(2021-06-24, 14:17)AchillesPunks Wrote: [ -> ] (2021-06-24, 14:15)fsurfer Wrote: [ -> ]Have to say the Addon Artwork Beef is a godsent, its bringing the mod alive adding the titles
To bad it doesn't work for Matrix. I love artwork beef
I use artwork downloader addon from our friend @
Angelinas for local library. It serves me very well. Try it if you haven't already.
https://github.com/Angelinas1/script.artwork.downloader
(2021-06-24, 03:29)AchillesPunks Wrote: [ -> ] (2021-06-23, 22:31)Blackysb Wrote: [ -> ] (2021-06-21, 18:52)fsurfer Wrote: [ -> ]This is an area I am having difficulty with
https://forum.kodi.tv/showthread.php?tid...pid3044712
Clearly im not the only one with the issue. Could someone tell me if this is a skin wide issue or a local one?
Use Bingie episode view for both. I'll remove options to have another view for them.
That's what episode view is for and artwork is made for that view.
Thanks for the reply, I think it's a shame you can't let the end user decide what they want to use but I understand, it's your mod at the end of the day. I do think removing any views that cannot be used is a good idea as it will save any head scratching. I personally like to see the season fanart so I'll move on to another skin. All the best with the skin going forward, I do appreciate all the work that's put in.
(2021-06-24, 15:42)matke Wrote: [ -> ] (2021-06-24, 14:17)AchillesPunks Wrote: [ -> ] (2021-06-24, 14:15)fsurfer Wrote: [ -> ]Have to say the Addon Artwork Beef is a godsent, its bringing the mod alive adding the titles
I use artwork downloader addon from our friend @Angelinas for local library. It serves me very well. Try it if you haven't already.
Someone has also forked artwork beef for matrix already.
artwork dump was the replacement as you know, though its much slower. Someone did fork Artwork Beef to work on 19 though https://github.com/henryjfry/fryhenryj/b...matrix.zip
The guy above me already linked it and i didn't check, my bad
I already have it but it never saves the artwork to my movie folder or to Kodi. It's always having a skin helper error.
(2021-06-24, 17:18)Logs22 Wrote: [ -> ] (2021-06-24, 14:17)AchillesPunks Wrote: [ -> ] (2021-06-24, 14:15)fsurfer Wrote: [ -> ]Have to say the Addon Artwork Beef is a godsent, its bringing the mod alive adding the titles
Artwork Beef works perfect.
(2021-06-24, 12:04)AchillesPunks Wrote: [ -> ] (2021-06-24, 11:16)nazim12 Wrote: [ -> ]As this skin is very similar to Netflix , I would recommend one more up gradation like Netflix , Which has Mix Catalogue of Movies and TV Shows in Widgets in Home Screen. Right now even if i add mix widgets on TBM it will only show Movies or Shows but not Both in same widget.
Also Episode view is working fine with addons showing all kind of artworks.
Similar will show TV and Movies in the same widget.
may be for Library but not for adddons.
(2021-06-24, 19:21)AchillesPunks Wrote: [ -> ] (2021-06-24, 15:42)matke Wrote: [ -> ] (2021-06-24, 14:17)AchillesPunks Wrote: [ -> ]To bad it doesn't work for Matrix. I love artwork beef
A vast majority of the pieces Artwork Beef collects should be collected by TMM, but TMM ignores yet I can enter manually
(2021-06-24, 20:22)fsurfer Wrote: [ -> ] (2021-06-24, 19:21)AchillesPunks Wrote: [ -> ] (2021-06-24, 15:42)matke Wrote: [ -> ]I use artwork downloader addon from our friend @Angelinas for local library. It serves me very well. Try it if you haven't already.
I use tmm as well I really love artwork beef though
Just make sure you add animatedposter to additional artwork types in artwork beef if you have them. Save it to your whitelist
Question on sorting
The normal convention 'The' is ignored and place at end of title
Examples:
Last Ship, The
Man in the High Castle, The
Mist, The
Orville, The
Just realised out of the box the Bingie Mod includes 'The' when sorting
Taking The 100 as an example this series is now grouped with the 'T' The 100 and not # 100,The
I have looked, is there a setting I can change that I missed?
(2021-06-24, 20:06)AchillesPunks Wrote: [ -> ] (2021-06-24, 17:18)Logs22 Wrote: [ -> ] (2021-06-24, 14:17)AchillesPunks Wrote: [ -> ]To bad it doesn't work for Matrix. I love artwork beef
Wait. This version of artwork beef work in a matrix without problems?
(2021-06-24, 20:48)matke Wrote: [ -> ] (2021-06-24, 20:06)AchillesPunks Wrote: [ -> ] (2021-06-24, 17:18)Logs22 Wrote: [ -> ]artwork dump was the replacement as you know, though its much slower. Someone did fork Artwork Beef to work on 19 though https://github.com/henryjfry/fryhenryj/b...matrix.zip
Yes it is great to have it back.
