(2021-10-31, 10:34)nilobar Wrote: [ -> ]Hi, I would like to create a second Movie Shortcut in the Home Menu for all my DOK Movies. Is it possible to do this with the same Movie Icon you use in the home menu? When I create a new Shortcut (Edit menu shortcuts) I don‘t find the Icons in „Set Icon“.
Thank you so much for your great work!
Try to select a movie shortcut from common menu and then edit it as you wish.
(2021-10-31, 10:33)matke Wrote: [ -> ] (2021-10-31, 02:06)geowill76 Wrote: [ -> ] (2021-10-30, 18:17)matke Wrote: [ -> ]This is very strange. I don't know why you get two ratings. Are you using some addon or a local library? Are you in the kodi setting set us or uk region? I've tried uk ratings now and I don't have that problem.
Hi Matke
Only addon I am using is Emby for Kodi as all my Movies and TV Shows are stored on a server running Emby. It is only happening for that particular parental rating. My region is set for UK. Emby already scrapes all the movie info and pulls the rating in as GB-U, GB-PG, GB-12, GB-12A, etc. All the other ratings display without any issue. U shows as U, PG shows as PG, 12 shows as 12, etc. The only rating I have issue with is 12A, where it shows 12A plus 12. Only started happening after the upgrade.
I think I know why is that hapening with 12a. In code in some places standing contains. When standing contains, code see 12 in both ratings 12 and 12a. The same thing is with pg and pg-13. I'll switch to equals so I think that will solve the problem.
Hi Matke
Thanks for looking into this. Does that mean you will push an update to fix this or do I need to replace a specific xml file to fix the problem?
(2021-10-31, 11:28)matke Wrote: [ -> ] (2021-10-31, 10:34)nilobar Wrote: [ -> ]Hi, I would like to create a second Movie Shortcut in the Home Menu for all my DOK Movies. Is it possible to do this with the same Movie Icon you use in the home menu? When I create a new Shortcut (Edit menu shortcuts) I don‘t find the Icons in „Set Icon“.
I did and it works, but where can I find the same Movies Icon you use in Home Menu?
(2021-10-31, 11:57)geowill76 Wrote: [ -> ] (2021-10-31, 10:33)matke Wrote: [ -> ] (2021-10-31, 02:06)geowill76 Wrote: [ -> ]Hi Matke
Hi Matke
I'll try to fix it today, so I'll send you an xml to test first before I update it.
(2021-10-31, 12:02)nilobar Wrote: [ -> ] (2021-10-31, 11:28)matke Wrote: [ -> ] (2021-10-31, 10:34)nilobar Wrote: [ -> ]Hi, I would like to create a second Movie Shortcut in the Home Menu for all my DOK Movies. Is it possible to do this with the same Movie Icon you use in the home menu? When I create a new Shortcut (Edit menu shortcuts) I don‘t find the Icons in „Set Icon“.
You need to install skin icon on bingie rep
(2021-10-31, 12:06)matke Wrote: [ -> ] (2021-10-31, 11:57)geowill76 Wrote: [ -> ] (2021-10-31, 10:33)matke Wrote: [ -> ]I think I know why is that hapening with 12a. In code in some places standing contains. When standing contains, code see 12 in both ratings 12 and 12a. The same thing is with pg and pg-13. I'll switch to equals so I think that will solve the problem.
Hi Matke
Hi Matke
Sounds good. I will update xml file so I can test and let you know how it goes.
(2021-10-31, 12:10)matke Wrote: [ -> ] (2021-10-31, 12:02)nilobar Wrote: [ -> ] (2021-10-31, 11:28)matke Wrote: [ -> ]Try to select a movie shortcut from common menu and then edit it as you
In textures.xbt
I found it! How can I open the file and get the icon out?
I have only a Mac, so I can't use TextureTool...
(2021-10-31, 12:30)nilobar Wrote: [ -> ]I have only a Mac, so I can't use TextureTool...
Use the Kodi texture tool
(2021-10-31, 12:59)AchillesPunks Wrote: [ -> ] (2021-10-31, 12:30)nilobar Wrote: [ -> ]I have only a Mac, so I can't use TextureTool...
Thats the one I found on Official Kodi Wiki: „TextureTool is only working with Windows XP and above.“
Just a question. Is there any way you can turn of the ClearLogo that displays on the OSD when you pause during playback? Id just prefer to have the minimal text displayed in the top righthand corner. No big deal if you cant. Just wondered if i was missing an option somewhere. Thanks.
Hola, la ultima acyualizacion, solo es para kodi matrix?
