(2021-01-23, 02:36)AchillesPunks Wrote: [ -> ] (2021-01-23, 02:33)t123thomas Wrote: [ -> ]@AchillesPunks hope all is well and thanks for support of the beautiful skin, recently, emby for Kodi (e4k) has gone through a lot of improvement and the name changed to the addon has cause Titan Bingie skin not to recognized e4k addon.
Please let me know if you wish me to test after you have had the opportunity to add to changes to your skin.
Emby4Kod Repo link
http://embydata.com/downloads/addons/xbm...-next-gen/
E4K group discussion link
https://emby.media/community/index.php?/...0-preview/
Thanks I'll look into this. I wasn't aware of this change.
Thanks for looking into it
Hey Acchiles personally the new Popcorn footer for the classic style doesnt look as good as previously I was gonna use the image from online but it seems u already have that anyway, other than that I think u could make the TMDB background non-transparent which ill do im gonna edit them now, also I believe U removed Hugos Flat colour footer logos in the new update or the one u sent me and its the same as the classic not sure if that was meant to be or not, but if it was the flat color ones were better the flat color ones should be the New ones, and if u disable new footer it should be the old style.
Also can u direct me to which ones the Text Footer, White, Old and New are? Ill name them and say what I think they are rn just correct me
Old Footer
-TMDB - flags/tmdbtp.png
-TVDB - flags/tvdbtrans.png
-Rotten Tomatoes Audience (Fresh) - flags/popcorn.png
-Rotten Tomatoes Audience (Rotten) - flags/popcorn2.png
-Certified Fresh - flags/certified.png
-Critics Fresh - flags/fresh.png
-Critics Rotten - flags/rotten.png
-Metacritic - flags/metacritic.png
-Oscars - (not sure where this one is does it share it with the New one being "oscarnew.png" in bingie folder? bc i was gonna make a realistic looking one for the old footer and a flat colour for the new one but if they share it Ill just go with a flat color edit on "oscarnew")
-IMDB - flags/imdb_logo.png
-IMDBTOP250 - flags/imdb_logo_250.png
New Footer
-TMDB - bingie/tmdb3.png
-TVDB - bingie/tvdb2.png
-Rotten Tomatoes Audience (Fresh) - bingie/audiencefresh.png
-Rotten Tomatoes Audience (Rotten) - bingie/audiencerotten.png
-Certified Fresh - bingie/cf.png
-Critics Fresh - bingie/fresh.png
-Critics Rotten - bingie/rotten.png
-Metacritic - bingie/metacritic2.png
-Oscars - bingie/oscarsnew.png (??)
-IMDB - bingie/imdb2.png
-IMDBTOP250 - bingie/250color.png
White Footer
-TMDB - I couldnt find this in bingie folder except for bingie/tmdb1.png, but I think that is for the text footer unless im wrong, or its the same for white and text. I also did find one in flags/white/ but that confused me bc there are white logos for everything else in bingie/ except for the tmdb in flags/white, and in flags/white there are white logos for everything else too.
-TVDB - Same as above (bingie/tvdb1 but there is a white tvdb in flags/white)
-Rotten Tomatoes Audience (Fresh) - bingie/audiencefreshwhite1.png
-Rotten Tomatoes Audience (Rotten) - bingie/audiencerottenwhite1.png
-Certified Fresh - bingie/cfwhite.png
-Critics Fresh - bingie/whitertcritics.png
-Critics Rotten - bingie/whitertcriticsrotten.png
-Metacritic - (same question as tmdb tvdb)
-Oscars - bingie/oscars1white.png
-IMDB - (same as tmdb and tvdb metacritic)
-IMDBTOP250 - bingie/top250white.png (is this shared with the text footer?)
Text Footer
-TMDB - bingie/tmdb1.png
-TVDB - bingie/tvdb1.png
-Rotten Tomatoes Audience (Fresh) - (shared with white?)
-Rotten Tomatoes Audience (Rotten) - (shared with white?)
-Certified Fresh - (shared with white?)
-Critics Fresh - (shared with white?)
-Critics Rotten - (shared with white?)
-Metacritic - bingie/metacritic1.png
-Oscars - (shared with oscars white I assume?)
-IMDB - bingie/imdb1.png
-IMDBTOP250 - (shared with white?)
(2021-01-23, 04:43)mathu204 Wrote: [ -> ]Hey Acchiles personally the new Popcorn footer for the classic style doesnt look as good as previously I was gonna use the image from online but it seems u already have that anyway, other than that I think u could make the TMDB background non-transparent which ill do im gonna edit them now, also I believe U removed Hugos Flat colour footer logos in the new update or the one u sent me and its the same as the classic not sure if that was meant to be or not, but if it was the flat color ones were better the flat color ones should be the New ones, and if u disable new footer it should be the old style.
Old Footer
New Footer
White Footer
Text Footer
If everyone would like me to change the footer icons back just let me know and I will. I just added these because they are more realistic looking and polished.
So basically if your not sure just edit the size then refresh your skin to see the change. I'll kind of break it down for you on what your looking for.
So whatever your looking for will be labeled down below. The oscars color will be labeled oscarsnew.png inside the bingie folder. I don't have time right this second but I think you already have the idea. The text for white TMDB could just be pulling from somewhere in the skin as just text. Yes there are icons all over right now basically so we don't have to keep decompiling the texture. We just change the label to test the other icon.
This is the new popcorn and the old popcorn
(2021-01-23, 04:58)AchillesPunks Wrote: [ -> ] (2021-01-23, 04:43)mathu204 Wrote: [ -> ]Hey Acchiles personally the new Popcorn footer for the classic style doesnt look as good as previously I was gonna use the image from online but it seems u already have that anyway, other than that I think u could make the TMDB background non-transparent which ill do im gonna edit them now, also I believe U removed Hugos Flat colour footer logos in the new update or the one u sent me and its the same as the classic not sure if that was meant to be or not, but if it was the flat color ones were better the flat color ones should be the New ones, and if u disable new footer it should be the old style.
Old Footer
New Footer
White Footer
Text Footer
Do you know what happened t the New Style Footers? The flat colour ones
(2021-01-23, 06:33)mathu204 Wrote: [ -> ] (2021-01-23, 04:58)AchillesPunks Wrote: [ -> ] (2021-01-23, 04:43)mathu204 Wrote: [ -> ]Hey Acchiles personally the new Popcorn footer for the classic style doesnt look as good as previously I was gonna use the image from online but it seems u already have that anyway, other than that I think u could make the TMDB background non-transparent which ill do im gonna edit them now, also I believe U removed Hugos Flat colour footer logos in the new update or the one u sent me and its the same as the classic not sure if that was meant to be or not, but if it was the flat color ones were better the flat color ones should be the New ones, and if u disable new footer it should be the old style.
Old Footer
New Footer
White Footer
Text Footer
They should still be there but if not just decompile your build.
(2021-01-23, 06:56)mathu204 Wrote: [ -> ] (2021-01-23, 06:43)AchillesPunks Wrote: [ -> ] (2021-01-23, 06:33)mathu204 Wrote: [ -> ]Do you know what happened t the New Style Footers? The flat colour ones
i think u may have mistakenly replaced it in the one u sent me ill check the update
Don't you have your old build
(2021-01-23, 06:59)AchillesPunks Wrote: [ -> ] (2021-01-23, 06:56)mathu204 Wrote: [ -> ] (2021-01-23, 06:43)AchillesPunks Wrote: [ -> ]They should still be there but if not just decompile your build.
yea thats the one i decompiled and recompiled from, but when i did install your textures .xbt my new footer changed to the old one without changing the setting thts why i mentioned it to u
(2021-01-23, 07:01)mathu204 Wrote: [ -> ] (2021-01-23, 06:59)AchillesPunks Wrote: [ -> ] (2021-01-23, 06:56)mathu204 Wrote: [ -> ]i think u may have mistakenly replaced it in the one u sent me ill check the update
I'm not at the computer right now. I'll send it to you later
AchillesPunks Small visual bug in new update. Tvdb icon is not well positioned. It went a little higher and is not aligned with raiting.
AchillesPunks Another visual bug. In the spotlight, the icon for the top 250 and director's chair are not the same color. When I turn on white icon in the settings, one icon is red and the other is white, and vice versa.
And I think the rating icons are too big now. The past ones were too small. I think some medium size would be ideal. But that’s just my opinion, tastes are different.
(2021-01-23, 22:29)matke Wrote: [ -> ]@AchillesPunks Another visual bug. In the spotlight, the icon for the top 250 and director's chair are not the same color. When I turn on white icon in the settings, one icon is red and the other is white, and vice versa.
Screenshot of the issue and the setting please
The issue has been fixed. Redownload from the Github.
(2021-01-23, 10:41)matke Wrote: [ -> ]@AchillesPunks Small visual bug in new update. Tvdb icon is not well positioned. It went a little higher and is not aligned with raiting.
The issue should be fixed. I am unable to get ratings or studio logos for any TV right now. I did adjust the image so I think it should work. Redownload from the Gitbub
