After re-installing older file of TBM , Pop corn rating is working absolutely fine , but latest update removed popcorn rating .
TBM Older one
(2021-06-13, 18:40)nazim12 Wrote: [ -> ]After re-installing older file of TBM , Pop corn rating is working absolutely fine , but latest update removed popcorn rating .
TBM Older one
RT audience was not kicked out of any updates. As far as I can see, you also haven't updated skin helper service, skin helper widgets, metadatutils... You still have a problem with playback progress 0% and that was solved a month ago.
Quote:RT audience was not kicked out of any updates. As far as I can see, you also haven't updated skin helper service, skin helper widgets, metadatutils... You still have a problem with playback progress 0% and that was solved a month ago.
Hi, manually updating from where and isn't the auto-update still being worked upon?
(2021-06-13, 20:55)fsurfer Wrote: [ -> ]Quote:RT audience was not kicked out of any updates. As far as I can see, you also haven't updated skin helper service, skin helper widgets, metadatutils... You still have a problem with playback progress 0% and that was solved a month ago.
If you have our repo installed then you have updates on it that have fixed playback progress (resume).
(2021-06-13, 20:36)matke Wrote: [ -> ] (2021-06-13, 18:40)nazim12 Wrote: [ -> ]After re-installing older file of TBM , Pop corn rating is working absolutely fine , but latest update removed popcorn rating .
TBM Older one
Skin Helper service,Widets,metadatulis should be updated auto as we are are using TBM Repo , RT Audience is enabled , Popcorn Rating is missing in current update but why not in previous one so issue must be in current xml and I also shared Current Aura Mod working all Ratings & Votes with my setup and same setup I am using with TBM . Progress 0% resolved only with Library items not with Addons , It need to address from 1 Year .
(2021-06-13, 21:11)nazim12 Wrote: [ -> ] (2021-06-13, 20:36)matke Wrote: [ -> ] (2021-06-13, 18:40)nazim12 Wrote: [ -> ]After re-installing older file of TBM , Pop corn rating is working absolutely fine , but latest update removed popcorn rating .
TBM Older one
Addons are something else. I'll see for the icon. But for playback progress I'm not sure that anyone will deal with addons that broadcast illegal content. That is the rule here on the forum as i know.
(2021-06-13, 21:28)matke Wrote: [ -> ] (2021-06-13, 21:11)nazim12 Wrote: [ -> ] (2021-06-13, 20:36)matke Wrote: [ -> ]RT audience was not kicked out of any updates. As far as I can see, you also haven't updated skin helper service, skin helper widgets, metadatutils... You still have a problem with playback progress 0% and that was solved a month ago.
Rating are working fine for me as well. It must be the add-on.
Upload your kodi log so I can look at it.
Ratings were there one day and gone the next - deleting simplecach.db didn't help, so what is your secret?
Quote:Upload your kodi log so I can look at it.
I have returned to Estuary
(2021-06-13, 23:27)AchillesPunks Wrote: [ -> ] (2021-06-13, 21:28)matke Wrote: [ -> ] (2021-06-13, 21:11)nazim12 Wrote: [ -> ]Skin Helper service,Widets,metadatulis should be updated auto as we are are using TBM Repo , RT Audience is enabled , Popcorn Rating is missing in current update but why not in previous one so issue must be in current xml and I also shared Current Aura Mod working all Ratings & Votes with my setup and same setup I am using with TBM . Progress 0% resolved only with Library items not with Addons , It need to address from 1 Year .
Everything works for me as well. But I'll check because of addons just in case when I find some time.
Amazon VOD & Netflix are quite legal addons
What I do is add content from these to my Library as .strm's which then gets the local library treatment
BTW Kodi scrapers were / currently have issues with not picking up scraped local nfo's "
See this thread Post 138
Those of us who screape everything using tmm / ember etc just use local scraper and you shall see all ratings
(2021-06-14, 00:31)shaktoo Wrote: [ -> ] (2021-06-13, 21:28)matke Wrote: [ -> ] (2021-06-13, 21:11)nazim12 Wrote: [ -> ]Skin Helper service,Widets,metadatulis should be updated auto as we are are using TBM Repo , RT Audience is enabled , Popcorn Rating is missing in current update but why not in previous one so issue must be in current xml and I also shared Current Aura Mod working all Ratings & Votes with my setup and same setup I am using with TBM . Progress 0% resolved only with Library items not with Addons , It need to address from 1 Year .
BTW Kodi scrapers were / currently have issues with not picking up scraped local nfo's " See this thread Post 138
I didn’t mean of course on these addons. I use tmdb helper myself. I just mentioned that no one is going to deal with addons that they distribute illegal content. And we all know what those addons are.
Yes but same Addons working fine for Ratings with Older TBM,Aura,AZ,AH.
I am also using the tmdb add-on and see no ratings whatsoever. APIs are configured and ratings enabled everywhere I could find, but unfortunately I cannot see them. The only rating I see is the XX% liked. No issues with ratings on add-ons with other skins. Is there anything else I should be checking?
(2021-06-14, 09:30)nazim12 Wrote: [ -> ] (2021-06-13, 23:27)AchillesPunks Wrote: [ -> ] (2021-06-13, 21:28)matke Wrote: [ -> ]Addons are something else. I'll see for the icon. But for playback progress I'm not sure that anyone will deal with addons that broadcast illegal content. That is the rule here on the forum as i know.
You are talking about Leia then. Nothing has changed with the skin maybe skin helper
