Hi
I thought I would try out this skin but have a couple of questions. I am using Emby on a server to manage my movies/tv shows:
1. How do I get all the rotten tomato, imdb, etc ratings to show up for movies + tv shows? I have entered in my omdb plus tmdb api key in Metadata and Artwork module but I am not getting the ratings like shown on screenshots
2. How do I get the movie/tv show certification to show the BBFC logo? For example i would like to it show the image of rated 18 instead of text. Please note that emby saves the UK certification as GB:12, GB:15, etc. Does this need to be UK:12, UK:15,etc
I am not able to use scrappers like universal movie scrapper since I am using Emby as I am not able to add any sources or change the content.
(2021-02-03, 21:18)geowill76 Wrote: [ -> ]1. How do I get all the rotten tomato, imdb, etc ratings to show up for movies + tv shows? I have entered in my omdb plus tmdb api key in Metadata and Artwork module but I am not getting the ratings like shown on screenshots
Skin use script.skin.helper.service for this.....All info you have in thread
https://forum.kodi.tv/showthread.php?tid=235676
omdb plus tmdb api key need to insert in setings for script.module.metadatautils
(2021-02-03, 21:18)geowill76 Wrote: [ -> ]2. How do I get the movie/tv show certification to show the BBFC logo? For example i would like to it show the image of rated 18 instead of text. Please note that emby saves the UK certification as GB:12, GB:15, etc. Does this need to be UK:12, UK:15,etc
for changing Country need to rename-replace UK: in to GB: in two .xml
IncludesMediaFlags.xml
IncludesBingie.xml
(2021-02-03, 21:56)Angelinas Wrote: [ -> ] (2021-02-03, 21:18)geowill76 Wrote: [ -> ]1. How do I get all the rotten tomato, imdb, etc ratings to show up for movies + tv shows? I have entered in my omdb plus tmdb api key in Metadata and Artwork module but I am not getting the ratings like shown on screenshots
Skin use script.skin.helper.service for this.....All info you have in thread https://forum.kodi.tv/showthread.php?tid=235676
IncludesBingie.xml
I've tested the skin helper service and I'm having a couple errors. Kodi 19
Send me log of error on pm
Hey Acchiles I am not sure what just happened I changed my season view to Big Poster details and all of a sudden my screen went black after locking the view, before locking it was fine and i was in the view. Can you tell me where Kodi stores locked/saved viewtypes so I can just reset it to default? Or another way to do that?
Another question, would u guys consider adding support for Embuary Info script and replacing Extended info with it unless u are still planning on moving forward with TMDBHelper replacing extended info which would still be great
Hi @
AchillesPunks & @
HugoL
Firstly, massive thanks for this awesome skin.
This is almost the perfect skin and I know beauty and perfection is individual, but could you please help me make this skin perfect for me with a few tweaks (or please tell me what to do so I can make changes myself)? ;-)
1. I would like to revert back to the original confluence-style menu homescreen, rather than the Netflix widget style homescreen.
I know I could use original Bingie Mod, but I love the new UK certificate and codecs that are shown in your version!
2. I love the Bingie Poster and Landscape views for Movies, but is it possible to have circular navigation for this?
Many thanks ;-)
Hi There
I'm new to the world of Kodi and have many many sleepless night modifying different skins..this one is by far my favorite..thanks for this mate!!
Just 1 thing troubling me at the moment that I just can't seem to get right.
1. Widgets that are in my hub(I.e TV Shows and Movie hubs) are set to sort alphabetically, and for the life of me I can't seem to find an option to sort widgets to Random . Where can I configure widgets in my hub ?
(2021-02-05, 03:18)Coach007 Wrote: [ -> ]Hi There
create a smart playlist with movie or tvshows and choose "sort by"
(2021-02-04, 00:53)mathu204 Wrote: [ -> ]Hey Acchiles I am not sure what just happened I changed my season view to Big Poster details and all of a sudden my screen went black after locking the view, before locking it was fine and i was in the view. Can you tell me where Kodi stores locked/saved viewtypes so I can just reset it to default? Or another way to do that?
any idea on this? deleting guisettings and the viewtype.db didnt fix it so I think i need to unlock the viewtype not sure where that is in xml form dont want to fresh install lmao
(2021-01-23, 02:36)AchillesPunks Wrote: [ -> ] (2021-01-23, 02:33)t123thomas Wrote: [ -> ]@AchillesPunks hope all is well and thanks for support of the beautiful skin, recently, emby for Kodi (e4k) has gone through a lot of improvement and the name changed to the addon has cause Titan Bingie skin not to recognized e4k addon.
Please let me know if you wish me to test after you have had the opportunity to add to changes to your skin.
Emby4Kod Repo link
http://embydata.com/downloads/addons/xbm...-next-gen/
E4K group discussion link
https://emby.media/community/index.php?/...0-preview/
Thanks I'll look into this. I wasn't aware of this change.
Hi just to circle back on this request have had the time to incorporate the new emby addon into your skin?
I tried to use your skin mod but after switching to it this is what I get:
I used the aeonmq18 skin before.
I installed the skin and all dependencies from the repo and then installed the modded zip file.
If I switch to the normal titan bingie skin it works.
Any idea what could cause this?
Kodi.log has these entries:
2021-02-07 12:58:28.816 T:6124 NOTICE: load skin from: C:\Users\Kodi\AppData\Roaming\Kodi\addons\skin.titan.bingie.mod (version: 1.0.9-mod)
2021-02-07 12:58:29.365 T:6124 ERROR: Window Translator: Can't find window InfoDialog
2021-02-07 12:58:29.378 T:6124 ERROR: unmatched parentheses in string.isempty(skinhelper.autoclosevideoosd))
2021-02-07 12:58:29.826 T:6124 WARNING: Trying to add unsupported control type 1
2021-02-07 12:58:29.842 T:6124 WARNING: Previous line repeats 2 times.
(2021-02-07, 14:02)mind12 Wrote: [ -> ]Hi,
Press esc at least 6 times. see
post 2202
Can anyone help me out here? I keep getting this randomly on Titan Bingie Mod, and switching skins to estuary and back fixes it but I dont want to have to keep doing it, and I also dont want to fresh install as I put in wayyyy too much work on this setup
Edit: Happens everytime on startup
Edit 2: so again changing skins and back fixes it or changing skin, then pressing no. Also just restored from a backup to see if it would fix it but it didnt, however the skin rewrite on the first open fixed it. so writing menu also fixes it if thats of any valuable information
Edit 3: figured it out, enabling login screen in profiles is what caused this not sure why
