(2021-10-30, 15:56)Test24 Wrote: [ -> ] (2021-10-30, 15:35)geowill76 Wrote: [ -> ]Hi guys
Just powered up my Kodi system and noticed that I have been updated to version 2.0.2. However, with this new update there seems to be a problem with the Enable UK Icons for the homescreen layout. All my movies and tv shows that have a UK parental rating of 12A are showing icons for both 12 and 12A on the screen. If I disable the option "Enable UK Icons" the items affected on show the text entry showing 12A, which shows that Kodi is picking up the correct parental rating I am not sure why the system is now showing two icons (12A + 12) which it didn't do when i was on version 2.0.1.
Other that the above problem everything else is running great with this update. Love this skin, it is the only one I use.
It s the same with popcorn
What about popcorn? You have to turn on ratings. Take a look at the forum a bit before you ask a question. It has been answered several times.
(2021-10-30, 18:19)matke Wrote: [ -> ] (2021-10-30, 15:56)Test24 Wrote: [ -> ] (2021-10-30, 15:35)geowill76 Wrote: [ -> ]Hi guys
I use m'y 2.0.1 settings and don t work on 2.0.2
(2021-10-30, 18:17)matke Wrote: [ -> ] (2021-10-30, 15:35)geowill76 Wrote: [ -> ]Hi guys
This is very strange. I don't know why you get two ratings. Are you using some addon or a local library? Are you in the kodi setting set us or uk region? I've tried uk ratings now and I don't have that problem.
The USA MPAA do the same thing. They show two MPAA now. Get Metadata Editor and update the ratings it will fix the issue.
(2021-10-30, 22:44)AchillesPunks Wrote: [ -> ] (2021-10-30, 22:36)Test24 Wrote: [ -> ]2.0.2
2.0.1
same settings
What is your issue
The problem is he doesn't read the forum. The problem is he doesn't listen to what I tell him. The problem is that he doesn't want to look at the options ......
2.0.1
same settings
What is your issue
No movie informations ,no popcorn and no french remaining
I have this in the.old version
(2021-10-30, 22:55)Test24 Wrote: [ -> ] (2021-10-30, 22:44)AchillesPunks Wrote: [ -> ] (2021-10-30, 22:36)Test24 Wrote: [ -> ]2.0.2
2.0.1
same settings
What is your issue
Did you enable footer options in the settings?
(2021-10-30, 22:57)AchillesPunks Wrote: [ -> ] (2021-10-30, 22:55)Test24 Wrote: [ -> ] (2021-10-30, 22:44)AchillesPunks Wrote: [ -> ]What is your issue
yes and it's the same with a fresh install
and for pourcent view this option is reversed in settings
(2021-10-30, 23:22)Test24 Wrote: [ -> ] (2021-10-30, 22:57)AchillesPunks Wrote: [ -> ] (2021-10-30, 22:55)Test24 Wrote: [ -> ]No movie informations ,no popcorn and no french remaining
So you uninstalled Kodi and all user folders.
Take a screenshot of the footer turned on and we can go from there. Screenshot first.
mist in french language
msgctxt "#31059"
msgid "remaining"
msgstr "Restant"
and
% Match but I don't found it
(2021-10-30, 23:41)Test24 Wrote: [ -> ]
That's not the setting. I need to see the one for home. You need to enable footer on home
(2021-10-30, 23:52)Test24 Wrote: [ -> ] (2021-10-30, 23:45)AchillesPunks Wrote: [ -> ] (2021-10-30, 23:41)Test24 Wrote: [ -> ]
Have you entered the API keys in Metadata
