knives Out in your example). Also what is the star beside the IMDB rating for? I feel like there could be icons beside the other two as well for consistency
Here is an imgur link i very very roughly edited the sizes of the ratings of what I think they would be better looking as with 1-2 comments. For the new footer you are designing, in Fargo the FX Studio logo is big enough, but on Knives Out the Lionsgate logo could be bigger personally. Now I understand its probably a universal sizing so im not sure why it looks so small for Lionsgate but i made it bigger on my edit for my liking anyway. But I understand it is probalby unlikely to fix that as its something universal.
Oh also a background colour for the TMDB icon would be nice something like a darker green that their icon officialy uses like here
https://apkpure.com/tmdb-movies-tv-shows...themoviedb
or here
https://play-lh.googleusercontent.com/IO...Dqxw2wPBAg
https://imgur.com/a/QOvjfDJ
