(2020-08-14, 11:49)spinecho Wrote: [ -> ] (2020-08-14, 10:26)shkop Wrote: [ -> ] (2020-08-13, 23:40)HugoL Wrote: [ -> ]@shkop I just realised Achilles had the right xml's in there already, you just needed the UK version of the includeshomebingie.xml too. Nevermind, you have the files now.
Anyway, please can you describe the process you used in ember media manager to scrape the ratings to help out @spinecho. Many thanks.
ok I send a message @spinecho
Got your pm...thanks.
I'll give it a try
Can you send the xml please
Updated github with small changes with details and other things. I re-added the BigPanelDetailsview.xml, and Shows only 6 posters with a larger view. I also re-added the Landscapesingle.xml with animated discart and a few other things. I also adjusted the fixed focus moving frames to fit with the new post size.
Fixed Focus Frame
(2020-08-13, 06:12)trkselim Wrote: [ -> ] (2020-08-13, 03:22)AchillesPunks Wrote: [ -> ] (2020-08-13, 02:35)HugoL Wrote: [ -> ]They probably don’t work for him. With this method, you need
1. A prefix of Rated in your scraped MPAA
2. UK ratings.
Number 2 isn’t strictly necessary but it requires more pngs to be added to the MPAA folder and named appropriately, and also a willingness to accept they won’t be entirely accurate depending on what country you selected for your certification when you scraped your library.
I’ve looked at another way that can display your own countries classification logos in that space, providing they’re in the textures folder. Works quite nicely if you like your countries classification logos.
Would love to see what you came up with for the clarifications.
Hi AchillesPunkshi
How to change Ratings And Studio height
In home screen
The height and studio in home have been adjusted now.
(2020-08-14, 15:19)trkselim Wrote: [ -> ] (2020-08-14, 13:39)AchillesPunks Wrote: [ -> ] (2020-08-13, 06:12)trkselim Wrote: [ -> ]Hi AchillesPunkshi
In home screen
Take a look
https://imgur.com/gallery/prq9myn?s=wa
Okay I see. Um not at a computer, but I think it's inside includesbingie.xml. should be labeled in the XML as Studio and Ratings.
In home screen
Take a look
Just add this inside the IncludesBingie.xml and adjust to your liking.
(2020-08-14, 13:12)AchillesPunks Wrote: [ -> ]Updated github with small changes with details and other things. I re-added the BigPanelDetailsview.xml, and Shows only 6 posters with a larger view. I also re-added the Landscapesingle.xml with animated discart and a few other things. I also adjusted the fixed focus moving frames to fit with the new post size.
Fixed Focus Frame
Got a chance to look at the update. There is something in your includesbingie.xml (probably the highlight layout code) causing an issue with 3 rows of widgets showing.
I checked out the panel details view too. Looks really good.
Updated Github to remove all of the Highlight layouts. Everything should work now.
