pavijan I am no coder or AchillesPunk but I looked @ your log ( it really should be a debug log according to team-kodi as
here ) and there are skin helper widget errors. My advice would be delete TBM skin, repo & dependencies ( if necessary delete guisettings.xm from C:\Users\*****\AppData\Roaming\Kodi\userdata\guisettings.xml & from database = found like C:\Users\*******\AppData\Roaming\Kodi\userdata\Database )= textures13.db & occasionally addons27.db from C:\Users\******\AppData\Roaming\Kodi\userdata\Database. This will reset your kodi & disable all your addons. So when you start kodi again it will open in estuary skin. Look @
this post to create an autoexec.py which will auto enable all your addon if you leave this file in userdata folder and restart kodi. Reinstall the latest Leia Skin ( not repo as repo is for matrix Now ). Hopefully you should be all set then.
fsurfer : try & follow the same steps as suggested above.
Please make a backup of your skin to reinstall if there are more issues.
I find Matrix still buggy with loads of crashes due to database / Addons.
(2021-05-19, 21:41)shaktoo Wrote: [ -> ]@pavijan I am no coder or AchillesPunk but I looked @ your log ( it really should be a debug log according to team-kodi as here ) and there are skin helper widget errors. My advice would be delete TBM skin, repo & dependencies ( if necessary delete guisettings.xm from C:\Users\*****\AppData\Roaming\Kodi\userdata\guisettings.xml & from database = found like C:\Users\*******\AppData\Roaming\Kodi\userdata\Database )= textures13.db & occasionally addons27.db from C:\Users\******\AppData\Roaming\Kodi\userdata\Database. This will reset your kodi & disable all your addons. So when you start kodi again it will open in estuary skin. Look @this post to create an autoexec.py which will auto enable all your addon if you leave this file in userdata folder and restart kodi. Reinstall the latest Leia Skin ( not repo as repo is for matrix Now ). Hopefully you should be all set then.
I think you meant to mention @
fsurfer on this reply
(2021-05-19, 21:45)pavijan Wrote: [ -> ] (2021-05-19, 21:41)shaktoo Wrote: [ -> ]@pavijan I am no coder or AchillesPunk but I looked @ your log ( it really should be a debug log according to team-kodi as here ) and there are skin helper widget errors. My advice would be delete TBM skin, repo & dependencies ( if necessary delete guisettings.xm from C:\Users\*****\AppData\Roaming\Kodi\userdata\guisettings.xml & from database = found like C:\Users\*******\AppData\Roaming\Kodi\userdata\Database )= textures13.db & occasionally addons27.db from C:\Users\******\AppData\Roaming\Kodi\userdata\Database. This will reset your kodi & disable all your addons. So when you start kodi again it will open in estuary skin. Look @this post to create an autoexec.py which will auto enable all your addon if you leave this file in userdata folder and restart kodi. Reinstall the latest Leia Skin ( not repo as repo is for matrix Now ). Hopefully you should be all set then.
I think you meant to mention @fsurfer on this reply
I am mapped to: G:\Kodi\portable_data\ does not mention C:\users and I have ERROR: Skin Helper Widgets --> Exception in main ! --> Incorrect widget action or type called
Will wait for AchillesPunks
Ok is it only me here but I've not really noticed how long this has been happening but in spotlight when the trailer is playing, the next trailer name comes up on screen whilst the previous trailer is still playing way before it finishes?
Is there a way of adjusting this to only change when the trailer has come to an end?
I don't know why, when I click on the sub-menus "All Movies" or "Recently Added" etc... I don't have the Bingie interface displayed, but this one.
I have the same problem when I open a saga, or when I do "More Episodes" in a TV Show.
How do I change this setting?
(2021-05-19, 22:13)fsurfer Wrote: [ -> ] (2021-05-19, 21:45)pavijan Wrote: [ -> ] (2021-05-19, 21:41)shaktoo Wrote: [ -> ]@pavijan I am no coder or AchillesPunk but I looked @ your log ( it really should be a debug log according to team-kodi as here ) and there are skin helper widget errors. My advice would be delete TBM skin, repo & dependencies ( if necessary delete guisettings.xm from C:\Users\*****\AppData\Roaming\Kodi\userdata\guisettings.xml & from database = found like C:\Users\*******\AppData\Roaming\Kodi\userdata\Database )= textures13.db & occasionally addons27.db from C:\Users\******\AppData\Roaming\Kodi\userdata\Database. This will reset your kodi & disable all your addons. So when you start kodi again it will open in estuary skin. Look @this post to create an autoexec.py which will auto enable all your addon if you leave this file in userdata folder and restart kodi. Reinstall the latest Leia Skin ( not repo as repo is for matrix Now ). Hopefully you should be all set then.
Thanks for correcting pavijan.
Fsurfer , the path I mentioned was just an example. The error you are experiencing isnt due to any error in the skin itself.
If you are on a portable install then just locate the user_data & addons and delete the skin helper widgets & old settings.
I am trying to help you out. if you dont feel comfortable then thats alright.
good luck.
(2021-05-19, 23:49)DROIDshield Wrote: [ -> ]Ok is it only me here but I've not really noticed how long this has been happening but in spotlight when the trailer is playing, the next trailer name comes up on screen whilst the previous trailer is still playing way before it finishes?
Show a log please.. I can't reproduce the error. I have tried before and don't have issues. This is known issue for only some users.
(2021-05-20, 00:06)thibaudbrg Wrote: [ -> ]I don't know why, when I click on the sub-menus "All Movies" or "Recently Added" etc... I don't have the Bingie interface displayed, but this one.
Press left and change the layout. I know @
matke has been hard at on the views. He has only had one set back and that was me being selfish.. lol
On the oxygen movie (bottom left), there is a certified tomato to the left of IMDB. What does it represent?
(2021-05-20, 00:27)shaktoo Wrote: [ -> ] (2021-05-19, 22:13)fsurfer Wrote: [ -> ] (2021-05-19, 21:45)pavijan Wrote: [ -> ]I think you meant to mention @fsurfer on this reply
good luck.
I have been using Kodi for a few years and without this Mod works perfectly well. So for you to say "The error you are experiencing isnt due to any error in the skin itself." just confuses the matter.
I do not think I am installing the Mod correctly - let's focus on the 'How to's' first.
I have Kodi Leia with Estuary under Win 10 set as portable
