Full Version: Titan BINGIE MOD v1 (UPDATED - 07/24/2020)
(2020-09-03, 18:48)AchillesPunks Wrote: [ -> ]
(2020-09-03, 17:53)nazim12 Wrote: [ -> ]@HugoL: Diffuse Image is not looking good , Its too black and not visible , edges  diffuse will look fine though
Not sure what your talking about on the diffuse image not looking good? I thing is perfect, or maybe you can show us some photos of the problem.
He’s trying to say it’s too dark on the image itself. He probably prefers it brighter which it probably was. I personally like it how it is but I’m not against making it brighter either. Think I need to see it on my telly since I’ve only seen it on my laptop.
(2020-09-03, 18:45)AchillesPunks Wrote: [ -> ]Please remove the code or comment it out in the xml. I am adding the Netflix logo and flat2 png to the texture.xbt folder
Will do! But I'll keep it in home since I can't remove it from hubs..
(2020-09-03, 18:59)Desperados Wrote: [ -> ]
That will remove it from hubs. It just won’t remove it from menus. Sorry, probably didn’t read your message properly.
(2020-09-03, 14:16)AchillesPunks Wrote: [ -> ]Fixed frames have been fixed.
So happy to see this thread is being so active. Hats off to you guys.
(2020-09-03, 19:01)HugoL Wrote: [ -> ]That will remove it from hubs. It just won’t remove it from menus. Sorry, probably didn’t read your message properly.
Oh great! I just thought includeshomebingie.xml only referred to the homepage, good to know  Big Grin
(2020-09-03, 18:40)cscott1 Wrote: [ -> ]You can make more than that too I think I have 7 or 8 a few of my hubs are linked to addons each hub has like 7 or 8 widgets so you can have over 40 different widgets.
Really?! Didn't know that! Besides movies and tv shows I only have an extra hub for my list.
I tried adding a hub with widgets from the Netflix addon but they didn't work properly..
Only my list and continue watching, so I just added them to my home screen..
A totally different question but since everybody here seems to know a lot, does anyone have a Shield tv?
I added kodi playlists as a channel but they are in poster format, all other channels are in landscape.
Does anyone know if it's possible to change the kodi playlist from posters to landscapes?
(2020-09-03, 19:19)Desperados Wrote: [ -> ]A totally different question but since everybody here seems to know a lot, does anyone have a Shield tv?
Yes I have a shield and I have a modded version of kodi with the landscape posters on the android TV home screen. let me see if I can find you the thread on the modification.
(2020-09-03, 19:23)cscott1 Wrote: [ -> ]Yes I have a shield and I have a modded version of kodi with the landscape posters on the android TV home screen. let me see if I can find you the thread on the modification.
Wow thanks! So I would have to download a kodi fork to get the landscape images? Is the fork still being maintained and updated??
(2020-09-03, 19:32)Desperados Wrote: [ -> ]
No it is a kodi 19 fork and is slowly dying new addons arent updating it is still working but ill probably abandon it when the official version of Kodi 19 comes out.
 https://github.com/xbmc/xbmc/pull/16225
https://forum.kodi.tv/showthread.php?tid...pid2861487
https://drive.google.com/file/d/1Jdr2-VE...sp=sharing
this is the modded version of Kodi with a fix for the auto trailers and the Android TV landscape view but I dont recommend it now it would be awesome if someone who knows what they are doing to compile the change to a newer version of kodi any takers? https://github.com/xbmc/xbmc/blob/master/docs/README.md "IMPORTANT" if you try this when going from kodi 18 to this fork it will migrate your build but you cant migrate your build back to 18 I have tried. so make a backup on 18. Im waiting for 19 to come out before I can switch back to the Main branch.
here is Cartmans Pull request to fix the auto trailers for anyone who is interested as well. It was tested in the Nightlys and worked fine but they never added it to the main branch for some reason.
https://github.com/xbmc/xbmc/pull/16241
(2020-09-03, 19:14)Desperados Wrote: [ -> ]
I always forget the search menu is a hub.
Then when I need more widgets and decide to use it, those widgets are top of my widget list where they don’t belong and it’s annoying having to redo all the widgets again to get your preferred starting widgets on top.
You should always use your top Hub menu item first (probably Search hub) to start your widget order properly but it’s so counter intuitive it’s easy to forget!
(2020-09-03, 19:38)HugoL Wrote: [ -> ]I always forget the search menu is a hub.
Yeah I started my widgets on home as well.. In my case it worked out great because I added the Netflix widgets to search so they are on top now, which I prefer..
(2020-09-03, 19:46)Desperados Wrote: [ -> ]
Yeah me too. Works out great like that! But before I was using that addon I got caught out all the time.
(2020-09-03, 18:54)HugoL Wrote: [ -> ]
Well It really looks great.
Fanart background image in Home and hub , its darker with Diffuse .
