Full Version: Titan BINGIE MOD v1 (UPDATED - 07/24/2020)
(2020-09-03, 13:16)Desperados Wrote: [ -> ]
(2020-09-03, 12:38)cscott1 Wrote: [ -> ]I changed the color theme to HugoLs Netflix theme and copied my old Bingie skin settings and it righted itself somehow.
I don't have that color theme  Huh There's Cartman.dos, AchillesPunks and Jooode..
What's the difference between the color themes? And how did you copy your skin settings back? I tried using the skinhelper backup function but that didn't work for me..
Oh honestly Im not sure what the color them was called I am assuming it said HugoL because the picture had the new menu I believe it could have been something else my bad trying to go off memory as I am at work. as far as the settings I went back into Bingie and took pictures of all my settings with my phone then one by one set the setting in the Mod not ideal but it works.
(2020-09-03, 12:30)Jooode Wrote: [ -> ]
(2020-09-03, 11:36)ronnel Wrote: [ -> ]Image
Am I the only one having this overlapping frame?
disable fixed frame in settings, this fixes your problem
I know. But that isnt really a wise choice since it removes the static frame which gives a netflix-ish style.
(2020-09-03, 13:29)ronnel Wrote: [ -> ]
My frame is in a fixed position and it no longer has the overlapping in focus frame after I changed a bunch of my settings keep messing with the settings there is a way to right that issue not sure what it is tho sorry.
(2020-09-03, 12:56)Desperados Wrote: [ -> ]
(2020-09-03, 12:29)Jooode Wrote: [ -> ]disable fixed frame in settings, this fixes your problem
Yes it does! But I actually like the fixed frame so I'll just wait till github gets updated..
I'll use the original Bingie skin until then..
(2020-09-03, 13:23)cscott1 Wrote: [ -> ]as far as the settings I went back into Bingie and took pictures of all my settings with my phone then one by one set the setting in the Mod not ideal but it works
Oh wow never thought of doing that lol. Kodi remembers my skin settings and just restores them when I update the skin.
When I uninstall the skin I always check the box to keep the skin settings..
you have something wrong with your skin, it works for me with fixed frame and new changes, try to update again or remove and install again
(2020-09-03, 13:38)Jooode Wrote: [ -> ]you have something wrong with your skin, it works for me with fixed frame and new changes, try to update again or remove and install again
I actually removed the skin twice last night reinstalled this morning so maybe the uninstall helps somehow. while uninstalled I updated Bingie from the repo so try that too.
(2020-09-03, 13:20)cscott1 Wrote: [ -> ]
(2020-09-03, 12:50)HugoL Wrote: [ -> ]
(2020-09-03, 12:38)cscott1 Wrote: [ -> ]I had the overlapping in focus frame as well when I first uploaded the update. I changed the color theme to HugoLs Netflix theme and copied my old Bingie skin settings and it righted itself somehow. I dont mind the Netflix Logo actually I like it altho thats what I always looked at to tell whether I was using Kodi or Netflix lol the option to have it or remove it would be nice. I hope Achillies gets a working knowledge of the button controls because a skin setting option to chose between US an UK MPAA ratings is number one on my wishlist it is literally the only thing that looks different from Netflix now everything else is spot on. The compromises made is right at the sweet spot in my opinion. Did you guys change the Poster view slightly? before they looked almost stretched a bit now they look perfect. Kudos to HugoL on the new menu looks awesome!
So does your submenu work? I just downloaded the update and it’s working.
Also, what happened with your issue with the widgets moving gradually moving up into the more info section?
Not sure if I still have the issue or not before the mod overwrote Bingie so all my widgets stuck when I installed the new update it installed as a separate skin and I have to plug in all my settings and add all my widgets I only added 2 as I drank my coffee before coming to work to check out the new look. I still have about 40 widgets to add when I get home Im at work right now Ill check when  get home and report back to you.
I’m guessing you can just copy all your widgets over using one of the xmls in your previous xml folder to the new one. I think it’s scriptshortcutincludes.xml (or something written very similar to this).
I don’t have a colour theme by the way. I have hard coded most of my text colours in the xmls. If Achilles has used this code in the xmls (haven’t checked yet) then unfortunately you won’t have much choice in the matter either. Changing colour schemes or trying to change the colours in settings won’t work for the specific text colours I’ve changed.
(2020-09-03, 13:37)Jooode Wrote: [ -> ]
OK the first time I tried that it didn't work, so I just switched to the Bingie skin.
Just now switched back to this Mod to try it again after seeing your video and now it does work, wtf??
But thanks! Another question, how does your color theme differ from AchillesPunks Netflix theme?
EDIT: Submenus still don't work though..
(2020-09-03, 13:50)Desperados Wrote: [ -> ]
I’m really confused. Jooode isn’t showing fixed frame enabled. He is using disabled. I can see the moving frame and the video shows the setting disabled too. This works as intended.
Your issue is with fixed frame enabled. This isn’t working properly on the update because I just checked.
Are you sure you have it enabled?
This video isn’t fixed frame enabled. You should see a fault if you enable it. I just confirmed the update has this fault.
If I choose to delete this skin including the skin settings and then install the skin again from scratch, can I use the skinhelper backup addon to restore all my previous settings including submenus and all widgets? I don't really want to have to start over.. Or can I copy some xmls that contain these settings?
(2020-09-03, 13:59)HugoL Wrote: [ -> ]
(2020-09-03, 12:56)Desperados Wrote: [ -> ]Yes it does! But I actually like the fixed frame so I'll just wait till github gets updated..
true I don't use it because of not seeing it
(2020-09-03, 13:56)HugoL Wrote: [ -> ]Are you sure you have it enabled?
No I disabled it like Jooode mentioned.. Normally it's enabled but that indeed causes the issue which is weird.
But disabling it keeps the frame fixed somehow so happy that works!
(2020-09-03, 14:00)Desperados Wrote: [ -> ]
Just have fixed frame disabled for now. We’ll get round to fixing it.
It shouldn’t bother you that much. after all, you didn’t even notice from Joodes video that it was disabled which is understandable because the difference is minimal. I think Netflix may even work this way anyway.
