(2021-06-25, 08:00)fsurfer Wrote: [ -> ] (2021-06-25, 07:16)matke Wrote: [ -> ] (2021-06-24, 20:15)nazim12 Wrote: [ -> ]may be for Library but not for adddons.
That can't be done with addons. You have tmdb helper and in it random lists of movies and tv shows.
On the subject of lists, a basic function is missing - location of source
Check to see if you have this setting turned on... This will remove the "THE" when sorting through your media library.
(2021-06-25, 08:28)fsurfer Wrote: [ -> ] (2021-06-25, 08:20)AchillesPunks Wrote: [ -> ] (2021-06-25, 08:00)fsurfer Wrote: [ -> ]On the subject of lists, a basic function is missing - location of source
Changed settings, exited and restarted, Information does nothing - Kodi is locked
I don't know what to tell you. That's the only way I know how to fix the sorting of your media.
(2021-06-25, 08:36)AchillesPunks Wrote: [ -> ] (2021-06-25, 08:28)fsurfer Wrote: [ -> ] (2021-06-25, 08:20)AchillesPunks Wrote: [ -> ]Check to see if you have this setting turned on... This will remove the "THE" when sorting through your media library.
It must be something I am doing wrong on the install, but it all functions in Estuary - one step forward with this mod and then several steps back
(2021-06-25, 09:16)fsurfer Wrote: [ -> ] (2021-06-25, 08:36)AchillesPunks Wrote: [ -> ] (2021-06-25, 08:28)fsurfer Wrote: [ -> ]Changed settings, exited and restarted, Information does nothing - Kodi is locked
I just checked mine again.. You can see I'm on The Wolfman and it's located in the W section.
(2021-06-25, 11:12)AchillesPunks Wrote: [ -> ] (2021-06-25, 08:28)fsurfer Wrote: [ -> ] (2021-06-25, 08:20)AchillesPunks Wrote: [ -> ]
Are you running it off of emby?
No Embuary its in skin.titan.bingie.mod-leia
Fix works for title order in mod, why does it overwrite core settings?
These are my Estuary settings
[/url]
Will we have a full detailed outline on this forum when Artwork beef is fully sorted out and working with Kodi 19 Matrix?
(2021-06-25, 22:35)DROIDshield Wrote: [ -> ]Will we have a full detailed outline on this forum when Artwork beef is fully sorted out and working with Kodi 19 Matrix?
It already works. Just download it from the post with the link
(2021-06-25, 21:46)AchillesPunks Wrote: [ -> ] (2021-06-25, 12:13)fsurfer Wrote: [ -> ] (2021-06-25, 11:12)AchillesPunks Wrote: [ -> ]Are you running it off of emby?
I don't understand your question.
You asked what I was running it off and I have never used Embuary - there is Embuary xml in your skin.titan.bingie.mod-leia skin I downloaded
Is it possible to replace Netflix logo on home page with custom logo?
(2021-06-26, 12:48)hoskic Wrote: [ -> ]Is it possible to replace Netflix logo on home page with custom logo?
You would need to decompile the texture.xbt and change it to whatever you want.
Achiles How to increase Fix Frame size ?
