Also, Achilles thank u so much for the movie progress xmls I still haven’t gotten to testing it yet but I appreciate it a lot I will let u know as soon as I implement it and if it works.
I have a question though, since u guys are working on TMDBHelper integration now can you consider adding support for multiple season view in Bingie episodes view with addons? Well really just TMdB Helper but by default it extends to any addon too official or not. Jurialmunkey who made tmdbh, also implemented this in his own skins!
EDIT: Can confirm the xmls work! thank you!!!
(2021-01-13, 19:35)nazim12 Wrote: [ -> ]"4K Ultra HD " Logo appears only when ratings doesn't load in full but when ratings load fully it changed to " Released " ,how to set it on 4K Ultra HD logo permanently ?
Kindly sort it out
see Old boy with Fake Codec ''Ultra HD 4K '' cover , when Ratings wasn't load fully
https://i.postimg.cc/BndgDk97/image.png
after few seconds when all Ratings loaded fully then Fake cover '' Ultra HD 4K '' changed to ''Released''
https://i.postimg.cc/3xcKZjnc/image.png
I want permanently Ultra HD 4K cover for all movies.
(2021-01-14, 10:49)nazim12 Wrote: [ -> ] (2021-01-13, 19:35)nazim12 Wrote: [ -> ]"4K Ultra HD " Logo appears only when ratings doesn't load in full but when ratings load fully it changed to " Released " ,how to set it on 4K Ultra HD logo permanently ?
Any Suggestion ?
And also I want RT,TVDB, Metacritic , Trakt ratings for TV Shows without tvdb scrapper , is there any Universal TV Shows scrapper or similar just like UMS ? right now I am getting imdb , tmdb only ratings for TV Shows .
First of all nothing is perfect in this world.
Second do you use any tool to scrape your media or just rely on Kodi ?
Third how much heartache / headache are you willing to take on ?
If you know the answers then let me share my experiences with you.
Like many others I use a scraping tool to customise all my media. Selecting artwork to custom nfo's .Ember Media Manager is my preferred poisoned chalice ! its the best media manager IMO. However its not perfect YET and Does NOT scrape any ratings ....this feature has been requested and will (hopefully ) be soon available.
I have tried tinymediamanager, mediaelch & recently Media companion 3beta.
Media Companion 3 beta downloads Ratings from MC, TVDB & RT but for me personally its nfo writing seriously messed up my whole library.
So I had to redo my Whole library again using ember.
I guess you can install any or all of them but use only few media files as tests that way you will not screw up your library like I did.
Let me know if I could be of any help.
I recommend Ember... check out the forum thread
here !
Cheers !
(2021-01-14, 21:58)shaktoo Wrote: [ -> ] (2021-01-14, 10:49)nazim12 Wrote: [ -> ] (2021-01-13, 19:35)nazim12 Wrote: [ -> ]"4K Ultra HD " Logo appears only when ratings doesn't load in full but when ratings load fully it changed to " Released " ,how to set it on 4K Ultra HD logo permanently ?
Any Suggestion ?
I recommend Ember... check out the forum thread here !
Cheers !
For me it was the other way around lol Ember Media Manager would not even scan my shows or movies into the program, when in the same format Kodi picked it up fine, I ended up getting and eventually buying Tiny Media Manager, and it picked up my folder instantly and now I have been using that.
If I recall correctly I started using media companion in 2015 or 2016. Thats the time I also dabbled in Media Browser. Things were not working out for me hence I kept looking & eventually found Kodi & Ember. I have been using ember since 2010 & never looked back.
I am very used to Ember , its GUI and I have set it to run as command line auto scraping everything. Only for very few certain tricky media I have to manually edit it otherwise its all automated for me .
I have utmost respect for all the other media managers : tiny/elch & companion. I would urge everyone to try & see whichever is suitable for them.
MC 3 is currently scraping all the ratings that we all need into the nfo. So whoever is using nfo's can right now get all these ratings via MC3.
Hey There.
I find this project here and I did not read anything about the reason to install this?
Can someone explain me the benefits to normal Bingie? THX.
(2021-01-14, 23:31)HushPeter Wrote: [ -> ]Hey There.
More features and gets updates
Hey Acchilies are the footer logos self contained in one XML only? and if so how do i access the images is it a url in the xml for each logo? Id like to make some custom logos myself 1- to test, and maybe if its good show them to u guys too
(2021-01-15, 02:18)mathu204 Wrote: [ -> ]Hey Acchilies are the footer logos self contained in one XML only? and if so how do i access the images is it a url in the xml for each logo? Id like to make some custom logos myself 1- to test, and maybe if its good show them to u guys too
They are inside the xbt file I sent you, and includes footer I sent you.
Any Suggestion ?
Cheers !
I was using tinymanager year ago , will defenetly look in to Ember & MC.
(2021-01-14, 16:28)AchillesPunks Wrote: [ -> ] (2021-01-14, 11:52)Drakens Wrote: [ -> ]hello
can you add the media info "color or not" in the bingie view menu mode please
or tell me which xml file to modify, or which line of code to add look at the screens thank you
add : https://imgur.com/baAFKzs
in : bingie mod view : https://imgur.com/ZF0oLQw
thank you
Look in the includesosd.xml but you will have to search for it.
Thank you I was able to modify as I wanted
(2021-01-14, 22:50)mathu204 Wrote: [ -> ] (2021-01-14, 21:58)shaktoo Wrote: [ -> ] (2021-01-14, 10:49)nazim12 Wrote: [ -> ]Any Suggestion ?
Cheers !
Did you figure out the xbt
(2021-01-15, 22:04)AchillesPunks Wrote: [ -> ] (2021-01-14, 22:50)mathu204 Wrote: [ -> ] (2021-01-14, 21:58)shaktoo Wrote: [ -> ]First of all nothing is perfect in this world.
Cheers !
Im gonna try to give it a shot later today, what can i open that file with? and does it have links to the images? I know how to use photoshop decently so id like to just make pngs and import them basically
(2021-01-15, 22:07)mathu204 Wrote: [ -> ] (2021-01-15, 22:04)AchillesPunks Wrote: [ -> ] (2021-01-14, 22:50)mathu204 Wrote: [ -> ]For me it was the other way around lol Ember Media Manager would not even scan my shows or movies into the program, when in the same format Kodi picked it up fine, I ended up getting and eventually buying Tiny Media Manager, and it picked up my folder instantly and now I have been using that.
You need to download Kodi texture tool.
(2021-01-15, 22:08)AchillesPunks Wrote: [ -> ] (2021-01-15, 22:07)mathu204 Wrote: [ -> ] (2021-01-15, 22:04)AchillesPunks Wrote: [ -> ]Did you figure out the xbt
Alright thank you, I got a question for anyone here that uses TMDBHelper for Library Integration. If you have any shows that are currently airing, when new episodes come out do you manually refresh details for each show when they come out? Is there a way to automate this so when the next episode comes out instead of being blank with just the episode number and no plot, when it gets added to library, the details would refresh
