(2022-02-02, 13:53)matke Wrote: [ -> ] (2022-02-02, 13:40)cscott1 Wrote: [ -> ] (2022-02-01, 14:57)dkw81 Wrote: [ -> ]First of all thanks for all the help on the forum. I've been reading all the tips for the last few days setting up this skin.
Just one question, that I can't find addressed anywhere. On some of the film posters there is a broken white line on the right side. I've tried changing some posters but it doesn't seem to be the image itself that's the problem. Is this normal?
This has been brought up before its an android thing and it sucks it happens when you use the 1426 width posters. I went one by one and changed all of mine to the narrower posters because it drove me nuts...
https://forum.kodi.tv/showthread.php?tid...pid2979608
Yes it is possible that it is up to the android. Now I tried it on an Android device and I have some glitches, but I tried it on a TV that has 720p resolution, so it's not very authoritative. Everything looks perfect on PC (1080p).
I don't think it has anything to do with the televisions screen resolution since it happens on your 720p my 1080p and dkw81's 4k tv. Its also odd that shkop was able to fix the issue with an external SSD and it works without glitches on a PC so its a possible it has something to do with the processing power of the device? I'm not that technical just trying to help eliminate causes for the problem.
I dropped the resolution down from the highest down to the lowest 640x480p on PC and I can not duplicate
more information for you to ponder it doesnt happen to the same poster every time and most of the posters show correctly it seems random possibly something to do with the animations navigating widgets?
@dkw81
Its because youre using Poster art from Fanart.tv (1000x1426). Happens to me too. Happens on other skins too. If you use poster art with a 1000x1500 resolution it'll be fine
I guess that happens on Android? PC has no issues with any size.
Anyways just redownload or change the size. I make fanart and edit poster all the time.
I also still use artwork beef
I've been using Titan Bingie Mod for quite a while now (on Nvidia Shield). Am on Matrix now. Did a clean Install. A few queries.
Why do I keep getting Skin Helper, Embuary, Skin Helper Widget errors.
Can I change Menu from the Netflix to my own only keeping Search, TV Shows, Movies and My List.
Why is it when I transition to test another skin, the Menu changes.
(2022-02-02, 16:47)insync44 Wrote: [ -> ]I've been using Titan Bingie Mod for quite a while now (on Nvidia Shield). Am on Matrix now. Did a clean Install. A few queries.
1. You have to do a complete clean install of Kodi (no userdata and addon data).
2. Yes you can change menu and customize your entries with your own widgets
3. What menu ?
redglory
1. Thank you for replying my thoughts exactly.
2.This stuff has been addressed so many times throughout the thread. Just a little effort into searching for the answers would help you with these questions.
3.The lack of detailed information given as well doesn't help.
I have the same issue, searched this thread and there's not much comment on the matter.
...Self help.. more research before posting.
In the even of dependency issues when installing on Matrix, the bingie repo needs to be removed which is for Kodi 18 leia only.
I tried your version for Kodi Matrix but I get xbmc.python version 2.24 could not be satified.
It is on LibreELEC and OSMC on a Raspberry Pi 4.
Any help this is the skin I have been trying to find.
Hi kodi family I'm trying to install the titan bingie build but so for know luck can you please explain to me the right steps to take on installing it please thank you
Needs to be 100% fresh install. You cannot upgrade from Kodi 18
Mine was a fresh install on LibreELEC and OSMC
(2022-02-02, 15:01)Giant_Midget Wrote: [ -> ]@dkw81
Thanks, I'll give that a go tonight.
