(2022-04-10, 21:09)Baxter300 Wrote: [ -> ]Hi @AchillesPunk don’t suppose you’ve have a chance to look into the issue with widget labels scrolling away when auto-scroll text is enabled?
https://imgur.com/a/LjRusxc
Did you fix your widget names scrolling issue?
Hi when's the next update keep up the good work
AchillesPunks
I have had same problem with scrolling widgets names but it was me being numbty lol I have changed font from Default to Original. So I was gonna recommend him checking these settings.
Hello friends
I have Kodi Matrix 19.4 and Artwork Beef is not working properly with some covers.
Can you tell me the correct version of Artwork Beff for kodi 19 and how to make everything work well again.
Thank you very much
Sorry, I found a solution
This might be a noob question but how to I setup these things?
Setup search?
Setup play something?
How can I add a folder location for the categories under home?
How can I display all of the ratings IMDB,rotten tomatoes, etc. on the bottom right?
How can I display the TV shows like netflix where there is a small video screen shot and a description to each episode?
1. As of right now the search option only works with local media.
2. Categories is already attached to the home you just need your media.
3. You need to enter your API keys to get all of your ratings to work.
4. If you have media in your library then these functions are already work.
How can I setup these things
The search feature?
How can I show ratings on the bottom right?
Under the home page how can I configure the categories pages?
How can I setup play something?
Tv show listing as it is in the screen shot if the picture that shows the seasons and episodes on the right?
Thank you and thanks for the skin. It's incredible! How can I add the media to my library from my video add on?
It shows the ratings if I check show IMDB instead of percentage in the settings but not on the bottom right like it shows in your screen shots. Where can I add the api keys?
What view is used for the TV shows that shows the seasons on the left. I am able to click to the left and switch between views but I would like to change all the views at once so I went into MYaddon - tools - settings - advanced - and I check the box for FORCE VIEWS. This is the only way im able to set all of the views for a specific type like Movies, TV shows
DISPLAY RATING
3. I beileve i entered all the API correctly becuase if I go to SETTINGS/HOMESCREEN LAYOUT/PREFER IMDB/RT/TVDB Rating over Percentage on details row. It shows up but it comes out on the top and replaces the percentage not on the bottom right like it shows on your screen shot. Could you tell me where I should add the api details? I have added it to all the places I could find but maybe im missing one
CHANGE VIEWS
I found the view called "Bingie Episodes" but when I go into a TV show and click to the left to change the view it does not show up as one of the options. I can only see that view if I go to SETTINGS/SKIN SETTINGS/MEDIA LIBRARY VIEWS/ ENABLE-DISABLE VIEWS. I would like to set this view for all my episodes.
When I go into my video add on/TOOLS/OPEN SETTINGS MENU/ADVANCED/FORCE VIEW TYPES ON MENU/ it does not show up there as one of the options. I only see Default,Poster,Icon Wall, Shift, Info Wall, Wide list, Wall, Banner, Fanart
CATEGORIES
Could you point me to somewhere that I can see how to add the movies from my video add on into my kodi library? Or should I just add the category from my add on?
If I add the category from my add on the icons are ugly and not as nice as the ones you created,
Hello,
When I try to install the skin on CoreElec (Kodi 19.5 RC1) I have a dependencies missing problem.
For script.module.arrow, script.module.beautifulsoup4, script.module.request and few more dependencies are not available.
Any suggestions?
