(2021-01-03, 23:32)HugoL Wrote: [ -> ] (2021-01-02, 09:59)mathu204 Wrote: [ -> ]Here is an imgur link i very very roughly edited the sizes of the ratings of what I think they would be better looking as with 1-2 comments. For the new footer you are designing, in Fargo the FX Studio logo is big enough, but on Knives Out the Lionsgate logo could be bigger personally. Now I understand its probably a universal sizing so im not sure why it looks so small for Lionsgate but i made it bigger on my edit for my liking anyway. But I understand it is probalby unlikely to fix that as its something universal.
Oh also a background colour for the TMDB icon would be nice something like a darker green that their icon officialy uses like here
https://apkpure.com/tmdb-movies-tv-shows...themoviedb
or here
https://play-lh.googleusercontent.com/IO...Dqxw2wPBAg
https://imgur.com/a/QOvjfDJ
All the icons in the yet-to-be released footer were designed to be equal height and length hence the IMDB icon designed this way. I'm going to revisit the previous footer too to make it larger so maybe that one would suit you better.
Regarding the new flat RT icon, looks like yours disappeared because Achilles swapped it back for personal preference and probably accidently uploaded it to GitHub. I also prefer the flat colour icon. Don't worry, it will be back soon.
Regarding studios, as I explained previously, I can only control the border size (or max size). I have absolutely no control over the size of the actual artwork within these borders which vary wildly, just like clearlogos for example. Hence the reason some look much larger/smaller than others.
Yep regarding the last one i assumed as much and am all good with it, just a pipe dream lol
or here
I think I might have accidentally swapped it by mistake.
(2020-12-31, 14:25)spinecho Wrote: [ -> ]As always, fantastic work and a fantastic skin!
One question that I may have asked before (apologies if so) but on the homescreen widgets is it possible to show moviesets mixed with the movies?
Currently I have to make a separate node/playlist widget for single movies and another node/playlist widget to display moviesets, otherwise the movieset doesn't display, rather it shows as separate movies.
Sorry, don't think I'm explaining it well.
Sorry to bump my own post.
I'm guessing by the lack of replies to this, it's not possible? :-(
(2021-01-05, 10:30)spinecho Wrote: [ -> ] (2020-12-31, 14:25)spinecho Wrote: [ -> ]As always, fantastic work and a fantastic skin!
Not sure if this is exactly what you’re looking for but, there’s an option in videos settings somewhere to show moviesets Among movies in library, not sure If it transfers over to widgets
edit: Its in Settings, Media Settings, Videos, Library subsection, "Show Movie Sets". not sure if it will work in widgets tho again so try it out.
(2021-01-05, 10:35)mathu204 Wrote: [ -> ] (2021-01-05, 10:30)spinecho Wrote: [ -> ] (2020-12-31, 14:25)spinecho Wrote: [ -> ]As always, fantastic work and a fantastic skin!
Thanks for the reply.
I've already got this setting applied and sadly it doesn't seem to extend to widget views :-(
(2021-01-05, 19:55)spinecho Wrote: [ -> ] (2021-01-05, 10:35)mathu204 Wrote: [ -> ] (2021-01-05, 10:30)spinecho Wrote: [ -> ]Sorry to bump my own post.
It would take some editing and I am very busy. It could be done the same way continue watching is setup in the xml. Would be in the overrides.xml.
(2021-01-06, 14:29)AchillesPunks Wrote: [ -> ] (2021-01-05, 19:55)spinecho Wrote: [ -> ] (2021-01-05, 10:35)mathu204 Wrote: [ -> ]Not sure if this is exactly what you’re looking for but, there’s an option in videos settings somewhere to show moviesets Among movies in library, not sure If it transfers over to widgets
Thank you @
AchillesPunks.
It's not a huge issue if it means having to change lots of files ;-) just would be nice to incorporate my movie sets along with my movies instead of having separate widget.
As always, many thanks for the support of this fantastic skin and stay well :-)
(2020-12-30, 13:21)HugoL Wrote: [ -> ] (2020-12-30, 11:31)mathu204 Wrote: [ -> ] (2020-12-28, 03:25)mathu204 Wrote: [ -> ]Glad you got it working Nazim no prob, now I have some questions for you nice folk at Titan Bingie Mod lol. Numbered and an imgur link to reference.
1. This is just continuing off the quoted thread above the first two images are just 2 pictures of it if i didnt explain it well enough. Wrong episode sometimes shows on Next episodes widget.
2. Im Not sure if this is meant to work this way, and if it is maybe you would consider changing it. So in the in progress episodes, it shows a red progress bar to visualize where you are in the episode. This bar does not show up for Movies in the main view. When i press info and it shows resume the bar is there so it is not like it isn't there or is it not possible to create. If there is a reason you dont add this why not? Is it cause its not like this in Netfilx, or cause there is a limitation of some sort? I do think that putting the bar for movies too would be nice as it makes for a more constant experience.
3. I dont encounter often but I added the movie Taken to my library and it said New episodes rather than New. Is the function to say "New" for movies that are recently added possible or there? It may just be a one off bug bc i added a show called Taken to my library at the same time too but just raising this. Not that serious but yea.
4. Some shows have names for seasons like DBZ, Naruto, or Archer, etc. The problem I have with this though is when I go into Bingie Episodes view, the seasons on the left are incorrectly ordered, I think it goes alphabetically which messes up the whole order. So far my only way to solve this is to switch to TVDB scraper, but as many of you know unfortunately TVDB may be switching to paid soon. Do u think u can make it so Bingie Episode view orders season by release date or something else instead to make it more accurate? Also the folders in my library are named Seasons 1 thru 9, the information provider is what gave the seasons these names.
5. Lastly, in the last image you can see there is a movie with only an iMDB, and TMDB rating. With RT Audience set as the default there is no "x% liked" status on the details row, can you consider making it so when the default rating is not available that it fallbacks to any of the other ratings that are available? In this case of the image, IMDB or TMDB.
https://imgur.com/a/CaWaJcE
Bump on this, any thoughts @HugoL ?
Also have a new suggestion, I was messing around with my other Auramod build that I know really just use for testing before importing stuff into Titan Bingie, but I noticed that instead of TBM where all the episode counts (or remaining episodes to watch) are on the corner of the posters. Auramod shows them only on the one you are highlighting which i think is better Bc you can see the posters and stuff a lot better when its not on all of them, IMO.
https://imgur.com/a/2I0hZSk
What do u think?
1. No idea about wrong episodes showing up on Next Episodes widget I'm afraid.
2. Achilles tried to add movies to the Continue Watching widget in order to get the progress bar for them. It worked for him, didn't work for me. Maybe something to do with using .strm files but I'm not sure.
3. There's no "New" poster tag for movies, only episodes. I don't think there needs to be a new tag on posters for movies. Taken is also a TV series, maybe you got confused and saw the new episode tag for the Taken TV series or maybe it's the film but the info was scraped incorrectly as a TV show.
4. No idea, never seen this. None of my seasons have names. Pretty sure you got an answer for this already, something related to your addon.
5. Probably possible, but wouldn't be high on my list. If you want to guarantee a default rating, best to switch your default rating to IMDB or TMDB. With the new footers that utilise TMDB helper, you won't need to set RT audience as default anyway.
As to your suggestion, that's a good idea. I've never liked or use the poster tags (apart from New Episodes) but if they're just on focus it would be much better.
oh back to 2. is there like a line of code i can just paste in somewhere to get the Movies continue watching or is it tedious?
(2021-01-07, 18:56)mathu204 Wrote: [ -> ] (2020-12-30, 13:21)HugoL Wrote: [ -> ] (2020-12-30, 11:31)mathu204 Wrote: [ -> ]Bump on this, any thoughts @HugoL ?
What do u think?
It's going to take more than just pasting a line of code I'm afraid. You would still be left with the movie details and ratings and everything else. Many things would need to be adjusted.
I actually tested it out around a year ago and had gotten side tracked with something else and never came back to it. I'm really busy right now so I really have no time when I'm off from work to help out @
HugoL. If I can find time I'll see about putting the progress bar for continue watching on HugoL next update, but I don't think I will be able to.
And happy new year to everyone. I know it's a little late.
(2021-01-07, 19:17)AchillesPunks Wrote: [ -> ] (2021-01-07, 18:56)mathu204 Wrote: [ -> ] (2020-12-30, 13:21)HugoL Wrote: [ -> ]1. No idea about wrong episodes showing up on Next Episodes widget I'm afraid.
I actually tested it out around a year ago and had gotten side tracked with something else and never came back to it. I'm really busy right now so I really have no time when I'm off from work to help out HugoL. If I can find time I'll see about putting the progress bar for continue watching on HugoL next update, but I don't think I will be able to.
Same to you!, and no no its completely fine then, you and Hugo have blessed up with this amazing skin so take your time. I just ask that you keep it on the long list of to-dos that you guys probalby have even if its at the very bottom. I wont rush u guys
Some new Icons for the new footer not as polished as HugoL
(2021-01-08, 13:04)Gmbexpert2020 Wrote: [ -> ]Titan BINGIE is a Titan fork that supports Kodi Leia and adds the new BINGIE layout which simulates Netflix UI for TV remote users. Terms of use.
What do you mean by terms of use?
AchillesPunks @
HugoL
This picture that is missing, which picture is from fanart.tv or kodi? I'm using one addon so I'm interested because it doesn't show this image, so I'd like try to fix it. Thanks in advance.
(2021-01-08, 18:18)matke Wrote: [ -> ]@AchillesPunks @HugoL
Use artwork beef and download the season landscape artwork
