Full Version: Titan BINGIE MOD v1 (UPDATED - 07/24/2020)
i installed the mod after the bingie skin but when installed a prompt comes up saying unable to build menu help please anyone
(2020-09-01, 04:55)AchillesPunks Wrote: [ -> ]
(2020-09-01, 04:06)ESCO1 Wrote: [ -> ]
(2020-09-01, 00:52)AchillesPunks Wrote: [ -> ]Do you have a picture.
https://imgur.com/kEeJAEA
https://imgur.com/njpCMBl
https://imgur.com/jyh2dt9
https://imgur.com/GlsRyZs
Lol. Those are huge. I will check this out on Wednesday. They are definitely not supposed to be that big.
I’ve discussed this issue already. It’s because they’re using a different aspect ratio to the default and recommended standard Kodi scraped aspect ratio clearlogos. His are a wider aspect ratio. (They actually seem to be wider then Netflix logos for some reason)
The only way to fix this is to reduce all clearlogos. I’ve already fixed this on mine (you have it in the recent xmls I sent you) but then standard Kodi/artwork beef scraped clearlogos are much smaller and only the non standard aspect ratio clearlogos match Netflix width.
I still think it’s the best solution though.
(2020-09-01, 00:22)ESCO1 Wrote: [ -> ]Hey @AchillesPunks , I was gone from the forum for awhile, cameback and update all the files and noticed the logo art is extremely overzied overlapping the fanart. Not sure if this is what you intended to achieve looks wise but all the logos look way too big on my screen. Is there a way to update the xml to the original size. Thanks bro!!!!
Where are you getting these clearlogos from? These aren’t the default Kodi aspect ratio.
(2020-09-01, 04:33)Slick_Sanchez Wrote: [ -> ]can anyone create a build with this mod all set up it would be much appreciated
Should be set up after you install.
Do you know if it's possible to add item on the menu like home menu with widget.
I succed with add shortcut called "myhub" but...only one. If I want to add a second "myhub" I can't change widget, it's the same for all "myhub".
(2020-09-01, 04:56)AchillesPunks Wrote: [ -> ]
(2020-09-01, 01:46)cscott1 Wrote: [ -> ]Hello can someone point me to the skin setting to use the original Bingie OSD without the disk coming out of the poster and the finishes at, the time and duration. I prefer a cleaner more like Netflix look. I can't find where to get rid of that stuff.
I will give you the old file for the this on Wednesday. We switched it to have those features.
Thank you along with the original OSD could you possibly also give me the files to make the clear titles the original Bingie size and the US grey boxed in style media codec. Love everything else you have done. Thank you if possible look into making those skin settings when you have time.
(2020-09-01, 04:48)AchillesPunks Wrote: [ -> ]The new episode is centered now because that's how netflix has it set now
Oh I didn't know that.. I'm still using landscape images like Netflix did in the past.
Now Netflix has switched to posters but I've gotten so used to the landscape images that I just don't like it.
Do you know if it's possible in Netflix to switch from posters back to landscape or is it just the new default?
I ask because using the Netflix addon with your Bingie landscape views I know those images are still available.
(2020-09-01, 05:00)AchillesPunks Wrote: [ -> ]I just uploaded the new addon from my phone so it should work now
Thanks man, much appreciated!
(2020-09-01, 10:33)Samouraicop Wrote: [ -> ]If I want to add a second "myhub" I can't change widget, it's the same for all "myhub"
Maybe you have to go to skinsettings > configure shortcuts > lock widgets in hubs > disable that option.
Go to the hubs whose widgets you want to edit and after go back to the settings to lock the widgets in hubs again.
(2020-09-01, 12:03)Desperados Wrote: [ -> ]
Netflix isnt very customizable you are just kind of stuck with whatever they want to do. You used to be able to load previous versions of the app on android but starting a couple years ago when you load old versions it just updates to their current skin even if you have automatic updates turned off. They did finally make it an option to turn off auto trailers because so many people complained about them.
https://www.cnbc.com/2020/02/06/how-to-t...views.html
(2020-09-01, 11:29)cscott1 Wrote: [ -> ]
I'll send it all to you on Wednesday. I'll switch the mpaa to the original for you as well.
(2020-09-01, 13:11)cscott1 Wrote: [ -> ]They did finally make it an option to turn off auto trailers because so many people complained about them.
Yeah I heard about that but haven't gotten around to it yet, I'll give it a try!
Most of the time I don't mind but sometimes it can be annoying..
Thanks man. When i saw it i was like DAMN!!!! what happened!Huh lol
(2020-09-02, 02:11)ESCO1 Wrote: [ -> ]
Lol
I can give you everything on Wednesday. I'll fix the mpaa for you before I send you the xml
