Full Version: Titan BINGIE MOD v1 (UPDATED - 07/24/2020)
Great work, thanks!!!!
(2020-07-25, 09:46)sanangel Wrote: [ -> ]Great work, thanks!!!!
Great work achillespunks!
Some way of doing it works for example with TheMovieDb Helper? the netflix style view doesn't work very well
thanks
(2020-07-25, 00:23)AchillesPunks Wrote: [ -> ]Looks just like Netflix when you walk into the house.
thanks for the mention i will be for what i can contribute as always
@AchillesPunks
is it possible to have the consolidated bingie episodes view for meta addons as well, like Openmeta or TMDB helper (those are meta addons and they only scrap meta information from tmdb and trakt, the dont host anything, but they work as video add-ons)
because currently the bingie episode view is separate for season layer and episode layer
this is the season layer
and this is the episode layer
compared to how you have it in your screenshots
I wish to have both in the same view, seasons on the left and a episode tiles on the right (i know it currently only supports library items, but it would be great if it can support meta video addons too)
(2020-07-25, 14:37)Jooode Wrote: [ -> ]
Your welcome
(2020-07-25, 19:37)daking1512 Wrote: [ -> ]@AchillesPunks
I would have to look at into it. Might end up being a little work not sure, but I will check this out.
(2020-07-25, 14:36)Frusciantism Wrote: [ -> ]Great work achillespunks!
thanks
Not sure what you mean.
Welcome
Amazing work AchillesPunks Smile
(2020-07-25, 20:44)shaktoo Wrote: [ -> ]Amazing work AchillesPunks Smile
If you ever get the artwork to me I'll change it inside the skin. And welcome back
(2020-07-25, 20:20)AchillesPunks Wrote: [ -> ]
thanks
exactly what the user daking1512 has said, he explained better  Laugh
(2020-07-26, 02:13)Frusciantism Wrote: [ -> ]
thanks
At this time it's local only that I know of.
(2020-07-24, 08:09)AchillesPunks Wrote: [ -> ]Make sure you run Artwork beef and download all fanart. On the view you need to press left hit change view and select episode views. Not sure how it works on UPNP
Sorted...changed the media server on my PC to Emby, not only does it show everything correctly but using emby-con it merges the TV shows on my PC into the TV shows in my library ( no need for a separate menu item ). Just one more thing....when you push left to bring up the menu items, is it possible to have the black background fade from left to right as Netflix does instead of it being solid black, or can you point me in the right direction to change it myself. Thanks again for this great skin.
(2020-07-26, 06:34)tankman37 Wrote: [ -> ]
I have been looking for that inside the XML's to have the side panel fade instead of solid black. I really want this on the home screen like Netflix has it. I'm already working on this and surprised you are the first person to ask about this. I'm not going to start going through the XML's again until next week. I work as a engineer 12hr shifts every Sunday, Monday, Tuesday, and every other Saturday. I have spent a lot of time changing small things inside the code on my personal build and have to balance this fun hobby and family life. Smile
