Full Version: Titan BINGIE MOD v1 (UPDATED - 07/24/2020)
(2020-09-12, 05:11)AchillesPunks Wrote: [ -> ]Github has been updated.
Added Option to Remove the Netflix Logo on Home.
Removed Fixed Focus Frames.
Removed the Option to Disable profile picture
Added Enable Zoom effect on selected Widget on Home
Adjusted Configure Shortcuts.
Moved Spotlight Diffuse & Vignette to XBT.
Changed the Bingie Logo in xml to Netflix Logo for Home icon.
the fuzzy image of the posters has disappeared for me this is so or is it a mistake. but as always great work thanks.
I have corrected it by installing the png the fuzzy image in the extras folder should not obey the xbt command.
(2020-09-12, 13:27)Jooode Wrote: [ -> ]
Hi, can you explain a bit further?
(2020-09-12, 18:44)spinecho Wrote: [ -> ]
He’s talking about the diffuse mask for the spotlight corner.
Unless Achilles fixes it sooner, I’ll see if I can jump on my laptop tonight and sort it out. He seems to have forgotten to change a couple of paths or is using incorrect xmls. Dunno.
Well done   its nice to see changes  but I feel  zoom has a minor effect,  very hard to determine its zoomed , Better a little more zoom might better .
Mine solved. because there wasn't any file on extra folder call spotlight diffuse image i manually copy it on that folder.
(2020-09-12, 19:15)nazim12 Wrote: [ -> ]
(2020-09-12, 13:27)Jooode Wrote: [ -> ]the fuzzy image of the posters has disappeared for me this is so or is it a mistake. but as always great work thanks.
Achilles moved it to the .xbt file where it should be but didn't change the path in the xmls.  Extras folder was just a temporary solution while trying out a few different diffuse images.
(2020-09-12, 19:26)HugoL Wrote: [ -> ]
(2020-09-12, 18:44)spinecho Wrote: [ -> ]Hi, can you explain a bit further?
when I installed new updates I faced same problem like ''spineco'' , then i used old spotlight image ( The one which is Brighter ) and placed it on Extra folder, It worked .
https://i.postimg.cc/2jdYFpsF/image.png
(2020-09-12, 19:33)nazim12 Wrote: [ -> ]
(2020-09-12, 19:15)nazim12 Wrote: [ -> ]Mine solved. because there wasn't any file on extra folder call spotlight diffuse image i manually copy it on that folder.
Yep, that will fix it temporarily.
(2020-09-12, 19:10)HugoL Wrote: [ -> ]
Thanks @HugoL
Hi Guys, thanks for the explanations, but it's all beyond me!!
Where are you getting the diffuse png from?
(2020-09-12, 20:07)spinecho Wrote: [ -> ]Hi Guys, thanks for the explanations, but it's all beyond me!!
Copy this file in extras folder and restart
https://mega.nz/file/auwxDShL#Eo9j1H_hGW...BICdZLSr5k
Good day,
Could it be that tmdb is being used instead of extendedinfo?
Thank you in advance for your top skin and work
(2020-09-12, 20:24)nazim12 Wrote: [ -> ]
Thanks...will try it
When I get home in the morning I'll upload all files to GitHub. My mistake I thought I did but I guess I just the changed the settings and uploaded only that.
After this I will not be on for a while. Many things going on right now.
(2020-09-13, 04:37)AchillesPunks Wrote: [ -> ]When I get home in the morning I'll upload all files to GitHub. My mistake I thought I did but I guess I just the changed the settings and uploaded only that.
would it be possible to implement the changes from @HugoL ? especially the big logo looking text labels (if clear logos are disabled), that would be nice
