helllo anybody say how to chage rated on start movie to other text please. i change it on all plugins but do nothing
I can't change the menu item's icon's on the vero4k using the latest version, Kodi 19.
I edit it in the menu but still empty after the skin reloads. I browse it from the skin's custom images folder.
Where is it referenced in the config file? Can I change it in another way somehow?
Hello,
when I try to install the Skin on Vero4k+ matrix, there is some error and unsatisfied dependencies. Here are the kodi logs:
2021-10-21 19:16:26.420 T:2579 INFO <general>: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
2021-10-21 19:16:26.830 T:2579 ERROR <general>: Add-on 'script.module.cherrypy' is not compatible with Kodi
2021-10-21 19:16:26.831 T:2579 ERROR <general>: Add-on 'script.module.musicbrainz' is not compatible with Kodi
2021-10-21 19:16:26.831 T:2579 ERROR <general>: Add-on 'script.module.thetvdb' is not compatible with Kodi
2021-10-21 19:16:26.832 T:2579 ERROR <general>: Add-on 'script.module.beautifulsoup' is not compatible with Kodi
2021-10-21 19:16:26.833 T:2579 ERROR <general>: Add-on 'script.module.metadatautils' is not compatible with Kodi
2021-10-21 19:16:26.834 T:2579 ERROR <general>: Add-on 'script.skin.helper.service' is not compatible with Kodi
2021-10-21 19:16:26.835 T:2579 ERROR <general>: CAddonInstallJob[skin.titan.bingie.mod]: La dépendance de xbmc.python version 2.13.0 n'a pas pu être satisfaite.# english: the dependency of xbmc.python 2.13.0 could not be satisfied
2021-10-21 19:16:26.839 T:2579 INFO <general>: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
2021-10-21 19:16:33.644 T:2579 INFO <general>: Unloaded skin
Does someone have an advice ?
(2021-10-21, 19:25)yoyo2000 Wrote: [ -> ]Hello,
Did you upgrade from Kodi 18 to Kodi on 19? It must be a fresh install. You can not upgrade from Kodi 18
(2021-10-21, 21:25)AchillesPunks Wrote: [ -> ] (2021-10-21, 19:25)yoyo2000 Wrote: [ -> ]Hello,
Thank you for your answer.
Yes I did.
Ok, i will see if I can do a fresh install on this device. Im not sure how to do it anyway as it cames with OSMC kodi18 preinstalled. I will try to find a matrix disk image for it and will try to boot on it.
Currently the my list feature isn´t working, right?
(2021-10-21, 21:42)yoyo2000 Wrote: [ -> ] (2021-10-21, 21:25)AchillesPunks Wrote: [ -> ] (2021-10-21, 19:25)yoyo2000 Wrote: [ -> ]Hello,
Yes I did.
Just make sure there is no Kodi 18 file's before installing
(2021-10-22, 02:49)Joker09 Wrote: [ -> ]Currently the my list feature isn´t working, right?
That is going to be fixed on the update.
Yes I did.
Its easy and it will work with a fresh install. I did the same on my vero4k+. You just need an USB drive prepared on another machine.
(2021-10-22, 09:54)mind12 Wrote: [ -> ] (2021-10-21, 21:42)yoyo2000 Wrote: [ -> ] (2021-10-21, 21:25)AchillesPunks Wrote: [ -> ]Did you upgrade from Kodi 18 to Kodi on 19? It must be a fresh install. You can not upgrade from Kodi 18
Yes I did.
thank you, I just did it with the last disk image, installed the skin and now its is working fine
Hello,
Everything looking good since I did a fresh install, except this:
I have no OSD buttons when I press OK during video playback. I tried to modify the OSD button settings via the Show/Hide OSD Buttons in the skin settings without success. The OSD buttons are displaying fine with others skins.
And I have a question about the "recently added" widget, it actually shows several episodes of the same TV show, is there a way to have the TV show to appear only one time ? I tried to set up the media settings --> videos --> Library --> flattern hierachy to on and flattern TV show seasons to always in Kodi settings but without success.
Thank you by advance.
(2021-10-23, 19:26)yoyo2000 Wrote: [ -> ]Hello,
Look for the answer in the post it's been answered.
(2021-10-23, 23:12)AchillesPunks Wrote: [ -> ] (2021-10-23, 19:26)yoyo2000 Wrote: [ -> ]Hello,
Hi, AchillesPunks, this is about OSD buttons ?
(2021-10-24, 03:49)yoyo2000 Wrote: [ -> ] (2021-10-23, 23:12)AchillesPunks Wrote: [ -> ] (2021-10-23, 19:26)yoyo2000 Wrote: [ -> ]Hello,
About the TV episodes in recently added. I don't remember what the setting says but I just answered it for another person like 2 weeks ago.
(2021-10-24, 05:02)AchillesPunks Wrote: [ -> ] (2021-10-24, 03:49)yoyo2000 Wrote: [ -> ] (2021-10-23, 23:12)AchillesPunks Wrote: [ -> ]Look for the answer in the post it's been answered.
I was struggling with the same and I saw you answer two weeks ago. It was a "look for a kodi setting", nothing specific. I did not find it.
