[font][font]Ciao, perdona il mio inglese, sono italiano! [/font][/font]
[font][font]Grazie in anticipo per l'ottimo lavoro! [/font][/font]
[font][font]Tuttavia, come posso fare per disabilitare l'aggiornamento automatico di Spotlight ogni volta che cambio voce di menu?[/font][/font]
Hi, forgive my English, I'm Italian!
Thanks in advance for the excellent work!
However, how can I do to disable the auto update of spotlight every time I change menu item?
Does anyone else get this here in the red circle where the diffuse i think u call it is on top of the white bar and a bit of the poster??
(2021-01-11, 23:39)mathu204 Wrote: [ -> ]
No I don't. Have you made any adjustments of your own? That's the only way I see it doing that.
(2021-01-12, 05:49)AchillesPunks Wrote: [ -> ] (2021-01-11, 23:39)mathu204 Wrote: [ -> ]
I did but i made backups of the files I edited and put them back cause it wasnt working but maybe Ill just fresh install again later.
(2021-01-11, 08:07)AchillesPunks Wrote: [ -> ]adjusted ratings icons a little more.
How did you get the progress bar to show up on your movies widgets?
(2021-01-12, 05:51)mathu204 Wrote: [ -> ] (2021-01-11, 08:07)AchillesPunks Wrote: [ -> ]adjusted ratings icons a little more.
I added in so I could see the progress of the currently watching movies
(2021-01-12, 05:54)AchillesPunks Wrote: [ -> ] (2021-01-12, 05:51)mathu204 Wrote: [ -> ] (2021-01-11, 08:07)AchillesPunks Wrote: [ -> ]adjusted ratings icons a little more.
is it an xml change if so would u mind sharing it?
(2021-01-12, 05:54)mathu204 Wrote: [ -> ] (2021-01-12, 05:54)AchillesPunks Wrote: [ -> ] (2021-01-12, 05:51)mathu204 Wrote: [ -> ]How did you get the progress bar to show up on your movies widgets?
It is but I'm at work till 6am. I can send it to you tomorrow. Just send me your email address
(2021-01-12, 05:56)AchillesPunks Wrote: [ -> ] (2021-01-12, 05:54)mathu204 Wrote: [ -> ][quote="AchillesPunks" pid='3002426' dateline='1610423660']
[/, yes whenever no rush. Thank you in advance
[font][font]Bonjour
J'ai remarqué un bug lors de la lecture des bande-annonce automatique.
Lorsque je vais sur un film la bande annonce ce lance sans problème, mais quand je sélectionne la vidéo qui se trouve à coté la bande annonce ce lance pas.
Une chose que j'ai remarqué c'est quand je sélectionne 2 film à coté la bande annonce se lance bien.
C'est juste que un seule décalage droit ou gauche, la bande annonce se lance pas
Avez vous le même problème
merci pour votre réponse [/font][/font]
(2021-01-12, 06:28)mathu204 Wrote: [ -> ] (2021-01-12, 05:56)AchillesPunks Wrote: [ -> ] (2021-01-12, 05:54)mathu204 Wrote: [ -> ][quote="AchillesPunks" pid='3002426' dateline='1610423660']
I haven't forgotten. I woke up late. I'll send later
(2021-01-12, 23:51)music59940 Wrote: [ -> ]Bonjour
oh un francais, ca fait plaisir
(2021-01-13, 06:30)AchillesPunks Wrote: [ -> ] (2021-01-12, 06:28)mathu204 Wrote: [ -> ] (2021-01-12, 05:56)AchillesPunks Wrote: [ -> ]is it an xml change if so would u mind sharing it?
No problem at all, much appreciated and it’s no rush!! Question though is your library physical media or .strms? Bc I remember Hugo saying something about how the progress worked for you but not for him
