I have match in text
if I enable this
no change to popcorn but it's ok on 2.0.1
(2021-10-31, 00:00)Test24 Wrote: [ -> ]I have match in text
if I enable this
Did you enter your API keys?
(2021-10-31, 00:15)Test24 Wrote: [ -> ]my tmdb api key ?
your going to need a omdb key
(2021-10-30, 22:44)AchillesPunks Wrote: [ -> ] (2021-10-30, 22:36)Test24 Wrote: [ -> ]2.0.2
2.0.1
same settings
What is your issue
v2.0.2 doesnt have the percent remaining on the poster anymore. I't s shows at top
i don't do that in 2.0.1
I generete apikey omdb but it done nothing more
it's on a fresh install of kodi 19.3 with remove old settings
(2021-10-31, 00:28)Test24 Wrote: [ -> ]i don't do that in 2.0.1
is your content local on HDD or strm
Man, are you kidding us? Turn off the option in the settings continue watching and you will get a notification on the poster. Play a little with the skin. There are so many options. Investigate a little. You started spamming.
(2021-10-30, 18:17)matke Wrote: [ -> ] (2021-10-30, 15:35)geowill76 Wrote: [ -> ]Hi guys
Just powered up my Kodi system and noticed that I have been updated to version 2.0.2. However, with this new update there seems to be a problem with the Enable UK Icons for the homescreen layout. All my movies and tv shows that have a UK parental rating of 12A are showing icons for both 12 and 12A on the screen. If I disable the option "Enable UK Icons" the items affected on show the text entry showing 12A, which shows that Kodi is picking up the correct parental rating I am not sure why the system is now showing two icons (12A + 12) which it didn't do when i was on version 2.0.1.
Other that the above problem everything else is running great with this update. Love this skin, it is the only one I use.
This is very strange. I don't know why you get two ratings. Are you using some addon or a local library? Are you in the kodi setting set us or uk region? I've tried uk ratings now and I don't have that problem.
Hi Matke
Only addon I am using is Emby for Kodi as all my Movies and TV Shows are stored on a server running Emby. It is only happening for that particular parental rating. My region is set for UK. Emby already scrapes all the movie info and pulls the rating in as GB-U, GB-PG, GB-12, GB-12A, etc. All the other ratings display without any issue. U shows as U, PG shows as PG, 12 shows as 12, etc. The only rating I have issue with is 12A, where it shows 12A plus 12. Only started happening after the upgrade.
(2021-10-30, 22:14)AchillesPunks Wrote: [ -> ] (2021-10-30, 18:17)matke Wrote: [ -> ] (2021-10-30, 15:35)geowill76 Wrote: [ -> ]Hi guys
The USA MPAA do the same thing. They show two MPAA now. Get Metadata Editor and update the ratings it will fix the issue.
Hi AchillesPunk
Just saw your response. When you say get Metadata Editor and update the ratings - what do you mean? Is MetaData Editor an addon or standalone program? Do I have to manually edit the movies/tv shows that have the issue showing the two MPAA ratings? All my Metadata comes from my Emby server, where it scrapes the info and stores it in an nfo file. Does this mean I should edit all the movies/tv shows that have a parental rating of 12A and change them to something else?
(2021-10-31, 02:10)geowill76 Wrote: [ -> ] (2021-10-30, 22:14)AchillesPunks Wrote: [ -> ] (2021-10-30, 18:17)matke Wrote: [ -> ]This is very strange. I don't know why you get two ratings. Are you using some addon or a local library? Are you in the kodi setting set us or uk region? I've tried uk ratings now and I don't have that problem.
Hi AchillesPunk
Metadata Editor is a standalone program just download thru Kodi. Only update the ratings that are messed up. Or update them all
(2021-10-31, 02:06)geowill76 Wrote: [ -> ] (2021-10-30, 18:17)matke Wrote: [ -> ] (2021-10-30, 15:35)geowill76 Wrote: [ -> ]Hi guys
Hi Matke
Mine shows PG-13 in two different colors until I update.
Could someone tell me is there away I can edit the skin helper service so that I can point menus like Bindge worthy... to a different folder or do I just have to live with where the helper pulls it's information from as going into configure there are no settings to change in there?
Hi Matke
I think I know why is that hapening with 12a. In code in some places standing contains. When standing contains, code see 12 in both ratings 12 and 12a. The same thing is with pg and pg-13. I'll switch to equals so I think that will solve the problem.
Hi, I would like to create a second Movie Shortcut in the Home Menu for all my DOK Movies. Is it possible to do this with the same Movie Icon you use in the home menu? When I create a new Shortcut (Edit menu shortcuts) I don‘t find the Icons in „Set Icon“.
Thank you so much for your great work!
