(2021-03-14, 00:43)AchillesPunks Wrote: [ -> ] (2021-03-13, 14:18)matke Wrote: [ -> ] (2021-03-11, 02:26)AchillesPunks Wrote: [ -> ]What are you trying to achieve?
I'm trying to make this fantastic skin work with matrix. :-) I installed the following addons in this order:
1.https://github.com/kodi-community-addons/script.module.cherrypy
2.https://github.com/kodi-community-addons/script.module.musicbrainz
3.https://github.com/kodi-community-addons/script.module.thetvdb
4.https://github.com/kodi-community-addons/script.module.metadatautils
5.https://github.com/kodi-community-addons/script.skin.helper.service
6.https://github.com/kodi-community-addons/script.skin.helper.widgets
Bingie helper doesn't work. I use tmdb helper and some other addons to watch movies and tv shows online. Everything works very well for now. I keep testing, as long as I have time.
Keep it up. I'm heading to work right now.
Something is wrong. Kodi after some time of use starts crashing with skin. After the netflix loading screen, kodi just crash. I use it on the android box. Sometimes it loads without problems and sometimes it just crash. With leia everything worked perfectly. Log file doesn't display anything.
(2021-03-14, 11:35)matke Wrote: [ -> ] (2021-03-14, 00:43)AchillesPunks Wrote: [ -> ] (2021-03-13, 14:18)matke Wrote: [ -> ]I'm trying to make this fantastic skin work with matrix. :-) I installed the following addons in this order:
This is up to the kodi. With the last nightly version there is no crashes. I have to admit I don’t like the matrix, at least not at the moment. Everything is chopping, I think is not well optimized. At least I have such experiences. Leia works much better. We might have to wait a few versions to sort it out everything.
I'm trying to have Bingie display the banner when playback is paused instead of clearlogo and I've been racking my brain. Everything I try doesn't and currently this is the best I've come up with (which doesn't work too)
Any help would be highly appreciated
AchillesPunks
(2021-03-14, 15:18)matke Wrote: [ -> ] (2021-03-14, 11:35)matke Wrote: [ -> ] (2021-03-14, 00:43)AchillesPunks Wrote: [ -> ]Keep it up. I'm heading to work right now.
I refuse to change until Matrix has everything working. Leia is fine with me. Everything works.
Where did this thread go I cant find it under the Titan subforum anymore and its not even in the archives. I had to go to my profile and go to threads I commented on to find it.
(2021-03-15, 12:44)cscott1 Wrote: [ -> ]Where did this thread go I cant find it under the Titan subforum anymore
The Titan skin is likely in the archive for obvious reasons, so this mod skin becomes a standalone skin.
And please don't plaster your question in more than one place on this forum.
(2021-03-15, 12:56)Klojum Wrote: [ -> ] (2021-03-15, 12:44)cscott1 Wrote: [ -> ]Where did this thread go I cant find it under the Titan subforum anymore
Sorry for the double post just didn't think anyone would see it here because this thread is not archived nor in the stand alone skin section but thanks for the response.
(2021-03-15, 14:13)matke Wrote: [ -> ]@AchillesPunks I set up bingie helper addon to work with the matrix. All you have to do is manually delete the script.bingie.helper folder from C:\Users\(your name)\AppData\Roaming\Kodi\addons. And then just install updated addon from https://github.com/matke-84/script.bingie.helper
It should work. ;-)
I can give it a go maybe Thursday afternoon. I haven't given up on the skin I have been very busy with house remodel and getting the home theater setup. I really do like matrix for the HDR support though.
(2021-03-15, 14:40)AchillesPunks Wrote: [ -> ] (2021-03-15, 14:13)matke Wrote: [ -> ]@AchillesPunks I set up bingie helper addon to work with the matrix. All you have to do is manually delete the script.bingie.helper folder from C:\Users\(your name)\AppData\Roaming\Kodi\addons. And then just install updated addon from https://github.com/matke-84/script.bingie.helper
It should work. ;-)
Ok. When you have a time, try it.
It should work. ;-)
Does that mean that this change makes the whole skin compatible with Matrix ?
I can't wait to try it out on matrix. I stay on matrix because it now is able to play double layer dolby vision
(2021-03-15, 19:19)je1992 Wrote: [ -> ] (2021-03-15, 14:13)matke Wrote: [ -> ]@AchillesPunks I set up bingie helper addon to work with the matrix. All you have to do is manually delete the script.bingie.helper folder from C:\Users\(your name)\AppData\Roaming\Kodi\addons. And then just install updated addon from https://github.com/matke-84/script.bingie.helper
It should work. ;-)
Not yet. There's still work to be done. I try to help as much my time allows. A little patience. Leia is still working well.
(2021-03-14, 15:37)misterkoat Wrote: [ -> ]I'm trying to have Bingie display the banner when playback is paused instead of clearlogo and I've been racking my brain. Everything I try doesn't and currently this is the best I've come up with (which doesn't work too)
@AchillesPunks
Still need help with this.
(2021-03-16, 08:58)misterkoat Wrote: [ -> ] (2021-03-14, 15:37)misterkoat Wrote: [ -> ]I'm trying to have Bingie display the banner when playback is paused instead of clearlogo and I've been racking my brain. Everything I try doesn't and currently this is the best I've come up with (which doesn't work too)
@AchillesPunks
I'm at work until Wednesday. Cannot look until after Wednesday.
I've been playing around with the skin but I can't seem to be able to get the clearlogos. I have installed Artwork Beef. Do I need to do anything else?
