Full Version: Titan BINGIE MOD v1 (UPDATED - 07/24/2020)
(2020-09-18, 22:50)cscott1 Wrote: [ -> ]
(2020-09-18, 22:46)AchillesPunks Wrote: [ -> ]
(2020-09-18, 21:32)cscott1 Wrote: [ -> ]Thank you
I sent you a private message. Just send me your email, and I'll give you the episode view with the landscape turned off
Thanks I got it and sent you my email
Email has been sent
This is a great-looking skin/mod. One question (sorry if it's been asked before, but after a quick search I couldn't trace it). Is there any way of converting the sub-menus to hubs? I'm coming fro. Auramod, where I could just convert have the sub-menu items as their own widget, and 'genres' and 'studios' would take you to their own page. Thanks again, great work!
(2020-09-19, 01:47)AchillesPunks Wrote: [ -> ]
(2020-09-18, 22:46)AchillesPunks Wrote: [ -> ]I sent you a private message. Just send me your email, and I'll give you the episode view with the landscape turned off
Email has been sent
Thanks got it it was exactly what I wanted. Thumbs up given.
Hi everyone, is there anyway I can stop both startup splas screens? Still getting original
(2020-09-19, 19:33)pocca Wrote: [ -> ]Hi everyone, is there anyway I can stop both startup splas screens? Still getting original
Do a custom splashcreen and replace with a black image.
You can remove the Kodi splash by making an easy advanced settings forder and use this setting <splash>false</splash>
https://kodi.wiki/view/Advancedsettings.xml
I also use the advanced settings to increase the cache for slower streams.
I use this for my splash lol
https://youtu.be/Hs-1_HNALhw
(2020-09-19, 21:59)cscott1 Wrote: [ -> ]
could you post a pic of the part of your advancedsettings , for increasing cache please ?
(2020-09-19, 22:34)ontap Wrote: [ -> ]
A video was easier here you go.
https://youtu.be/oUK4_Rp2PQo
Hi all,
Any change to make the first widget raw being a bit transparent when the cursor is on the spotlight? i think it will be a nice touch
https://ibb.co/NKC2RfS
(2020-09-20, 15:12)jonsnow30 Wrote: [ -> ]Hi all,
I think i've got it:
https://ibb.co/XppLyXk
I added this line:
        <animation effect="fade" start="35" time="300" condition="Control.IsVisible(1508) + Integer.IsGreater(Container(77777).Position,0)">Conditional</animation>
under this line:
<animation effect="slide" end="0,-250" time="300" condition="Control.IsVisible(1508) + Integer.IsGreater(Container(77777).Position,0)">Conditional</animation>
Hi, whilst the English maps logos are on the Home Screen is there any way to change when playing a movie. Still comes with tvma on player screen?
(2020-09-20, 16:02)jonsnow30 Wrote: [ -> ]
I added this line:
under this line:
I like that a lot. Good job!
What's up with your plot/button configuration? You switched it around? The original Bingie had it like this and I was never that keen on it to be honest.
The current version:
(2020-09-20, 16:23)pocca Wrote: [ -> ]Hi, whilst the English maps logos are on the Home Screen is there any way to change when playing a movie. Still comes with tvma on player screen?
Not at this time. Not for the logos at least. But if you want UK age certificate text to replace the TV-XX text, you need to scrape UK age ratings.
So over months my my Kodi build has grown to over 6 GB and that's without any media so I decided it was time to delete my thumbnails folder. In the past when I have done this it almost all my art reappeared but not this time. About 50% is gone particularly from my movies just black rectangles with white triangles. Now I have found my self totally redoing my artwork with artwork beef which takes forever and to top that off I spent hours already and noticed that a lot of posters are not cropped well and I have to redo those. Just an FYI for those who read the first page of the Bingie page under tips only do this if you are having performance issues and absolutely need more space. This sucks lol.
(2020-09-10, 15:48)chihaeru Wrote: [ -> ]Hi, I'm having an issue with this skin (and the original Bingie too) which causes Kodi to crash.
My current setup is latest Kodi 18 with Jellyfin addon and the skin, and everything works fine - widgets on TV Shows, Movies, etc populate fine. The issue I have, is when I choose to play a movie from any movie widgets, Kodi will crash when trying to start the stream. I've tried multiple skins and this is the only skin that I've had this issue with. Strangely, playing those same movies from the Spotlight on either Home or Movies tab works fine. Everything in regarding TV Shows plays fine from any widgets.
Going into the logs, I can see the last few lines when Kodi crashes are always the same:
2020-09-10 23:31:32.706 T:13108  NOTICE: JELLYFIN.objects.actions -> INFO::jellyfin_kodi\objects\actions.py:776  [ play ] kodi_id: 1 media: movie
2020-09-10 23:31:34.206 T:6504 WARNING: CRenderManager::Configure - timeout waiting for configure
2020-09-10 23:31:34.206 T:6504   ERROR: CVideoPlayerVideo::OutputPicture - failed to configure renderer
I've also tried creating a custom view using a custom hub, adding the movie widgets, and the result is the same, yet playing from the spotlight works.
Any ideas? I love the skin, but I'd have to find another one if I can't get movies to work.
Hi, I have same error. Also tried lot of skins and this only happens with this one and bingie original. Did you fix it?
