(2020-09-11, 15:34)cscott1 Wrote: [ -> ] (2020-09-09, 12:01)cscott1 Wrote: [ -> ] (2020-09-09, 11:22)HugoL Wrote: [ -> ]This kind of rules out anything that either Achilles or I have changed and would be much harder to trace and fix.
@cscott1 Can you confirm this also happened for you in the original Bingie?
Yeah I still have Bingie as a skin I'll see if I can duplicate the behavior when I get home from work.
Yes the behavior is exactly the same in Cartmans Bingie skin the reason i never noticed before was because I was using the landscape view where for me the problem of only one widget appearing on screen after 29 widgets does not happen in Bingie or the the Mod it's only a problem in poster view. I'm speculating but perhaps since posters are almost twice the height of landscape posters that has something to do with the problem maybe there is a coded limit of how long the total height of the combined widgets allow for two widgets to be on screen? As far as scrolling upwards and the widgets moving into the information dialog this behavior doesn't happen in the landscape view I believe because there is a visible widget at the bottom that says spotlight. When you scroll to it it disappears and transitions into the spotlight on both Bingie and the mod in poster view this kind of ghost widget is not there maybe it was something Cartman did to make everything work with landscape but neglected to do so with poster or other views. Worth looking into if you know where to look maybe whatever he did with landscape posters could be replicated with posters.
At least one of those issues, is to do with multiple layouts (i.e having both poster and landscape on the same screen) and while using "fixed focused widgets in vertical scrolling" is enabled. If you want the categories landscape with "fixed focus widgets in vertical scrolling" enabled, it has to your very last widget.
I thought maybe your other issue was related but then again, you said you removed your landscape categories widget completely and you still had an issue with the 29th widget. Do you have any other landscape (or any other non poster view) widgets other than the categories widget?
(2020-09-11, 16:11)HugoL Wrote: [ -> ] (2020-09-11, 15:34)cscott1 Wrote: [ -> ] (2020-09-09, 12:01)cscott1 Wrote: [ -> ]Yeah I still have Bingie as a skin I'll see if I can duplicate the behavior when I get home from work.
No they are all poster except the categories widget.
HugoL After seeing your Netflix integration i am trying myself to add Netflix addon username & password , but unfortunately it keep saying username password incorrect although it is right , now i need an irrelevant question for Netflix authentication method how can i authenticate with nf key ? how to create personal key ?
(2020-09-11, 20:48)nazim12 Wrote: [ -> ]@HugoL After seeing your Netflix integration i am trying myself to add Netflix addon username & password , but unfortunately it keep saying username password incorrect although it is right , now i need an irrelevant question for Netflix authentication method how can i authenticate with nf key ? how to create personal key ?
I installed it quite a long time ago and don’t really remember the process. Don’t remember having any difficulty though.
Are you using this add-on and did you check the guide here?
https://github.com/CastagnaIT/plugin.vid...-the-addon
(2020-09-11, 20:57)HugoL Wrote: [ -> ] (2020-09-11, 20:48)nazim12 Wrote: [ -> ]@HugoL After seeing your Netflix integration i am trying myself to add Netflix addon username & password , but unfortunately it keep saying username password incorrect although it is right , now i need an irrelevant question for Netflix authentication method how can i authenticate with nf key ? how to create personal key ?
Thanks its done . i think Netflix Logos are little bigger compare to library widgets ?
(2020-09-11, 21:34)nazim12 Wrote: [ -> ] (2020-09-11, 20:57)HugoL Wrote: [ -> ] (2020-09-11, 20:48)nazim12 Wrote: [ -> ]@HugoL After seeing your Netflix integration i am trying myself to add Netflix addon username & password , but unfortunately it keep saying username password incorrect although it is right , now i need an irrelevant question for Netflix authentication method how can i authenticate with nf key ? how to create personal key ?
They are “bigger“ yes. Specifically, they are only wider. I’ve mentioned this previously but Netflix uses a different aspect ratio to Kodi scraped logos. Their max width is wider meaning their artwork can extend much wider than your typical clearlogo. That doesn’t mean they are always wider, it depends specifically on the artwork they use. If they use artwork that utilises it’s full width, it can extend to 1100-1200px (around 3 poster widths) compared to the Kodi standard of 800px.
The skin can’t recreate this. You can’t increase the width without increasing the height as the aspect ratio has to be respected. We had larger logos but it just wasn’t right because we matched the width of Netflix but that inevitably meant increasing the height (to respect the aspect ratio of the art) so the height was all wrong. I had to make them smaller again (although still an improvement over the original bingie).
However, you can recreate their logos. With a png editor like Paint 3D for example, you can increase the standard logo width on specific artwork that allows for it.
As follows (in Paint3d):
1. Open your clearlogo png and extend the width (and only the width!)of the canvas.
Do not allow the artwork to stretch with the canvas otherwise the artwork aspect ratio will be altered (stretched). Do not alter the height of the canvas either. All Kodi scraped logos are 800px wide. Edit the canvas width from 800px to 1100px while maintaining the default height.
2. Now you’ve fixed the canvas, increase the artwork itself.
Draw a selection box around the artwork itself and shift key + mouse drag a corner of the box to enlarge the artwork until your artwork meets either the end of the canvas or the bottom. This isn’t a choice. It’s which ever comes first. If it hits the bottom canvas before it hits the full width, that is the max size increase you can make.
Holding the shift key ensures it maintains the correct aspect ratio as you increase the size. Do not attempt a mouse drag without first hold the shift key.
**this will only work for artwork that doesn’t already utilise it’s full height area. ie. if the artwork already touches both the top and bottom of its canvas, you can’t increase its size further (without ruining its aspect ratio)**
Should take about 20 seconds in paint 3D once you know what you're doing. If you’re having trouble I’ll see about making a video.
(2020-09-11, 23:27)HugoL Wrote: [ -> ] (2020-09-11, 21:34)nazim12 Wrote: [ -> ] (2020-09-11, 20:57)HugoL Wrote: [ -> ]I installed it quite a long time ago and don’t really remember the process. Don’t remember having any difficulty though.
I have about 900 movies and about 500 tv shows any volunteers to edit my logos for me? lol. No takers lol I think I'll just keep the standard size logos good enough for the girls I go out with. But thanks for the info if any of them bother me bad enough to change I now know how. Also for those who don't know if artwork beef doesn't scrape a logo for your show you can often find the logo from a simple google search and just type in the name of the show plus PNG. You can often source them from netflix or amazon prime.
(2020-09-12, 01:59)cscott1 Wrote: [ -> ] (2020-09-11, 23:27)HugoL Wrote: [ -> ] (2020-09-11, 21:34)nazim12 Wrote: [ -> ]Thanks its done . i think Netflix Logos are little bigger compare to library widgets ?
Oh that reminds me I have to switch to Estuary to manually add my artwork it would be nice if that could be an added feature to Bingie. I'm sitting at my river camp by a fire right now not near my hub but I will go into a more in depth request when I'm at home maybe make a short video to show you what I mean.
(2020-09-12, 02:09)cscott1 Wrote: [ -> ] (2020-09-12, 01:59)cscott1 Wrote: [ -> ] (2020-09-11, 23:27)HugoL Wrote: [ -> ]They are “bigger“ yes. Specifically, they are only wider. I’ve mentioned this previously but Netflix uses a different aspect ratio to Kodi scraped logos. Their max width is wider meaning their artwork can extend much wider than your typical clearlogo. That doesn’t mean they are always wider, it depends specifically on the artwork they use. If they use artwork that utilises it’s full width, it can extend to 1100-1200px (around 3 poster widths) compared to the Kodi standard of 800px.
Add a reload in configure shortcut settings. No need to switch to another skin.
Github has been updated.
Added Option to Remove the Netflix Logo on Home.
Removed Fixed Focus Frames.
Removed the Option to Disable profile picture
Added Enable Zoom effect on selected Widget on Home
Adjusted Configure Shortcuts.
Moved Spotlight Diffuse & Vignette to XBT.
Changed the Bingie Logo in xml to Netflix Logo for Home icon.
(2020-09-12, 02:30)AchillesPunks Wrote: [ -> ] (2020-09-12, 02:09)cscott1 Wrote: [ -> ] (2020-09-12, 01:59)cscott1 Wrote: [ -> ]I have about 900 movies and about 500 tv shows any volunteers to edit my logos for me? lol. No takers lol I think I'll just keep the standard size logos good enough for the girls I go out with. But thanks for the info if any of them bother me bad enough to change I now know how. Also for those who don't know if artwork beef doesn't scrape a logo for your show you can often find the logo from a simple google search and just type in the name of the show plus PNG. You can often source them from netflix or amazon prime.
Somethings going on with the spotlight corner diffuse and the spotlight content widget diffuse. Neither are showing up me.
Buttons are working nicely though! You forgot to include the diffuse for the Netflix logo which should disappear with the logo itself.
Hello, Is there a place where I can set a specific widget style to landscape? all I can see is the option to set all widgets style.
If it is not possible via the gui maybe I can edit a file or something?
(2020-09-12, 10:19)HugoL Wrote: [ -> ] (2020-09-12, 02:30)AchillesPunks Wrote: [ -> ] (2020-09-12, 02:09)cscott1 Wrote: [ -> ]Oh that reminds me I have to switch to Estuary to manually add my artwork it would be nice if that could be an added feature to Bingie. I'm sitting at my river camp by a fire right now not near my hub but I will go into a more in depth request when I'm at home maybe make a short video to show you what I mean.
I just checked your xmls. The paths for these images are still pointing to the extras folder.
(2020-09-12, 10:56)aahmyu Wrote: [ -> ]Hello, Is there a place where I can set a specific widget style to landscape? all I can see is the option to set all widgets style.
You can, but you'll lose fixed focus vertical scrolling since it won't work properly with different layouts. Disable the option in settings and you can then configure individual widgets.
