(2021-09-04, 05:53)jeelmisc Wrote: [ -> ]Okay Thanks. One last question. On the Home screen, how is Continue watching for You widget configured? What is that pointing too? That takes a good 10 secs to load for me
Continue Watching is just a combination of In-progress playlists for Movies and TV shows which are identical to the default library nodes.
There's nothing preventing you from changing the default playlists selected in the Home widgets section with ones you've created.
For example I've created my own playlist for Blockbuster films using Library tag blockbuster which I've applied to movies that earned more than $150M at the box office - BoxOffice mojo
https://www.boxofficemojo.com/chart/top_...=bo_cso_ac and replaced the default Blockbuster playlist that uses rules based on Rating greater than 6.4 and added in the last 180 days.
(2021-09-05, 02:37)Kokonutcreme Wrote: [ -> ] (2021-09-04, 05:53)jeelmisc Wrote: [ -> ]Okay Thanks. One last question. On the Home screen, how is Continue watching for You widget configured? What is that pointing too? That takes a good 10 secs to load for me
For example I've created my own playlist for Blockbuster films using Library tag blockbuster which I've applied to movies that earned more than $150M at the box office - BoxOffice mojo https://www.boxofficemojo.com/chart/top_...=bo_cso_ac and replaced the default Blockbuster playlist that uses rules based on Rating greater than 6.4 and added in the last 180 days.
Yes but he wants to speed it up with continue watching. That is relying on skin helper widgets. It pulls from continue watching movies and TV shows. It will slow his system.
I have been trying to copy the widgets to different profiles. I created 2/3 different profiles with different Trakt accounts as multiple people use the account to watch movies/shows. Is there a file I could copy over to make the widgets the same? I guessed that you would know more since you developed a lot!
(2021-09-05, 22:23)hasharock Wrote: [ -> ]I have been trying to copy the widgets to different profiles. I created 2/3 different profiles with different Trakt accounts as multiple people use the account to watch movies/shows. Is there a file I could copy over to make the widgets the same? I guessed that you would know more since you developed a lot!
Just wait for the profile stuff. There is about to be a big update.
Hi, Im running an Nvidia Shield and just installed the skin yesterday on Kodi 19.1 for Android TV, works well. Oh and Im using PlexKodiConnect add-on. Although the skin (or some widgets?) is very slow to load at first. I mean when I open the app, its like loading "Genres" and I think it was "Recommended for you" and so on, things on the main screen. Is there a way to make it faster? I would just like to open the Kodi app and see my movies/series pop up, nothing else. As it is with the Plex app
(2021-09-07, 09:58)Tarts5 Wrote: [ -> ]Hi, Im running an Nvidia Shield and just installed the skin yesterday on Kodi 19.1 for Android TV, works well. Oh and Im using PlexKodiConnect add-on. Although the skin (or some widgets?) is very slow to load at first. I mean when I open the app, its like loading "Genres" and I think it was "Recommended for you" and so on, things on the main screen. Is there a way to make it faster? I would just like to open the Kodi app and see my movies/series pop up, nothing else. As it is with the Plex app Thanks.
Widget & Spotlight Content
The widgets and spotlight for Home entry are set from Skin Settings->Configure Shortucts tab->Edit Shortcuts->Widgets for each entry
The spotlight is set from Skin Settings -> Homelayout tab-> Under Spotlight header
For HUBS, both spotlight & widgets are set from the hub's page, for this it should be unlocked first. this is done from Skin Settings->Configure Shortucts tab-> tick off 'Lock Widgets in Hubs', and then go to the hub you want to customize.
You can also have your own Hub or List, from Edit Shortcuts -> Add Shortcut -> in 'Common' directory from pop-up window you will have amongst other the option for 'MyHub' and 'My Custom List' and set them as explained above.
When I try to play trailers I get the YouTube api message although I've scraped my library (TV shows) using the tvdb scraper and set trailers to use tubed. If I switch to an alternative skin these trailers play using tubed but in TBM it always defaults to using the YouTube addon. Is there any way to change this I've looked at the trailer settings and can't seem to get it to change player.
