Hi, dear AchillesPunks!
Thanks a lot for your perfect mod of Netflix.
I have installed the apk then from repository the mod and artwork beef and set the options the same as from your YouTube video but the mod is not working correct.
Istead of skin as it should be I have just black screen with names of the folders with film genres.
When I come back from work I'll take a photo and send here.
My box is Mecool KM3 4/64 GB with certified ATV10.
Will you be so kind and help me to solve this problem, pleasel, afterwards?
(2021-11-30, 14:22)Jalau Wrote: [ -> ]So I am having a performance issue with this skin.
Everytime I load up kodi every menu takes like at least a minute to load. Sections such as "Because you watched X" even take longer. I figure this is because it queries the imdb database for ratings and similar movies.
Also when opening a series the "Watch Season X Episode Y" button only loads in after like 20 seconds or something, probably because there is another slow query going on in the background.
What I am wondering isn't there some sort of cache in place? If not it would be possible right? I am a coder myself so I could go and add it but I wanted to ask if it was just me encountering this problem first.
Thanks for any help in advance!
Have a nice day
EDIT:
Btw. the search is also really slow for some reason.
Not sure if it is related but I was having the same issue and discovered it was due to some of the advancedsettings I was using I deleted all the advanced settings except the no splash setting and then my widgets all loaded instantly.
There is definitely a cache in place within Kodi its in the Userdata folder I dont use Jellyfin so I dont know much about it but some assumptions on my part is your Jellyfin Server Library is acting like an addon and yes I assume it has to pull the information upon every refresh whether or not you can trick Kodi into caching your servers Library Im not sure. I use addon Library integration which basically does something similar it allows you to make a virtual library then it uses the addon to pull video sources across the web. Perhaps you can use addon library integration for the Kodi Jellyfish addon?
Antoniuss Sorry, but I think you need a better/newer potato to make photos with. Also, photos in portrait (VVS..) of a landscape TV screen, that doesn't help.
(2021-11-30, 05:57)AchillesPunks Wrote: [ -> ]Just refresh the movie and select the correct year for mortal Kombat. It's still the same as before.
Also means that your .nfo file for the movie is incorrect.
If you still can't figure it out download metadata editor and Change the .nfo file and save it then refresh.
Maybe I’m being dumb but I don’t have the refresh option.
You turned it off inside settings. I'm at work so can't help you right now.
(2021-12-01, 14:37)matke Wrote: [ -> ] (2021-12-01, 13:28)Antoniuss Wrote: [ -> ] (2021-12-01, 08:03)matke Wrote: [ -> ]First of all, considering you use an android box, I guess you don't have a local library or maybe you have one on nas? Only if you have a local library skin can do things automatically. In the case of addons you have to adjust everything manually. Browse the forum a bit.
Yes, and I mentioned it in my first post - I use certified Android TV box 10 Mecool KM3 4/64 GB. So RAM memory and internal is ok.
I have all skins from repository. The problem is I selected the skin from the author of this mode and adjust the settings as like in YouTube video but it's not workable normally...
Of course I can surf this topic and try to find solutions in case someone had the same issues.
You obviously don't understand me. How you watch movies? Do you have them on a hard drive or use some addon for that.
Perhaps I don't. I watch movies online through the certain apps or streaming apps like Netflix etc. But sorry, how does your question concern to this mod Netflix Kodi and skin which is not unfortunately working in the box...
Please, explain
Guys,
Have you ever come across issue where you click on Add-ons section inside Kodi and get black screen without any options to choose? Missing list of My addons, Recently updated Addons etc etc
and as you can see its working normally when switched to other skin
(2021-12-01, 17:51)Antoniuss Wrote: [ -> ] (2021-12-01, 14:37)matke Wrote: [ -> ] (2021-12-01, 13:28)Antoniuss Wrote: [ -> ]Yes, and I mentioned it in my first post - I use certified Android TV box 10 Mecool KM3 4/64 GB. So RAM memory and internal is ok.
Please, explain
According to your screenshots, everything works as it should. I've already written to you, but you obviously don't know very well how kodi and skins work. Since you use an addon like netflix, you have to set everything manualy. And no, I don't mean the video you watched on youtube. Find out a little about how widgets work in kodi.
(2021-12-01, 18:44)awesomebuilder Wrote: [ -> ]Guys,
No. This is the first time I've heard from you about this problem. Try reinstalling the skin. I don't know what the problem might be.
(2021-12-01, 19:36)matke Wrote: [ -> ] (2021-12-01, 18:44)awesomebuilder Wrote: [ -> ]Guys,
Seems to be happening only on Bingie skin, dont know why.
There is some strange input inside Kodi log file ... + none of the addons can be actually opened using home shortcut. Only widgets works
log
