Full Version: Titan BINGIE MOD v1 (UPDATED - 07/24/2020)
(2020-09-21, 13:05)wrp_199 Wrote: [ -> ]
(2020-09-10, 15:48)chihaeru Wrote: [ -> ]Hi, I'm having an issue with this skin (and the original Bingie too) which causes Kodi to crash.
My current setup is latest Kodi 18 with Jellyfin addon and the skin, and everything works fine - widgets on TV Shows, Movies, etc populate fine. The issue I have, is when I choose to play a movie from any movie widgets, Kodi will crash when trying to start the stream. I've tried multiple skins and this is the only skin that I've had this issue with. Strangely, playing those same movies from the Spotlight on either Home or Movies tab works fine. Everything in regarding TV Shows plays fine from any widgets.
Going into the logs, I can see the last few lines when Kodi crashes are always the same:
2020-09-10 23:31:32.706 T:13108  NOTICE: JELLYFIN.objects.actions -> INFO::jellyfin_kodi\objects\actions.py:776  [ play ] kodi_id: 1 media: movie
2020-09-10 23:31:34.206 T:6504 WARNING: CRenderManager::Configure - timeout waiting for configure
2020-09-10 23:31:34.206 T:6504   ERROR: CVideoPlayerVideo::OutputPicture - failed to configure renderer
I've also tried creating a custom view using a custom hub, adding the movie widgets, and the result is the same, yet playing from the spotlight works.
Any ideas? I love the skin, but I'd have to find another one if I can't get movies to work.
@HugoL @AchillesPunks any info about this?
I could provide logs if you need
No clue about Jellyfin at all I’m afraid. Can I see the same log again with it working from Spotlight?
(2020-09-21, 10:42)HugoL Wrote: [ -> ]
(2020-09-21, 02:44)stecik14 Wrote: [ -> ]I will literally pay someone to get my shields setup with this.. I can not even get widgets to populate more than once when I have the skin on.. someone.please.help!
Can you explain the problem in more detail?
Well I'm using the normal titan bingie not this mod because I can't get this one.. I'm couldn't get the repository to work.. but when I add the widgets and point then to Seren in the tv shows and movies section every time I switch away from tv shows the widgets won't come up anymore it just is writing.. I can take a picture or video when I get home
(2020-09-21, 20:48)stecik14 Wrote: [ -> ]I can take a picture or video when I get home
Don't bother... This forum will halt all support to Kodi devices running any type of video piracy tool(s).
You should know that as you have accepted our forum rules (wiki) when you registered here.
*MOD EDIT*
No support = no support for users/devices using video piracy crap.
(2020-09-21, 13:19)HugoL Wrote: [ -> ]
This one is playing a movie from new content widget in home tab: https://pastebin.com/5vaze2U9
This is the kodi crashlog after hitting play on that movie: https://pastebin.com/5xpjrPbs
This one playing a tv show from same widget: https://pastebin.com/0u23fF3M
This one is playing a movie from recently added in movies tab (estuary skin): https://pastebin.com/8W9ViScx
Sorry about the spotlight but i dont see the play button on mine, im using latest verison of this skin 1.0.6
Edit: @HugoL Here you have the log playing a movie from spotlight. I left the movie playing for 5 minutes without any issue. The only thing ive noticed is that when i hit stop button, a few seconds later it plays again.
https://pastebin.com/2mcMSApU
(2020-09-21, 23:54)wrp_199 Wrote: [ -> ]
(2020-09-21, 13:05)wrp_199 Wrote: [ -> ]@HugoL @AchillesPunks any info about this?
This is beyond me I’m afraid. I noticed a few minor bingie errors in your log but the ones I noticed at least should be irrelevant.
Also, your log doesn’t seem to contain the same errors as the the other jellyfin user you quoted.
Found the fix for red triangle overlay not showing full percentage in the home menu 'Continue Watching' widget.
IncludesViews.xml
around line 1390 - 1408
<control type="group">
                <description>In progress Overlay</description>
                <visible>ListItem$PARAM[listitem].IsResumable + Skin.HasSetting(WatchedIndicator.Progress)</visible>
                <visible>!ListItem$PARAM[listitem].IsPlaying + !ListItem$PARAM[listitem].IsRecording</visible>
                <control type="image">
                    <texture background="true">$PARAM[overlay_texture]</texture>
                    <colordiffuse>$INFO[Skin.String(WatchedIndicator.Progress.Color)]</colordiffuse>
                </control>
                <control type="label">
                    <right>0</right>
                    <top>0</top>
                    <align>right</align>
                    <font>$PARAM[font]</font>
                    <width>100%</width>
                    <height>45%</height>
                    <label>$INFO[ListItem$PARAM[listitem].PercentPlayed]%</label>
                    <textcolor>$INFO[Skin.String(WatchedIndicator.Progress.TextColor)]</textcolor>
                </control>
            </control>
Now the only bug that bothers me the most is the incorrect display of progress bar within dialog video info in TV Shows hub. In Home it displays accurately. Sad
(2020-09-22, 19:00)HugoL Wrote: [ -> ]
(2020-09-21, 13:19)HugoL Wrote: [ -> ]No clue about Jellyfin at all I’m afraid. Can I see the same log again with it working from Spotlight?
Well, ill ask on jellyfin forum, but its strange because this only happens with this skin and the original bingie. Its related with widgets for sure and only applies to movies.
Thank you anyways Hugo.
(2020-09-22, 20:23)ronnel Wrote: [ -> ]Found the fix for red triangle overlay not showing full percentage in the home menu 'Continue Watching' widget.
IncludesViews.xml
                </control>
                    <right>0</right>
                    <top>0</top>
                    <font>$PARAM</font>
                    <width>100%</width>
                </control>
            </control>
I actually fixed this today for an upcoming update.  But like the dickhead I am, I didn't go here like you did.  I went to includesviewslayoutPoster.xml and includesviewslayoutLandscape.xml and adjusted the fonts.
I also fixed the label overlay on landscape not showing on the landscape widget properly. I don't use these tags/overlays on my widgets so I didn't even notice I'd cocked them up.
I did notice this error
ERROR: NEWADDON Unknown Video Info Key "progress" and I just presumed it wasn't Bingie at first but then I realised it must be related since it doesn't show up in Estuary.  So I googled around and I saw the following thread where the creator of Bingie, Cartman is asking about this error which seems to be related to Skin Helper. Don't know if this is causing the crash though but it might be.
https://forum.kodi.tv/showthread.php?tid...id=2813962
IncludesViews.xml
                </control>
                    <right>0</right>
                    <top>0</top>
                    <font>$PARAM</font>
                    <width>100%</width>
                </control>
            </control>
So what is your actual edit here. Can't be bothered to search in the xmls right now. And does it look better than mine? If so, I'll just revert back and do it your way.
(2020-09-22, 22:01)HugoL Wrote: [ -> ]
IncludesViews.xml
                </control>
                    <right>0</right>
                    <top>0</top>
                    <font>$PARAM</font>
                    <width>100%</width>
                </control>
            </control>
Yours did also fix this problem, that's what matters most.
Quote:incorrect display of progress bar within dialog video info in TV Shows hub. In Home it displays accurately.
@HugoL  can you help me please with this one? I'm stucked with this for days now.
(2020-09-22, 22:29)HugoL Wrote: [ -> ]
IncludesViews.xml
                </control>
                    <right>0</right>
                    <top>0</top>
                    <font>$PARAM</font>
                    <width>100%</width>
                </control>
            </control>
Made the width into 100% and adjusted the alignment into right. Default was center which makes the text not fit for some resolutions since it was centered. Making it aligned right makes the text stay on the right side regardless of the resolution.
(2020-09-22, 22:29)HugoL Wrote: [ -> ]does it look better than mine?
basically its just the same look on the latest update but is already displaying full text regardless of the resolution.
