Full Version: Titan BINGIE MOD v1 (UPDATED - 07/24/2020)
(2020-09-01, 00:22)ESCO1 Wrote: [ -> ]Hey @AchillesPunks , I was gone from the forum for awhile, cameback and update all the files and noticed the logo art is extremely overzied overlapping the fanart. Not sure if this is what you intended to achieve looks wise but all the logos look way too big on my screen. Is there a way to update the xml to the original size. Thanks bro!!!!
Do you have a picture.
(2020-09-01, 00:04)Jooode Wrote: [ -> ]
(2020-08-31, 23:53)AchillesPunks Wrote: [ -> ]I updated the add-on.xml it should install now.
I have already updated it for you in the guithub dear friend
Okay sorry I didn't know.
Hello can someone point me to the skin setting to use the original Bingie OSD without the disk coming out of the poster and the finishes at, the time and duration. I prefer a cleaner more like Netflix look. I can't find where to get rid of that stuff.
So I just spent an hour setting up my widgets to clone my setup from the original Bingie skin.
One thing I noticed is the red label 'new episodes', it's centered instead of aligned left, can I change that somewhere in the settings?
(2020-08-31, 17:41)ShibajiCh Wrote: [ -> ]Hi,
I found an issue. In the Titan Bingie Skin if I enabled auto scroll for plot and descriptions then the widget headers in the Home screen remained static. However now when I enable that option the widget headers also start auto scrolling along with the plot descriptions. This is really annoying, please fix the issue. Also, the power menu items at the bottom are overlapping with the main menu items. This was not the case with the Titan Bingie Skin. Kindly fix this as well. Many thanks in advance!
Any updates on these issues?
(2020-09-01, 01:56)Desperados Wrote: [ -> ]So I just spent an hour setting up my widgets to clone my setup from the original Bingie skin.
It's probably because the size of the posters are different now stretched a lil wider. Probably haven't changed the new tags to compensate for that yet.
(2020-09-01, 02:00)cscott1 Wrote: [ -> ]It's probably because the size of the posters are different now stretched a lil wider. Probably haven't changed the new tags to compensate for that yet.
I'm using landscape images, not posters..
The label is very centered.. Maybe it's an easy fix but couldn't find the setting..
EDIT: I found the solution in IncludesViewsLayoutLandscape.xml
<!-- New Episodes Tag Overlay -->
<width>100%</width>
<height>25</height>
<left>100</left>
<bottom>13</bottom>
Changed <left>100</left> to <left>10</left>
Now the label is aligned to the left!
(2020-09-01, 00:52)AchillesPunks Wrote: [ -> ]
https://imgur.com/kEeJAEA
https://imgur.com/njpCMBl
https://imgur.com/jyh2dt9
https://imgur.com/GlsRyZs
@AchillesPunks @Jooode
I noticed in the addon.xml that both the original Bingie skin and this mod have the same addon id "skin.titan.bingie". The only difference is in the version number.
Maybe that's why the original Bingie kept updating when I installed your zip? Even after the change you made, I had to manually copy the folders over to prevent Bingie from updating.. Am I the only one having this problem?
can anyone create a build with this mod all set up it would be much appreciated
(2020-09-01, 04:25)Desperados Wrote: [ -> ]@AchillesPunks @Jooode
I'm at work until Wednesday. I have the addon.xml I just need to upload it to the github.
(2020-09-01, 02:28)Desperados Wrote: [ -> ]
<width>100%</width>
<height>25</height>
<left>100</left>
<bottom>13</bottom>
The new episode is centered now because that's how netflix has it set now
(2020-09-01, 04:06)ESCO1 Wrote: [ -> ]
Lol. Those are huge. I will check this out on Wednesday. They are definitely not supposed to be that big.
(2020-09-01, 01:46)cscott1 Wrote: [ -> ]Hello can someone point me to the skin setting to use the original Bingie OSD without the disk coming out of the poster and the finishes at, the time and duration. I prefer a cleaner more like Netflix look. I can't find where to get rid of that stuff.
I will give you the old file for the this on Wednesday. We switched it to have those features.
I just uploaded the new addon from my phone so it should work now
