Full Version: Titan BINGIE MOD v1 (UPDATED - 07/24/2020)
(2020-08-20, 23:14)AchillesPunks Wrote: [ -> ]
(2020-08-20, 13:49)HugoL Wrote: [ -> ]
(2020-08-20, 13:09)AchillesPunks Wrote: [ -> ]Yes another way.
Please can you tell me how? I want to change the poster height back to your edit (before Trkselim reverted the height)
If you make adjustments inside the IncludesHomeWidgets.xml you will need to adjust the Fixed focus navigation factory inside the IncludesBingie.xml to fix the scrolling.
Shoot me a email if I'm not explaining this correct or you need more help. Going to sleep for a little bit but I will reply back.
Example below with the small poster layout.
Let say I have changed Landscape large in Includehomewidget Height 280 , Width 450 but there is no option of Height and width in includebingie just one thing mentioned  Value -300 ?
That’s brilliant thanks. I’ll check it out tomorrow. I’m going to reduce the poster height back to your original change.
(2020-08-20, 23:47)nazim12 Wrote: [ -> ]
(2020-08-20, 13:49)HugoL Wrote: [ -> ]Please can you tell me how? I want to change the poster height back to your edit (before Trkselim reverted the height)
You will need to change the value until the scrolling up and down is staying in position.
(2020-08-20, 23:52)HugoL Wrote: [ -> ]
Would you like me to send you a xml with just the poster changed?
(2020-08-21, 00:35)AchillesPunks Wrote: [ -> ]
(2020-08-20, 23:14)AchillesPunks Wrote: [ -> ]If you make adjustments inside the IncludesHomeWidgets.xml you will need to adjust the Fixed focus navigation factory inside the IncludesBingie.xml to fix the scrolling.
Yeah that’s great thanks!
(2020-08-20, 02:41)AchillesPunks Wrote: [ -> ]Are you talking about the Netflix image or the Netflix mp4 intro?
Hello. Sorry if i'm answering so late. The answer is "Both"....
And by the way would you be kind to explain le the problem with the fanart that doesn't show on the pannel views ? Thank you
(2020-08-21, 00:56)caudibur Wrote: [ -> ]
#1.
You will need to replace the intro mp4 and image inside the extras folder.
#2.
I will need to know what view you are talking about to add the fanart.
(2020-08-21, 00:40)HugoL Wrote: [ -> ]
(2020-08-20, 23:52)HugoL Wrote: [ -> ]That’s brilliant thanks. I’ll check it out tomorrow. I’m going to reduce the poster height back to your original change.
Just sent you a email with the changes needed.
(2020-08-20, 18:58)nazim12 Wrote: [ -> ]
(2020-08-20, 14:46)trkselim Wrote: [ -> ]
(2020-08-20, 14:35)nazim12 Wrote: [ -> ]Update : When i use Mix layout of ( Poster & Landscape Widgets ) in Home , by Scrolling down up to last widget row , it look fine at first but when we scrolled up afterward , things get messy . , widgets rows try to merge one another . is there any thought ?
I just edit Mix layout
https://i.imgur.com/kEc1iZk.mp
Yes that's what i want ? kindly share what you change in xml
Remember i have increased the size of Poster & Logos  which i dont want to compromise .
Send me your email
(2020-08-20, 11:38)HugoL Wrote: [ -> ]
(2020-08-20, 10:43)2bpz Wrote: [ -> ]
(2020-08-19, 16:14)HugoL Wrote: [ -> ]@AchillesPunks
So I've made some subtle changes to the Spotlight content widget (I'm using the Netflix sans font too which makes a difference)
1. Added back the "Watch Season xx" sublabel
2. Tidied up the plot and button layout, things like buttons that now auto-adjust to plot so there's no inconsistent space between them when plot size changes, increased the text width on button while simultaneously reducing the actual button width, removed text shadow from plot and hardcoded it white for better visibility.
3. Made subtle edits to the diffuse overlay to slightly lighten up corners/edges of fanart image and made it slightly dimmer behind the plot for better plot visibility.
4. Changed the right side MPAA Text sliding animation to an MPAA icon sliding animation instead.
Right side images are the current bingiemod
Let me know if you're interested.
This is how mine looks with OG
I have the plot toggled to scrolling so my layout always looks the same regardless of plot size. On places other than spotlight I have toggled episode synopsis to override series plot for all "in progress " shows. I also changed the color of the side blade to a true black which matches better. I changed like 6 things in toggles and changed some colors ie: the buffer color in the progress bar is stock pink and I had to change it to yellow to be able to see the difference between buffer and progress. All in all stock skin allows all these changes but seems to have a steep learning curve. Took me a month of using it to get it truly where I want it. A lot of that time was just going through settings menus and seeing what is available to change.
I'm not keen on autoscroll at all, the only way I can see full plot anywhere in bingie views now is through Plot & Critics - info dialogue screen which I'm happy with.
I'd never go back to OG now.  I don't like the white line going down the menu blade or the menu blade position, don't like the font, don't like the clearlogo size, I really don't like justified text at all, those inconsistent spaces between text really bother me and in general, I didn't like the big square block of text in any of bingie views. And AchillesPunks mod improved a few other things so I was more than happy to switch over and make some minor adjustments.
I also really appreciate the uniformity I've highlighted here:
Right on, I can relate. Different things bothered me alot when I first started using it. I spent 3 days digging through to change the back arrow icon because I leave parent folders turned on.and the big white back areow was driving me cucoo for coco puffs. it's good to see activity in this skin regardless of the changes. I was just really trying to understand the changes made so I can decide when to update.
(2020-08-21, 06:07)trkselim Wrote: [ -> ]
(2020-08-20, 14:46)trkselim Wrote: [ -> ]I just edit Mix layout
Send me your email
email sent .
Tenho um problema, alguém poderia me ajudar.
Toda vez que tento sair de um filme ou série quando estou voltando a telas a seleção fica no botão Continuar ele é acionado mesmo quando o peço para voltar ou seja ele começa a reproduzir novamente o conteúdo tendo que sair de novo.
Existe como solucionar isso?
Outra dúvida, quando eu pause o filme ou serie o OSD aparece o discart tem como aparecer apenas o imagem sem disco?
Vi aqui que tem que alterar algum xml podem me dizer qual?
Desde já agradeço pela atenção.
______________________________
I have a problem, could someone help me. Every time I try to leave a movie or serie when I'm returning to screens the selection is on the Continue button it is activated even when I ask to go back, that is, it starts to play the content again having to leave again. Is there how to solve this?
Another doubt, when I pause the movie or the OSD series appears, does the discart have the image without a disc? I saw here that you have to change some xml can you tell me which one?
I thank you for your attention.
Someone?
(2020-08-21, 10:49)nazim12 Wrote: [ -> ]
(2020-08-20, 18:58)nazim12 Wrote: [ -> ]Yes that's what i want ? kindly share what you change in xml
Send me your email
email sent .
Check your email
(2020-08-21, 01:03)AchillesPunks Wrote: [ -> ]
#1.
#2.
Thank you. You wanted examples of my requests.
First image it's the example of the classifications i would like to delete. It's "classé u" just under the title of the movie
2nd image is the view where the fanarts don't show.here is in the pannel details view...
https://ibb.co/jD1gzHr
https://ibb.co/k5yg141
Thank you so much for your fantastic work.
(2020-08-21, 13:46)trkselim Wrote: [ -> ]
(2020-08-21, 06:07)trkselim Wrote: [ -> ]Send me your email
email sent .
Check your email
I have found it very good ,  smooth vertical scrolling but only thing matter to me second row widgets should be display at least half of it just like Native Netflix app but it look like Aura Mod now. kindly work on that .
Edit : I did something here and there now i could see a little of second row  but not more then this , just look at the pic ( Below second row Science Fiction )
https://i.postimg.cc/zvmCcZpj/image.png
