Full Version: Titan BINGIE MOD v1 (UPDATED - 07/24/2020)
(2021-01-24, 21:10)T94afc Wrote: [ -> ]am I missing something? cannot seem to find 'show all widgets (detach from main menu focus) I liked the ability to be able to scroll through all my widgets on the Home Screen without having to go into each section individually, just seemed smoother and less hassle
it used to be under homescreen layout > widgets
It's under home options.
(2021-01-24, 20:55)Reckoner89 Wrote: [ -> ]Is it possible to have the Dolby Atmos/Dolby Vision/HDR badges show like in the Netflix app?
Won't be able check for a while taking care of some other things. I'm about to start testing for SHS matrix.
@Achiless : Well after using kodi 19 matrix for about three days , i am not looking back to 18 anymore , it is fast like crisp , addon work like charm and HDR is amazing , better try to sort thing out of titan bingie mod for kodi 19, it will suite the tempo .
sorry if this has been asked recently but I've looked at the last pages and haven't found it. Will the skin be updated to work with Kodi 19?
i'm trying to figure out how i can use Autowidget with this skin, can someone help me pls?
(2021-01-24, 23:50)nazim12 Wrote: [ -> ]@Achiless : Well after using kodi 19 matrix for about three days , i am not looking back to 18 anymore , it is fast like crisp , addon work like charm and HDR is amazing , better try to sort thing out of titan bingie mod for kodi 19, it will suite the tempo .
+1 Image
(2021-01-25, 18:57)ferdinand Wrote: [ -> ]sorry if this has been asked recently but I've looked at the last pages and haven't found it. Will the skin be updated to work with Kodi 19?
The skin is but not skin helper service. There is another member I talked to yesterday that said he is working on that part.
(2021-01-19, 01:26)cscott1 Wrote: [ -> ]
(2021-01-18, 19:11)nazim12 Wrote: [ -> ]
(2021-01-18, 15:20)cscott1 Wrote: [ -> ]Skin settings/Homescrean layout/Details/untick Show TV Status on Details Row Home & Bingie Views.
Omg, i was thinking it will be long hassle to set ultra hd 4k permanently, but you solved it. Thanks a lot
No problem just giving you the advice Hugo gave me when I had the same problem a few months back.
I was just wondering if you had gotten your IMDb top 250 TV shows to work? I watched a video of you set it up through skin helper widgets. Did you try through smart playlist? If there isn't a smart playlist I'll create one
(2021-01-26, 00:26)AchillesPunks Wrote: [ -> ]
(2021-01-18, 19:11)nazim12 Wrote: [ -> ]Omg, i was thinking it will be long hassle to set ultra hd 4k permanently, but you solved it. Thanks a lot
Yeah they work but I had to start from scratch to finally get there. Ill have to check when I get home from work on the smart playlist but I avoid skin helper as much as I can as it just slows things down.
(2021-01-26, 13:38)cscott1 Wrote: [ -> ]
(2021-01-19, 01:26)cscott1 Wrote: [ -> ]No problem just giving you the advice Hugo gave me when I had the same problem a few months back.
Is there a way to make a next up episodes widget without skinhelper?
(2021-01-26, 14:26)mathu204 Wrote: [ -> ]
(2021-01-26, 00:26)AchillesPunks Wrote: [ -> ]I was just wondering if you had gotten your IMDb top 250 TV shows to work? I watched a video of you set it up through skin helper widgets. Did you try through smart playlist? If there isn't a smart playlist I'll create one
Not sure I dont use that widget I dont like it. My personal preference is to use the in progress tv shows and rename it Continue watching to stay up to date with the shows I am currently watching and to have a proper poster.
(2021-01-26, 15:31)cscott1 Wrote: [ -> ]
(2021-01-26, 13:38)cscott1 Wrote: [ -> ]Yeah they work but I had to start from scratch to finally get there. Ill have to check when I get home from work on the smart playlist but I avoid skin helper as much as I can as it just slows things down.
True but then you never get the progress bar indicator for episodes on the home screen then do you?
(2021-01-26, 15:35)mathu204 Wrote: [ -> ]
(2021-01-26, 14:26)mathu204 Wrote: [ -> ]Is there a way to make a next up episodes widget without skinhelper?
No I watch episodes all the way through so that's not important to me like I said its my personal preference. It's quick and a way to not go through skin helper.
(2021-01-23, 02:36)AchillesPunks Wrote: [ -> ]
(2021-01-23, 02:33)t123thomas Wrote: [ -> ]@AchillesPunks hope all is well and thanks for support of the beautiful skin, recently, emby for Kodi (e4k) has gone through a lot of improvement and the name changed to the addon has cause Titan Bingie skin not to recognized e4k addon.
Please let me know if you wish me to test after you have had the opportunity to add to changes to your skin.
Emby4Kod Repo link
http://embydata.com/downloads/addons/xbm...-next-gen/
E4K group discussion link
https://emby.media/comm?unity/index.php?/topic/90781-embyforkodi-500-preview/
Thanks I'll look into this. I wasn't aware of this change.
Hi Did get a chance to look at this request?
I can't wait for Titan Matrix Skin, once I have tasted the Matrix release version, I don't want to go back to lea, please can we have Matrix Skin.
Thanks for your supports and efforts
