(2021-07-28, 19:55)fsurfer Wrote: [ -> ] (2021-05-19, 21:45)shaktoo Wrote: [ -> ]@fsurfer : try & follow the same steps as suggested above.
Please make a backup of your skin to reinstall if there are more issues.
I find Matrix still buggy with loads of crashes due to database / Addons.
just adding media to Matrix Estuary, do you think it is wise move or should I remain with Leia?
What progress have you made?
I see so many issues for this mod blamed on Skin Helper, I don't think I will ever use it
I Know I had horrible time early on using TBM Matrix, But Once I migrated I never though about going back to Leia & i would advise you not to as well.
TBM Matrix has been working absolutely amazing for me.
I have Netflix, Disney+,Amazon all enabled AND my own library of strange TV Shows and Movies.
I have 8+ Widget rows of everything you can think of working in perfect harmony with all the logos/ addons working gloriously including Trakt & TMDBH.
How did it happen? I will tell you how I have persevered ;
Through a LOT OF PAIN !
My Son botched the Windows Install and I had to re Install Windows ... And ALL manner of Programe's & settings & tweaks including TMM & Kodi
I had to reinstall Kodi , reinstall mySQL server, redo Library with added bonus of having strm's directly added from the approprate addon's.
I had to completely reset my Trakt account
I had to redo all the tmdbh settings
and Now my Kodi library is synced with Netflix,Amazon Prime & I will be setting up Disney+ as well ( Just got it today )
Even outside of kodi , just on Netflix itself my continue watching gets synced within the netflix addon & through it on the particular netflix widget & Kodi library
The Key to is a proper , Clean & Fresh library.
OR May I be the devil's Advocate & suggest to Ditch the Library altogether ?
Just use the addon's directly using widgets
Properly setting the omdb ( Patreon ) API , fanart API & TVDB & TMDB API's within the Artwork module & addon themselves ... every artwork is pulled properly & displayed .. even when there is no library .
To make this even more awesome then Netflix itself I would request AchillesPunks to consider my suggestions for the further improvements ( Youtube button in Music library to direct to its video )Incorporating Netflix Screensaver & if possible the Top 10 in UK/USA Today .
However There will still be occassional glitches & crashes ..Thats why Estuary is the official Skin used as its the MOST STABLE , BUT Quite Boring !
So with Lots of resolve, hard work & PAIN you should have an enjoyable , satisfying WAF positive expereince .... Just Dont Ask for How Long... as it DOES breakdown & then you have to tinker again. But thats why we all have Kodi.. Tinkering / tweaking ... otherwise I / We would just be happy with Netflix/Prime/Disney and forget about Kodi altogether.
