how do i get spotlight to cycle on Matrix bingie mod? Its stuck on 1 movie...
(2021-08-17, 19:54)je1992 Wrote: [ -> ] (2021-08-17, 13:18)AchillesPunks Wrote: [ -> ] (2021-08-17, 13:11)TheLastOfUs Wrote: [ -> ]Makes sense. Appreciate it. Might I inquire what device you're using it on? Perhaps its a speed issue with the Matrix port? I might test on my 10900K Kodi soon
Running Intel i9 processor, Nvidia 3090 windows pc, and a Intel i7 processor, Nvidia 2010, windows laptop.
I have no speed issues at all.
People won't openly admit it here, But I think the difference in experience here, is that when Bingie Mod feeds on local content, or plex, or emby, it is blazing fast. But those experiencing slow loading, is probably users using Addons that need to fetch lists and media info every single time from online sources.
It's true I only use local content
(2021-08-18, 07:50)TheLastOfUs Wrote: [ -> ]how do i get spotlight to cycle on Matrix bingie mod? Its stuck on 1 movie...
The spotlight doesn't cycle unless you cut off Kodi a few times or watch the movie. You can change the spotlight in skin settings to recommended or custom and make it cycle.
(2021-08-18, 10:46)AchillesPunks Wrote: [ -> ] (2021-08-18, 07:50)TheLastOfUs Wrote: [ -> ]how do i get spotlight to cycle on Matrix bingie mod? Its stuck on 1 movie...
Hi
Where in the skin settings exactly or more specifically how? Its really not obvious. I tried to find it for 2 hours..should be a guide somewhere on that
(2021-08-18, 11:11)TheLastOfUs Wrote: [ -> ] (2021-08-18, 10:46)AchillesPunks Wrote: [ -> ] (2021-08-18, 07:50)TheLastOfUs Wrote: [ -> ]how do i get spotlight to cycle on Matrix bingie mod? Its stuck on 1 movie...
Hi
Very first skin setting that says homescreen layout close to very top. It's labeled pretty clear
About the speed of this skin... I'm using passive cooled Ryzen 3 3200G and it's working great. One exception tho. Every week or so it seems to update ratings or something and that uses 100% CPU wise. It takes between 20 to 30 minutes and then it's all good again. Wish that i could change it to do this less often and with kodi 18 this was less demanding. I could watch movie at the same time but with kodi 19 it uses all CPU power. This is the only performance issue for me with this skin. Working really great otherwise!
(2021-08-18, 18:20)dmlsh Wrote: [ -> ]About the speed of this skin... I'm using passive cooled Ryzen 3 3200G and it's working great. One exception tho. Every week or so it seems to update ratings or something and that uses 100% CPU wise. It takes between 20 to 30 minutes and then it's all good again. Wish that i could change it to do this less often and with kodi 18 this was less demanding. I could watch movie at the same time but with kodi 19 it uses all CPU power. This is the only performance issue for me with this skin. Working really great otherwise!
I can't tell the difference between 18 vs 19. They both keep my CPU around 25% to 30% give or take a little while it updates. Nothing we can do about that. I'm running it on a pretty fast system.
(2021-08-18, 18:43)AchillesPunks Wrote: [ -> ] (2021-08-18, 18:20)dmlsh Wrote: [ -> ]About the speed of this skin... I'm using passive cooled Ryzen 3 3200G and it's working great. One exception tho. Every week or so it seems to update ratings or something and that uses 100% CPU wise. It takes between 20 to 30 minutes and then it's all good again. Wish that i could change it to do this less often and with kodi 18 this was less demanding. I could watch movie at the same time but with kodi 19 it uses all CPU power. This is the only performance issue for me with this skin. Working really great otherwise!
Amazing PC. Can confirm im blind...and it was in the skin settings...thanks!
holy hell thats a nice rig. That is all I have to add to this discussion lmao
Off topic as I doubt the normal user would be this tech-savvy, perhaps this skin should have a 'minimum system requirement' warning
(2021-08-19, 08:36)fsurfer Wrote: [ -> ] (2021-08-18, 18:43)AchillesPunks Wrote: [ -> ] (2021-08-18, 18:20)dmlsh Wrote: [ -> ]About the speed of this skin... I'm using passive cooled Ryzen 3 3200G and it's working great. One exception tho. Every week or so it seems to update ratings or something and that uses 100% CPU wise. It takes between 20 to 30 minutes and then it's all good again. Wish that i could change it to do this less often and with kodi 18 this was less demanding. I could watch movie at the same time but with kodi 19 it uses all CPU power. This is the only performance issue for me with this skin. Working really great otherwise!
Maybe, I know it can run on a i5, i7, & i9. My main everyday laptop is a i7 you can see it on the table.
(2021-08-19, 11:22)AchillesPunks Wrote: [ -> ] (2021-08-19, 08:36)fsurfer Wrote: [ -> ] (2021-08-18, 18:43)AchillesPunks Wrote: [ -> ]I can't tell the difference between 18 vs 19. They both keep my CPU around 25% to 30% give or take a little while it updates. Nothing we can do about that. I'm running it on a pretty fast system.
Thought this was a support thread, not a platform to show your set-up which belongs here
https://forum.kodi.tv/forumdisplay.php?fid=202
(2021-08-19, 11:43)fsurfer Wrote: [ -> ] (2021-08-19, 11:22)AchillesPunks Wrote: [ -> ] (2021-08-19, 08:36)fsurfer Wrote: [ -> ]Off topic as I doubt the normal user would be this tech-savvy, perhaps this skin should have a 'minimum system requirement' warning
Thought this was a support thread, not a platform to show your set-up which belongs here https://forum.kodi.tv/forumdisplay.php?fid=202
No need for that thread. Just showing it can run on multiple system's. If it has lag 80 percent of the time it's how it's set up from the individual.
Hello, for a few days, I cannot add any default widget, since I do not get NONE, I get an error at the top right of the library and something else, it asks me to look at the registry and it is just what I have done but how I have not understood anything I have just taken the text where the registry error is and I have pasted it in a notepad to see if someone can help me to solve it, for me it is WORLD for sure that for you it is NOTHING I hope you will give me one command, THANKS!
https://1drv.ms/t/s!Ahs1hKWR0nmEuAWxmSMW...x?e=xlZama
(2021-08-19, 11:58)AchillesPunks Wrote: [ -> ] (2021-08-19, 11:43)fsurfer Wrote: [ -> ] (2021-08-19, 11:22)AchillesPunks Wrote: [ -> ]Maybe, I know it can run on a i5, i7, & i9. My main everyday laptop is a i7 you can see it on the table.
I disagree, showing a picture of an inanimate object is not answering the question - how many individual tweaks have you made to your Kodi set-up for it to work?
A new user needs to know, does the Titan BINGIE MOD v1 have a minimum system requirement which is highlighted in the majority of skins in the Skin Support forum then they will follow the instructions on page one of this thread!
