Hello,
first I want to thank you for great skin.
Second I have a question. I'm trying to set up a few widgets, but I don't wanna show them all on home screen. It's possible to show some widgets (in my case two) in home screen and some under different menu items?
Example:
Below are my folders in menu and I want to show widget when I point on the menu item.
Home - two widgets with my movies and shows to watch
Movies - two widgets with popular and new movies
Shows - two widgets with popular and new shows
Thank you!
(2021-07-08, 22:35)matke Wrote: [ -> ] (2021-07-08, 22:30)AchillesPunks Wrote: [ -> ] (2021-07-08, 22:27)matke Wrote: [ -> ]It's nice to see you on forum again. Welcome back @HugoL.
Don't let me forget to show what I was working on last night. I think its pretty cool. It has to do with the holidays animation like the snow.
Ok my friend.
Hi dear
Is the black screen problem solved on Apple TV?
(2021-05-17, 10:30)AchillesPunks Wrote: [ -> ] (2021-05-17, 10:26)thibaudbrg Wrote: [ -> ] (2021-05-17, 00:55)AchillesPunks Wrote: [ -> ]I think it's inside the IncludesBingieHome.xml.
There is a button to turn it off in skin settings.
Thanks for your answer, I found these lines in IncludesHomeBingie.xml.
I guess the netflix logo on the bottom right all the time displayed is from the textures "netflix_logo.png" or "netflix_diffuse.png"
But the problem is that I don't have those png's exist anywhere in my folders. I was thinking of replacing these images with the image I want to put instead, but since I can't even find the png....
Yes those images are inside the texture.xbt inside the home folder.
You can just decompile the xbt and recompile it
Hello I was wondering if you had any success with this I decompiled The textures. XBT , Replaced the NetflixLogo.png by opening that file in photoshop and creating a new layer adding my text then deleting the old layer then recompiled. The logo area was blank instead of having the text I replaced it with is there something I'm doing wrong.
(2021-07-13, 02:07)loakkala Wrote: [ -> ] (2021-05-17, 10:30)AchillesPunks Wrote: [ -> ] (2021-05-17, 10:26)thibaudbrg Wrote: [ -> ]Thanks for your answer, I found these lines in IncludesHomeBingie.xml.
It needs to be named the same as the logo you removed.
(2021-07-13, 02:25)AchillesPunks Wrote: [ -> ] (2021-07-13, 02:07)loakkala Wrote: [ -> ] (2021-05-17, 10:30)AchillesPunks Wrote: [ -> ]Yes those images are inside the texture.xbt inside the home folder.
Thank you for the quick reply I did a copy paste of the filename I will try again
(2021-07-13, 02:32)loakkala Wrote: [ -> ] (2021-07-13, 02:25)AchillesPunks Wrote: [ -> ] (2021-07-13, 02:07)loakkala Wrote: [ -> ]Hello I was wondering if you had any success with this I decompiled The textures. XBT , Replaced the NetflixLogo.png by opening that file in photoshop and creating a new layer adding my text then deleting the old layer then recompiled. The logo area was blank instead of having the text I replaced it with is there something I'm doing wrong.
The only way it wouldn't show is if it was named incorrectly or you edited the name or location in the xml.
(2021-06-26, 22:07)tomini Wrote: [ -> ]Hello,
few things do not work for me with this skin, but the most bothersome and annoying is that I can't play videos from some widgets/spotlights or how it's called.
I go from HOME to MOVIES. Recently Added movies - works. Recommended movies - works. Because you've seen (Similar to) - playback failed. My custom widget/spotlight for comedy genre movies has this error as well.
But if I summon context menu on the movie in these bugged widgets and select play -> it plays without an error.
So where is the issue? What logs should I send?
Thanks a lot :-)
EDIT: Even in HOME the Similar to (Because you watched...) doesn't work for movies, but for TV shows it does...but TV Shows are handled differently with this skin, so that's maybe why.
PS: Ratings, ClearLogos and more are not working, too... But that isn't such an issue as previously mentioned bug.
Could somebody please help me out?
Thank you.
(2021-06-16, 16:21)matke Wrote: [ -> ]I just want to explain one thing. Titan bingie mode uses a lot of addons that they use to gather all kinds of information. For example, skin helper service, skin helper widget, metadatautils, various scrapers... skin is here to actually show what addons are collecting as information. Unfortunately if something doesn’t work with these addons then these things happen. What exactly is the reason why everything works for someone and for someone not I really do not know. For example, everything works for me without any major problems, but I don't have anything installed except titan bingie mode and a couple of addons, I don't have any other skins. The Matrix is just at the beginning of its work and there will be a lot of problems until everything stabilizes. Soon, I should have release the update that I owe for some time, but unfortunately I didn't have time to finish it. I will also update all the existing addons that skin uses, so I hope that some problems will be solved without others appearing. AchillesPunks and me really try to keep this skin alive as much as our time and private commitments allow. Thank you for your understanding and patience.
Hi, I honestly think this mod has a mind of its own
(2021-07-13, 22:45)tomini Wrote: [ -> ] (2021-06-26, 22:07)tomini Wrote: [ -> ]Hello,
Thanks a lot :-)
Thank you.
You need to update skin helper service, skin widgets, metadata... Update it from the GitHub. This was fixed long time ago.
(2021-07-13, 05:09)AchillesPunks Wrote: [ -> ] (2021-07-13, 02:32)loakkala Wrote: [ -> ] (2021-07-13, 02:25)AchillesPunks Wrote: [ -> ]It needs to be named the same as the logo you removed.
Thank you for your help and all the work you do on this skin I really appreciate it. everything seems to be working I renamed the files taking extra care to make sure they matched exactly, recompiled and everything looks good.
Now I'm just wondering how I can add custom icons to the set icon list in the edit shortcuts menu 😆 I already replaced the default image icon 😊.
Anyways thank you again have a great day/night
Just curious if there are any plans for or anyone working on the "Titan Tiles" layout for this skin (in Matirx)? Thank you.
(2021-07-15, 16:42)StelioKantos Wrote: [ -> ]Just curious if there are any plans for or anyone working on the "Titan Tiles" layout for this skin (in Matirx)? Thank you.
This skin only has Netflix layout. If you want more layouts you should try Titan Mod. It is actively being worked on by @
Fuchs2468. His repo is posted below.
https://github.com/Fuchs246/repository.f...-1.0.0.zip
AchillesPunks
Is there still a limit on Widget amounts per home section?
(2021-07-16, 21:13)Rijs43 Wrote: [ -> ]@AchillesPunks
You can still have over 40
(2021-07-16, 23:56)AchillesPunks Wrote: [ -> ] (2021-07-16, 21:13)Rijs43 Wrote: [ -> ]@AchillesPunks
Thanks - in settings I see only 8 widgets per home header. How can I enable 40?
