Full Version: Titan BINGIE MOD v1 (UPDATED - 07/24/2020)
(2020-07-24, 01:28)AchillesPunks Wrote: [ -> ]
Titan BINGIE MOD v1.0.3.mod
This is the BINGIE MOD skin of @AchillesPunks, and @Cartman.dos. With this zip we can have both the original BINGIE skin from @Cartman.dos and the BINGIE MOD Skin from @AchillesPunks. Just note apply the NETFLIX COLOR THEME in Settings by @AchillesPunks. enjoy it
Link
First I wanted to Thank @Cartman.dos for creating the backbone for this skin & All users that are helping and contributing to continue this skin mod.
Required Repositories :
- BINGIE Repository: BINGIE Repository is the home of the Bingie skin and all its necessary add-ons.
THIS REPOSITORY IS THE ONLY REPOSITORY YOU NEED IN ORDER TO INSTALL THIS SKIN AND THE MOD ABOVE
Additional Add-ons: (not required)
- Artwork Beef : (Get from Rector Stuff Repository, also available on bingie repo)
- Up Next - is integrated and is used to watch next episode.
- BINGIE Movie Genre Icons - Install and set as resource in general settings to have the green bricks shown in images on genres and category widget.
Note: After you install the REPOSITORY and SKIN from @Cartman.dos Download my Mod from zip above and install.
Everything is perfect for me except I am trying to figure out how to get the plot to show up at the home screen for Next episodes.
(2020-08-17, 16:26)caudibur Wrote: [ -> ]
(2020-08-17, 14:36)nazim12 Wrote: [ -> ]Media Library > Default behavior of cast list > Select Show list of contents in library.   and refresh or restart
Hello, thank ou BUT it didn't change anything (I restarted kodi)   Confused. DO I have to rescrap ?
Check if it may help
https://i.postimg.cc/SQ6bmwLW/image.png
https://i.postimg.cc/h4ybQG0g/image.png
https://i.postimg.cc/QdpTmNcF/image.png
https://i.postimg.cc/N0dLCKFj/image.png
https://i.postimg.cc/66gYq0wt/image.png
(2020-08-17, 20:54)nazim12 Wrote: [ -> ]
Thank you for everything, but it desperately don't work for my fanarts in pannel details views...
https://ibb.co/jD1gzHr
https://ibb.co/k5yg141
And still no clearlogo anywhere...
I really must have forgotten something... (and it's the same behaviour everywhere I installed this mod : my Tablet, my PC, my Shield pro 2019...)
HELP !
REgards.
(2020-07-24, 08:09)AchillesPunks Wrote: [ -> ]Make sure you run Artwork beef and download all fanart. On the view you need to press left hit change view and select episode views. Not sure how it works on UPNP
Great Work OP
I currently use Auramod and I really want to try this skin can someone make a tutorial with one widget (as example) and all setting to achieve best experience (Ratings, network logo, for this skin really appreciate it
I also use Aura Mod sometimes. I find it faster loading & less heavy.
The widgets are very similar in installation OR read this tutorial. Might help.
https://old.reddit.com/r/Addons4Kodi/com..._tutorial/
Just stick with it & experiment. I did a lot of trial & error & adjusted the widgets to suit my needs
Can someone please help me how do I get to have those rounded multi-colored certification ratings?
(2020-08-18, 22:28)ronnel Wrote: [ -> ]Can someone please help me how do I get to have those rounded multi-colored certification ratings?
What country certification do you have and what is your certification prefix?
Is there any way to customize the categorie-hub?
great work,
Joker
(2020-08-19, 03:10)Joker09 Wrote: [ -> ]Is there any way to customize the categorie-hub?
great work,
Joker
Not at this time
(2020-08-19, 02:05)HugoL Wrote: [ -> ]
Country certification is US. The prefix I left it blank as default. By the way, Im using the default kodi TMDB scraper. I didnt touch the default settings either.
(2020-08-19, 07:01)ronnel Wrote: [ -> ]
The rounded icons you're talking about are UK certification icons.  I've set it up so US certification also points to them so you can use them but there's a compromise because you don't have the same ratings as we do. I've had to make a best comparison which will never be entirely accurate.  eg: NC-17 = UK 18 icon.  R rating = UK 15 icon.
If you want to display these icons accurately, you'd really need to re-scrape your certification with UK ratings rather than US.
Anyway, to use them you need to go your xml folder and look for includesbingie(UK).xml and includeshomebingie(UK).xml and rename them to includesbingie.xml and includeshomebingie.xml, overwriting the current ones.
I've also edited another version where you can have your own country icons there (US, UK, Germany, France, Brazil and maybe a few others depending on what was already in the resource pack). US example showed below:
I've sent Achilles the required files already but it's probably not implemented yet.
In your example, i see also all the notes (imdb, rotten tomates, etc...) , the studio logo... And the plot instead of the critics... How do you manage to have that ?
Another question, do you have to choose it via artwork beef the clearlogo or your scraping has done it automatically ? I need to do it manually and it's a pain in the a**. Moreover i don't want to scrap again (it kills all the watched/unwatched tags everytime)...
Can you or someone please explain the differences or changelog between this version and the OG binge view? I am using OG and from what I can see from the posted images all these things are already in bingie view, you just have to toggle them on in settings. (Which I already have) clear logos , studio icons have been toggled on and you added colored icons for ratings? Is there more to this? Because mine looks the same except I still have ratings toggled off because I don't care for them. Thanks in advance.
@AchillesPunks
So I've made some subtle changes to the Spotlight content widget (I'm using the Netflix sans font too which makes a difference)
1. Added back the "Watch Season xx" sublabel
2. Tidied up the plot and button layout, things like buttons that now auto-adjust to plot so there's no inconsistent space between them when plot size changes, increased the text width on button while simultaneously reducing the actual button width, removed text shadow from plot and hardcoded it white for better visibility.
3. Made subtle edits to the diffuse overlay to slightly lighten up corners/edges of fanart image and made it slightly dimmer behind the plot for better plot visibility.
4. Changed the right side MPAA Text sliding animation to an MPAA icon sliding animation instead.
Right side images are the current bingiemod
Let me know if you're interested.
