(2020-09-04, 02:29)HugoL Wrote: [ -> ] (2020-09-04, 01:56)cscott1 Wrote: [ -> ] (2020-09-04, 01:06)cscott1 Wrote: [ -> ]Thank you the replacement files were perfect just want I wanted. Going to hold onto them for future updates.
Ok so it seems I may have spoken too soon the xml file you sent me for the home page has the old zoomed in spotlight fanart size value I really like the smaller one I have been using recently if possible can you match that as well when you have time?
I can do this for you in the morning if you PM me your email, unless you get it done sooner. Just heading to bed now!
I'd like to see the MPAA text set as default for US certification. Not sure I'm keen on the US icons, especially since I incidentally made them smaller while improving the UK icons.
I'm keen to try your US setting if you want to send it to me. I'll send you my email
(2020-09-03, 20:00)HugoL Wrote: [ -> ]that poster height is winding me up. Needs to be lower but every time I try and move it, it messes up the home widget height and can’t see any way to solve it.
I agree with this, the previous poster height was better. In the latest update, the posters took almost half of the screen already.
(2020-09-04, 02:18)HugoL Wrote: [ -> ]I've brightened it up a bit now:
Current vs New for comparison.
Do you want me to send it to you?
I would also like to try the new diffuse mask if possible! The current spotlight corner I agree is a little too dark on my oled tv.
(2020-09-04, 10:13)Desperados Wrote: [ -> ] (2020-09-04, 02:18)HugoL Wrote: [ -> ]I've brightened it up a bit now:
Yep, me too. We’ll get it pushed out as an update soon.
(2020-09-03, 18:52)AchillesPunks Wrote: [ -> ] (2020-09-03, 18:07)Samouraicop Wrote: [ -> ] (2020-09-01, 12:16)Desperados Wrote: [ -> ]Maybe you have to go to skinsettings > configure shortcuts > lock widgets in hubs > disable that option.
Go to the hubs whose widgets you want to edit and after go back to the settings to lock the widgets in hubs again.
I tried, but it's the same issue. All myhub created have the same widget like the first myhub.
I used myhub but maybe I can use something else?
The only thing I want it's each menu element have widget like Home element.
After you select MyHub you will need to change the source to wherever you want to point at that has media. You will keep the same Icon but the source it points to will change and you will have a spotlight for the hub
I did. Myhub1-》source: Vidéo Folder
Myhub2-》source: Tv show Folder
But the same result. The both show same widget
(2020-09-04, 01:03)cscott1 Wrote: [ -> ] (2020-09-03, 12:50)HugoL Wrote: [ -> ] (2020-09-03, 12:38)cscott1 Wrote: [ -> ]I had the overlapping in focus frame as well when I first uploaded the update. I changed the color theme to HugoLs Netflix theme and copied my old Bingie skin settings and it righted itself somehow. I dont mind the Netflix Logo actually I like it altho thats what I always looked at to tell whether I was using Kodi or Netflix lol the option to have it or remove it would be nice. I hope Achillies gets a working knowledge of the button controls because a skin setting option to chose between US an UK MPAA ratings is number one on my wishlist it is literally the only thing that looks different from Netflix now everything else is spot on. The compromises made is right at the sweet spot in my opinion. Did you guys change the Poster view slightly? before they looked almost stretched a bit now they look perfect. Kudos to HugoL on the new menu looks awesome!
So does your submenu work? I just downloaded the update and it’s working.
Also, what happened with your issue with the widgets moving gradually moving up into the more info section?
So not sure that it matters now that a new update was pushed but my menus work fine. I have 33 widgets in the poster view with fixed focus in vertical scrolling enabled and everything works as intended moving down through them my very last widget is the categories widget and I have it in landscape view. When I move upwards from there the yes the widgets move into the info section. That is the only bug I can find at the moment. Until it is fixed I am happy to move down instead of up from the categories widget.
Yes , that's what happening to me , but not only upwards , even if you add more widgets after 35 , you will loose your two widget row screen and will only left single row widget screen .
and when you scroll vertical from last widget to upwards then the widgets section keep moving into info section.
I got it thanks yeah the MPAA text the nice grey boxed ones matches the US version of Netflix perfectly I agree it needs to be an option. There are lots of user on both sides of the pond I'm sure.
I really like this skin but I have a problem for some reason I can get season view (episode view) like you I tried everything but still I can't figure it out
I could get solid movies and tv shows rating on auramod skin but in this mod I can't ! Auramod screenshot
Is there any way I get those rating Oscar,Vote,..on this mod. Thanks in advance
Fantastic update!
Love all the changes except the constant Netflix banner bottom right screen. How can I remove this, please?
Also, my UK ratings show BBFC colour ratings perfect, except for PG ratings wich does not show the UK style rating, but a green rectangular US styke icon.
Can this be changed?
(Sorry for poor quality photo)
(2020-09-04, 19:33)spinecho Wrote: [ -> ]Fantastic update!
There’s no option to remove the logo yet unless through the xmls.
You need to use the UK includesmediaflags.xml. It’s designed to fix this this very problem of the PG icon crossing over with the US (along with making a translation of US TV show ratings to UK certs for people who use the default scraper and therefore wont have UK certs for their TV shows).
(2020-09-04, 19:48)HugoL Wrote: [ -> ] (2020-09-04, 19:33)spinecho Wrote: [ -> ]Fantastic update!
Thanks @
HugoL as always fantastic work!
I'll put up with Netflix logo [emoji2][emoji2]
Ignore... double post [emoji85]
