I would like to point out the second picture. If you look behind the menu you can see the info of the episode. It shows but only with the menu blade pulled up. So it isn't a streaming path. It's local media. The info seems to be there or why else show when I hit the menu key? (or backspace key, either key)
(2021-05-19, 03:19)Littleceezer Wrote: [ -> ]I would like to point out the second picture. If you look behind the menu you can see the info of the episode. It shows but only with the menu blade pulled up. So it isn't a streaming path. It's local media. The info seems to be there or why else show when I hit the menu key? (or backspace key, either key)
I'm at work till 6am but I will need to get more information from you for me to trouble shoot. I'll respond when I'm ready to figure it out.
(2021-05-19, 00:59)AchillesPunks Wrote: [ -> ] (2021-05-19, 00:28)thibaudbrg Wrote: [ -> ] (2021-05-17, 10:30)AchillesPunks Wrote: [ -> ]Yes those images are inside the texture.xbt inside the home folder.
You can just decompile the xbt and recompile it
Thanks, this is exactly what I was looking for.
I have two other small questions that I can't find.
When I'm playing a movie and I pause it, I don't have the buttons at the top left "play", "subtitles" etc... However, in the OSD settings, everything seems to be activated so that it is displayed. I tried to disable/enable everything but without success.
My other question is one that I have seen many times on the forum but I have not found a very clear answer. I don't know how to configure my home menu widgets to have the movie genres but with the images.I have activated the "categories" label and I have the genres but without the covers.
I saw in the forum that I have to go to "Default Widgets" -> "Skin Helper Services Widgets" -> "Movies" -> "Genres" but when I click on "Skin Helper Services Widgets" I get the error: "Extended Info Script Error".
I still imagine that the correct solution comes from the "categories" widget rather than the "Genres" widget in "Skin Helper Services Widgets"?
I saw that the solution may have come from "Select Movie Genre Fanart" and I had to select "Movie Genre Icons - BINGIE" in "General skin settings". I have installed the resource but I don't know how to select it, I don't have an application to select, only a "resource" folder.
Thanks for your help !
Categories widget is the correct method but it is currently not working correctly. Send me a screenshot of the top left for osd. You won't have a play button but should have the other buttons.
Okay so I have nothing to do for the fanarts of categories ?
Here's the picture when I pause a movie with the SPACE key.
and my parameters :
(2021-05-19, 09:20)thibaudbrg Wrote: [ -> ] (2021-05-19, 00:59)AchillesPunks Wrote: [ -> ] (2021-05-19, 00:28)thibaudbrg Wrote: [ -> ]Thanks, this is exactly what I was looking for.
and my parameters :
Try to uncheck show info panel on pause
(2021-05-19, 10:35)AchillesPunks Wrote: [ -> ] (2021-05-19, 09:20)thibaudbrg Wrote: [ -> ] (2021-05-19, 00:59)AchillesPunks Wrote: [ -> ]Categories widget is the correct method but it is currently not working correctly. Send me a screenshot of the top left for osd. You won't have a play button but should have the other buttons.
and my parameters :
It didn't change anything...
Where is located the 4k movies widget? i check in skin helper service widget and not luck!
(2021-05-18, 15:32)AchillesPunks Wrote: [ -> ] (2021-05-18, 15:15)geowill76 Wrote: [ -> ]Hi AchillesPunks
I have been using your skin since day one and love it. However, over the last few days I have ran into issue with UK logos appearing. My UK ratings are saved in nfo files as GB:** so I followed instructions below to have the logos appear
for changing Country need to rename-replace UK: in to GB: in two .xml
IncludesMediaFlags.xml
IncludesBingie.xml
Everything was working fine then I believe a few days ago there were updates to some of the skin helper service programs which I am not sure if they have broken something.
Is there anything I can do to fix problem? Is there anything you need from me to troubleshoot?
I'm actually working on the MPAA ratings right now. I have one more night of work and I can look at this tomorrow if I'm not too tired.
I will need more information from you though. I assume GB is Great Britain. Your MPAA are not the same as UK?
Hi dear
Plz help
Not working on apple tv😩😩
(2021-04-30, 19:59)beatmasterrs Wrote: [ -> ] (2021-04-30, 18:14)Timmyrocks26 Wrote: [ -> ] (2021-04-30, 18:00)AchillesPunks Wrote: [ -> ]Did you try and add any media first? I think @nazim12 mentioned something about this.
Second for this black screen problem on Titan Bingie for Matrix on AppleTV.
I have installed a fresh new copy of Matrix, A fresh new copy of Titan Bingie Matrix. (I had to manually install some of the dependancies to get around the Python 2.24.0 error)
I have added movies and TV Shows. (I can confirm that if I use the iOS kodi remote app I can go right to the TV or Movies Page and see all my entries)
No matter what I do or try I still just get a black Home Screen!?
Please check your settings.xml in userdata/addon_data/skin.titan.bingie.mod folder. Couldt you upload your settings.xml file to a free file hoster and post the link here? In some cases, the problem is with SHS. Then not all required settings are set.
Can i help me
I cant use bingie mod kodi matrix on apple tv 4k
Plz
(2021-04-30, 20:35)beatmasterrs Wrote: [ -> ] (2021-04-30, 20:10)Timmyrocks26 Wrote: [ -> ] (2021-04-30, 19:59)beatmasterrs Wrote: [ -> ]Please check your settings.xml in userdata/addon_data/skin.titan.bingie.mod folder. Couldt you upload your settings.xml file to a free file hoster and post the link here? In some cases, the problem is with SHS. Then not all required settings are set.
Sure can, thanks for the help!
https://www.dropbox.com/s/kxwb1u7cuawxky...s.xml?dl=0
Some strings are not set. That causes the black screen issue. I could reproduce that with your settings.xml. If you like to test with a working xml, please use this one here:
https://drive.google.com/file/d/1xZ02pau...sp=sharing
Note, that you have to close kodi, bevor you can replace the file, cause kodi will overwrite the file itself.
EDIT: this file works also fine for me: https://drive.google.com/file/d/1rItwnQd...sp=sharing
How change settings.xml on apple tv
AchillesPunks Kindly work on Resume Percentage not working issue.
I am doing something wrong?
I loaded up all my files - installed from zip
script.bingie.helper-1.0.0
then
repository.bingie.mod-master
accepted Use skin
Then presented with a black screen
Did forced shutdown, rebooted - everything looked ok then Kodi crashed here is link to log
https://paste.kodi.tv/isurasuhul.kodi
Restarted and if I go directly to Film, TV-Series or Music - no issues, seems to be a problem on home screen
AchillesPunks : Does the skin uses TheMovieDb Helper addon for additional ratings ?
I used Arctic Horizon by Jurialmunkey who also wrote the TheMovieDb Helper & Skin variables scripts. Out of the box without any modification of nfo's or using any specific scraper it pulled additional ratings ( MC/Trakt/RT/Tvdb etc ) and displayed instantaneously.
I went back to TBM and still no Joy Just the imdb & sometimes the tmdb ratings.
So I think TBM is not utilising the "TheMovieDb Helper" script . I think it utilizes the scraped info directly into Kodi library ( As on my Matrix test where I did not use any nfo files & got all artwork from UMS) or maybe via the local nfo ( as scraped by TMM ... Still not available on ember
Another great idea implemented in Arctic Horizon skin (which I had proposed to MiKe Silvo as well but didn't got heard )was to have a button to access Music Video ( Youtube Button )from the Audio source directly .
Could our beloved skin be configured to use these resources ? get additional ratings directly from TheMovieDb Helper / Skin variables ?
Also Is there anyway to have Netflix style Screensaver incorporated . Netflix currently has Fanart / landscape images with logo superimposed & pan scan effect with sound track as screensaver. The multi screensaver addon in kodi does not even come close to it .
(2021-05-19, 20:40)fsurfer Wrote: [ -> ]Hi,
then
accepted Use skin
Did forced shutdown, rebooted - everything looked ok then Kodi crashed here is link to log https://paste.kodi.tv/isurasuhul.kodi
I use the same process and got a black screen as well on home screen. I am not sure whether it has to do with me using an appletv 4k or not. It seems there are some reported issues there but I tried using a different settings.xml with no luck so far. What device are you using?
(2021-05-19, 21:04)pavijan Wrote: [ -> ] (2021-05-19, 20:40)fsurfer Wrote: [ -> ]Hi,
then
accepted Use skin
Win 10 and am using out of the box so too speak
