(2021-03-10, 20:06)Licorne06 Wrote: [ -> ]thanx AchillesPunks xbt ?? sorry i'm french
It's inside the media folder, and you can use Kodi texture tool
(2021-03-05, 16:15)insync44 Wrote: [ -> ]Beautiful Skin always loved it. One point, however. Is it possible to have "INfo" displayed for "Next Episodes Widget"? Titan Mod has it as does Aura Mod.
Not sure what you mean by this. I have never used any other skin except Titan Mod.
(2021-03-07, 21:21)xsynapse_ Wrote: [ -> ]@AchillesPunks
Is there an option to completely disable the netflix intro?
I have multiple intro for the skin. Maybe in the future I will upload them to the GitHub. You would need to change the start up time though.
(2020-08-20, 14:35)nazim12 Wrote: [ -> ]Update : When i use Mix layout of ( Poster & Landscape Widgets ) in Home , by Scrolling down up to last widget row , it look fine at first but when we scrolled up afterward , things get messy . , widgets rows try to merge one another . is there any thought ?
don't see the way to put the WIDGETS in mix mode, I would like to put some widgets in poster view and another strip of WIDGETS in landscape view, can I do that? how would it be done?
Thank you
(2021-03-11, 19:14)nazim12 Wrote: [ -> ] (2021-03-11, 02:23)AchillesPunks Wrote: [ -> ] (2021-03-10, 20:51)matke Wrote: [ -> ]Can you upload on github matrix branch or send me a link so I will try something?
For right now just install Kodi Matrix. Go to the folder that has Titan Bingie Mod and open up the addon.xml with a file editor and change
<import version="5.14.0" addon="xbmc.gui"/> to
<import version="5.15.0" addon="xbmc.gui"/>
now start Kodi and the skin will run for your testing.
Error : The Kodi python version 2.0.1 could not be satisfied . Unable to install by changing version 5.15.0
You were not supposed to be doing a fresh install. Needs to be a dirty install. Kodi needs to be off then change the addon then start Kodi the skin will start. There is going to be broken add-ons.
The skin should already be installed.
I don't know this my end or something need be fixed in the future.i I can change view setting. Example I can't change to bingi episode's.. Also I can't select items from home screen widgets. I don't expect the skin to be working fully. I just want to see if it's just my end or this need to fixed later down the line.
(2021-03-11, 19:23)AchillesPunks Wrote: [ -> ] (2021-03-11, 19:14)nazim12 Wrote: [ -> ] (2021-03-11, 02:23)AchillesPunks Wrote: [ -> ]For right now just install Kodi Matrix. Go to the folder that has Titan Bingie Mod and open up the addon.xml with a file editor and change
The Bingie Mod zip already updated with 5.15.0 version in addon.xml, I am trying to install by zip , What is dirty install?
(2021-03-11, 19:53)nazim12 Wrote: [ -> ] (2021-03-11, 19:23)AchillesPunks Wrote: [ -> ] (2021-03-11, 19:14)nazim12 Wrote: [ -> ]Error : The Kodi python version 2.0.1 could not be satisfied . Unable to install by changing version 5.15.0
You cannot install by zip. The skin needs to be already installed.
(2021-03-11, 20:35)AchillesPunks Wrote: [ -> ] (2021-03-11, 19:53)nazim12 Wrote: [ -> ] (2021-03-11, 19:23)AchillesPunks Wrote: [ -> ]You were not supposed to be doing a fresh install. Needs to be a dirty install. Kodi needs to be off then change the addon then start Kodi the skin will start. There is going to be broken add-ons.
That vary thing I am trying to install. "The Skin"
How it can be already installed?
(2021-03-11, 20:39)nazim12 Wrote: [ -> ] (2021-03-11, 20:35)AchillesPunks Wrote: [ -> ] (2021-03-11, 19:53)nazim12 Wrote: [ -> ]The Bingie Mod zip already updated with 5.15.0 version in addon.xml, I am trying to install by zip , What is dirty install?
Simple. You install the previous version of Kodi. Then you install the skin the same way as always. You edit the theme as instructed then install the latest version of Kodi over the previous version WITHOUT removing anything. Because you did not remove anything this is called a "dirty" installation.
Does that make more sense to you now?
(2021-03-11, 20:43)bornagainpengui Wrote: [ -> ] (2021-03-11, 20:39)nazim12 Wrote: [ -> ] (2021-03-11, 20:35)AchillesPunks Wrote: [ -> ]You cannot install by zip. The skin needs to be already installed.
here is a post i did a few pages back that has a link to kodi 18.9 for android. im sure the other versions can be found as well.
https://forum.kodi.tv/showthread.php?tid...pid3018769
Oh No , Not possible for me going back to 18.9 , It will disturb a lot in Kodi 19 by older version , Kodi 19 need clean install to work everything smooth. Thanks i will wait for Bingie Matrix version
