(2021-06-17, 22:09)matke Wrote: [ -> ] (2021-06-17, 22:00)nazim12 Wrote: [ -> ] (2021-06-17, 21:49)matke Wrote: [ -> ]It's not missing.
If votes are added, the rating will go from one edge of the screen to the other. and I personally don't like that. If you want to see the number of votes, you can see it through the plot & crtics.
Trakt rating requires the implementation of another addon. I don't know when and if it will be.
Ok let see how possibly is your setup ,
You have source file and you scrape with any software which added all the ratings in nfo and you scrape kodi using nfo or UMS ?
added achiless repo installed Bingie mod ?
added all api keys in metadatautii and load widgets and you got all the Ratings ?
I use local files but many more addons. For local files I use universal movie scraper and for tv shows tmdb tv show scraper.
Yes, I use our repo. https://achillespunks.github.io/reposito...ingie.mod/
Yes, I have my api keys and I use them wherever I need them (metadatautils, UMS...)
I am scrapping (.strm) using Media Companion to create nfo , and scrape library using local nfo.
same repo to installed .
updated api keys .
But yet I don't find Popcorn ratings . only difference is UMS , which I am not using . OK let me use UMS and reply .
(2021-06-17, 22:31)matke Wrote: [ -> ] (2021-06-17, 22:25)AchillesPunks Wrote: [ -> ] (2021-06-17, 22:09)matke Wrote: [ -> ]I use local files but many more addons. For local files I use universal movie scraper and for tv shows tmdb tv show scraper.
I like the views... lol, I know you don't like this.. Picture with the black back panel. lol
Hahaha. Not bad now. I didn't like the one before. But I still prefer more without the back panel.
They all look much better now. I just went through them all. back panel and fanart. I know that was time consuming. I remember when I started added fanart to the views that had them and discart. I gets boring going through each view.
Now if there was a way to auto add animatedfanart instead of selecting each separate. Animatedposter add automatically just fanart doesn't
(2021-06-17, 22:43)matke Wrote: [ -> ] (2021-06-17, 22:33)AchillesPunks Wrote: [ -> ] (2021-06-17, 22:31)matke Wrote: [ -> ]Hahaha. Not bad now. I didn't like the one before. But I still prefer more without the back panel.
I really tried to sort out every view and layout. Each option now works. All margins arranged. I sorted out a lot of icons (I improved their quality as much as I could.). Try to find it? lol I fixed some bugs. I can't even remember what I did. It may not be obvious at first that there are many changes, but believe me, there are a lot of them. You said it right, I almost got burned.
I see all the changed with the info arrangement, icons, fanart, backpanel. It's amazing work, because I know how long it takes.
Appreciate the work you guys put into the latest update. So far so good. I havent lost any ratings and everything seems to have remained the same. Havent really had time to play about with it so i dont know what has changed with this update.
Also thanks for the racoon!
(2021-06-17, 22:53)Giant_Midget Wrote: [ -> ]Appreciate the work you guys put into the latest update. So far so good. I havent lost any ratings and everything seems to have remained the same. Havent really had time to play about with it so i dont know what has changed with this update.
I guess @
matke didn't like my Big Hero 6 icon anymore. lol
(2021-06-17, 22:56)AchillesPunks Wrote: [ -> ] (2021-06-17, 22:53)Giant_Midget Wrote: [ -> ]Appreciate the work you guys put into the latest update. So far so good. I havent lost any ratings and everything seems to have remained the same. Havent really had time to play about with it so i dont know what has changed with this update.
I guess @matke didn't like my Big Hero 6 icon anymore. lol
Ohhh. I think they fit much better with the complete flat design and white color in menu. And I love raccoons.
