(2021-07-17, 00:12)Rijs43 Wrote: [ -> ] (2021-07-16, 23:56)AchillesPunks Wrote: [ -> ] (2021-07-16, 21:13)Rijs43 Wrote: [ -> ]@AchillesPunks
Is there still a limit on Widget amounts per home section?
You can still have over 40
Thanks - in settings I see only 8 widgets per home header. How can I enable 40?
I don't have time to explain right now but just do a search on our forum to find the answer.
(2021-07-14, 04:51)AchillesPunks Wrote: [ -> ] (2021-07-13, 22:45)tomini Wrote: [ -> ] (2021-06-26, 22:07)tomini Wrote: [ -> ]Hello,
few things do not work for me with this skin, but the most bothersome and annoying is that I can't play videos from some widgets/spotlights or how it's called.
I go from HOME to MOVIES. Recently Added movies - works. Recommended movies - works. Because you've seen (Similar to) - playback failed. My custom widget/spotlight for comedy genre movies has this error as well.
But if I summon context menu on the movie in these bugged widgets and select play -> it plays without an error.
So where is the issue? What logs should I send?
Thanks a lot :-)
EDIT: Even in HOME the Similar to (Because you watched...) doesn't work for movies, but for TV shows it does...but TV Shows are handled differently with this skin, so that's maybe why.
PS: Ratings, ClearLogos and more are not working, too... But that isn't such an issue as previously mentioned bug.
Could somebody please help me out?
Thank you.
You need to update skin helper service, skin widgets, metadata... Update it from the GitHub. This was fixed long time ago.
Can you please post the github links for skin helper service, skin widgets, metadata.. I cant seem to find the right version. Or at least say what the latest version is?
Thank you
(2021-07-17, 02:25)jeelmisc Wrote: [ -> ] (2021-07-14, 04:51)AchillesPunks Wrote: [ -> ] (2021-07-13, 22:45)tomini Wrote: [ -> ]Could somebody please help me out?
Thank you.
Thank you
Here is the Github link to all of them... They are all maintained by @
Angelinas.
https://github.com/kodi-community-addons
(2021-07-17, 05:03)AchillesPunks Wrote: [ -> ] (2021-07-17, 02:25)jeelmisc Wrote: [ -> ] (2021-07-14, 04:51)AchillesPunks Wrote: [ -> ]You need to update skin helper service, skin widgets, metadata... Update it from the GitHub. This was fixed long time ago.
Thank you
Here is the Github link to all of them... They are all maintained by @Angelinas.
Thank you! And thank you for an amazing skin
Thank you
Are these going to be added into the repository at some point so they can be auto updated or will we have to manually update them each time?
(2021-07-17, 06:21)jeelmisc Wrote: [ -> ] (2021-07-17, 05:03)AchillesPunks Wrote: [ -> ] (2021-07-17, 02:25)jeelmisc Wrote: [ -> ]Can you please post the github links for skin helper service, skin widgets, metadata.. I cant seem to find the right version. Or at least say what the latest version is?
Thank you
If you started from scratch with just the repo no skin it will auto update through skin. If you installed the skin then the repo it will not update. The repo should be updated to the latest now.
Thanks a lot :-)
Thank you.
Their official GitHub pages or some fork?
One would think that the newest ones would be on Kodi repositories.
Thank you.
(2021-07-17, 08:48)tomini Wrote: [ -> ] (2021-07-14, 04:51)AchillesPunks Wrote: [ -> ] (2021-07-13, 22:45)tomini Wrote: [ -> ]Could somebody please help me out?
Thank you.
Thank you.
I've already posted the link above. That link is the only available repo for Kodi Matrix.
(2021-07-17, 06:56)AchillesPunks Wrote: [ -> ] (2021-07-17, 06:21)jeelmisc Wrote: [ -> ] (2021-07-17, 05:03)AchillesPunks Wrote: [ -> ]Here is the Github link to all of them... They are all maintained by @Angelinas.
Can I ask why you are posting links, which can be missed - instead of updating page one?
(2021-07-17, 09:33)fsurfer Wrote: [ -> ] (2021-07-17, 06:56)AchillesPunks Wrote: [ -> ] (2021-07-17, 06:21)jeelmisc Wrote: [ -> ]Are these going to be added into the repository at some point so they can be auto updated or will we have to manually update them each time?
Well I haven't checked if we have the latest and I don't feel like taking the time to check and update everything right now.
I installed the skin using the titan bingie mod repo from page 1. Yesterday, I installed skin helper service and metadata util using the the zip manually, I am on version Skin Helper Service (1.1.38), Metadata and Artwork Module (1.0.42). Does that seem right?
What repo do I need to install so they will auto update for me rather than me downloading zip each time and installing. This link
https://github.com/kodi-community-addons has no steps to install this community add on repo.. maybe i am misunderstanding something. Are there steps to install a repo that will update all these depended skin helper addons automatically?
And by the repo you mean the titan bingie mod repo right?
