(2021-10-05, 09:22)AchillesPunks Wrote: [ -> ] (2021-10-05, 09:01)is.manu Wrote: [ -> ] (2021-10-04, 16:02)AchillesPunks Wrote: [ -> ]Did you even try to install this skin? You just copied your post from Titan Bingie and pasted it here.
Hello, yes for sure... as said, my previous post was in the bad thread sorry for that.
So yesterday i ve try another skin and i got the same problem (aeon nox skin)... :
All my menus set with a specif video source (from my synology nas) for each one and a skin layout for eachs, when i navigate in the menus, all these menus keep the last video shortcut path and layout define (from the last menu visited)
I ve formated, re install kodi (Leia in these cases) and always facing the same problem with the both theme (Titan Bingie Mod and Aeon Nox).
I ve tried with NFS source and SMB source and same.
I ve two other raspberry with kodi (Krypton) and no problems at all !
So I don't understand if it's a skin problem or kodi Leia problem (or the famous bug between the chair and the keyboad !!).
regards
manu
You need to uninstall Kodi Leia then install Kodi matrix. Remove your user data and start with a fresh install of Kodi 19.1 Matrix and userdata
thanks for your time and reply,
However for quote me : "I ve formated, re install kodi (Leia in these cases)"
when i install a kodi version that perform a complete format, so it s a fresh install each time
(2021-10-05, 09:50)is.manu Wrote: [ -> ] (2021-10-05, 09:22)AchillesPunks Wrote: [ -> ] (2021-10-05, 09:01)is.manu Wrote: [ -> ]Hello, yes for sure... as said, my previous post was in the bad thread sorry for that.
regards
manu
In reality you will need to only rebuild your configuration once. You can transfer your build to multiple devices if they support kodi 19 once fully configured the way you like. Previous builds not migrating to kodi 19 is a headache for sure but its a necessary one in this case. I am currently rebuilding my library, playlists and configurations whatnot in my spare time. Once you do get it set up on Kodi 19 the way you like it simply copy the addons and userdata folders in the .kodi folder and paste them in the same place on all your devices running Kodi 19 then you will be good to go. Hopefully the migrating issue was due to the change from Python 2 to Python 3 from Kodi 18 to kodi 19 and forthcoming builds wont have the migrating issue but that's just me guessing but keeping my fingers crossed.
(2021-10-05, 12:53)cscott1 Wrote: [ -> ] (2021-10-05, 09:50)is.manu Wrote: [ -> ] (2021-10-05, 09:22)AchillesPunks Wrote: [ -> ]You need to uninstall Kodi Leia then install Kodi matrix. Remove your user data and start with a fresh install of Kodi 19.1 Matrix and userdata
thanks for your help.
At noon i perform different tests:
1) reset the kodi to the factory: same issu...
2) i ve formated (again) my sdcard, re install a fresh kodi leia dist and the same issues with the shortcuts: they loose all the setting (source path and skin layout) when you navigate in the menus. It's the openelec dist.
Possible way:
1) issue in the openelec dist?
2) issue in the skin with Python2/3
My love go to an issue with Python, because i ve five menus.
I set all of them with a different source path and layout.
Sometime three of them are good, sudently one menu start to mess up and get the source path and skin layout of another menu, and these menus are mess up for life
There is no way to fix these menus that was mess up.
So i ve re-formated and installed matrix on xbian, but no enougth time for test at noon, i had to go to work
lol
I will test this evening and report to you.
(2021-10-05, 16:27)is.manu Wrote: [ -> ] (2021-10-05, 12:53)cscott1 Wrote: [ -> ] (2021-10-05, 09:50)is.manu Wrote: [ -> ]thanks for your time and reply,
Possible way:
Sometime three of them are good, sudently one menu start to mess up and get the source path and skin layout of another menu, and these menus are mess up for life There is no way to fix these menus that was mess up.
So i ve re-formated and installed matrix on xbian, but no enougth time for test at noon, i had to go to work lol
So, all is fine and fixed with Kodi 19 Matrix.
The Leia version on libreelec has an issue...
(2021-10-05, 22:27)is.manu Wrote: [ -> ] (2021-10-05, 16:27)is.manu Wrote: [ -> ] (2021-10-05, 12:53)cscott1 Wrote: [ -> ]In reality you will need to only rebuild your configuration once. You can transfer your build to multiple devices if they support kodi 19 once fully configured the way you like. Previous builds not migrating to kodi 19 is a headache for sure but its a necessary one in this case. I am currently rebuilding my library, playlists and configurations whatnot in my spare time. Once you do get it set up on Kodi 19 the way you like it simply copy the addons and userdata folders in the .kodi folder and paste them in the same place on all your devices running Kodi 19 then you will be good to go. Hopefully the migrating issue was due to the change from Python 2 to Python 3 from Kodi 18 to kodi 19 and forthcoming builds wont have the migrating issue but that's just me guessing but keeping my fingers crossed.
Possible way:
No Leia works just fine your just installing the wrong files. You had Leia installed and tried installing Kodi matrix files.
(2021-10-05, 23:21)AchillesPunks Wrote: [ -> ] (2021-10-05, 22:27)is.manu Wrote: [ -> ] (2021-10-05, 16:27)is.manu Wrote: [ -> ]thanks for your help.
Possible way:
Hmm.. no at all.
I ve installed aeon Nox from Leia repository and got the sqme issue.
First of all, I want to thank all the people who have made this Skin possible and work for this long. Off the top of my head I know @
cartman.dos and @
AchillesPunks have put a lot of energy into this. Since I'm someone who likes accesibility a lot, I couldn't help but make some changes to some parts of the skin. I thought I would share them with y'all and if anyone is interested in them I'd be happy to guide them along.
1. If you're someone who uses this MusicOSD, I have added the song's album in the osd, times and next track which is always visible.
2. If you use Bingie episodes, I've added Studio Logo, Binge time for a season or whole show, and Next Episodes. I've also added finish time for any episode. I tried to do it in a way the time shows end time considering the episodes before it but this was the best I could do. If anyone knows how to do it, please help out or if it's because it's not possible, Kodi should consider adding tags for the same in the next versions.
Kodi 18.9 Leia.
As per the instructions in the
first post:
1) I added the CartmanDos repo as a new source. (
https://cartmandos.github.io/repository....ry.bingie/ )
2) Downloaded the Titan Bingie Mod Leia skin (
https://github.com/AchillesPunks/skin.ti...s/leia.zip )
3) Did an install from zip file on skin.titan.bingie.mod-leia.zip (35.3 MB).
Result:
Quote:Failed to install Add-on from zip file.
The dependency on xbmc.python version 3.0.0 could not be satisfied.
Exiting and starting Kodi did not help. Neither did a shutdown and boot of the HTPC.
I've seen the other posts with the similar/reversed error for Python version 2.24.0, but they are all for Kodi 19 Matrix.
Guys the update is coming soon.
(2021-10-07, 03:07)AchillesPunks Wrote: [ -> ]Guy the update is coming soon.
Wooooow. I'm so excited. I can't wait. lol
(2021-10-07, 02:16)AchillesPunks Wrote: [ -> ] (2021-10-06, 19:15)Up Next ..... Wrote: [ -> ]Kodi 18.9 Leia.
As per the instructions in the first post:
1) I added the CartmanDos repo as a new source. ( https://cartmandos.github.io/repository....ry.bingie/ )
2) Downloaded the Titan Bingie Mod Leia skin ( https://github.com/AchillesPunks/skin.ti...s/leia.zip )
Result:
If you are installing it for Kodi Leia just install Cartmon.dos Repo and download Kodi Leia Titan Bingie Mod skin only... Thats it..
Kodi 18.9 Leia
1. https://cartmandos.github.io/repository....ry.bingie/
2. https://github.com/AchillesPunks/skin.ti...s/leia.zip
If you are installing if for Kodi Matrix Just install our repo thats all that is needed..... If installing on Matrix this must be a fresh install you cannot upgrade from Kodi 18 to Kodi 19.
Kodi 19.1 Matrix
1. https://achillespunks.github.io/reposito...ingie.mod/
I did the usual steps for Kodi 18.9 Leia.
1) I added
https://cartmandos.github.io/repository....ry.bingie/ as a Source in Files.
2) Then installed repository,bingie-1.0.2.zip with Install from zip file, from the newly created source in step 1).
3) I downloaded file skin.titan.bingie.mod-leia.zip from
4) Then installed this skin with Install from zip file by browsing to file skin.titan.bingie.mod-leia.zip in the Downloads folder. But the installation fails with the error message i quoted before.
Just repeated the whole procedure all over again (after first uninstalling the CartmanDos repo, and then exiting and starting Kodi). Same error message.
