Full Version: Titan BINGIE MOD v1 (UPDATED - 07/24/2020)
I fumbled my way into changing the MPAA flag/text into BBFC - UK Icon flags after also increasing the clearlogo size and changing the font and formatting of the plot text. I'm happy with the results and I should probably just leave it alone now!
(2020-08-06, 20:09)HugoL Wrote: [ -> ]I fumbled my way into changing the MPAA flag/text into BBFC - UK Icon flags after also increasing the clearlogo size and changing the font and formatting of the plot text. I'm happy with the results and I should probably just leave it alone now!
It’s looks beautiful
Can you share the files
Looks really nice. Yes please do share the file. I just had my first day off and should finish uploading everything to the GitHub today. I added your three lines for text. I added more views with fanart. Also have the clearlogo set bigger. Home set to 60, views to 50.
Is that your setup with the TV and sound bar? If so it looks amazing. Is that a Samsung TV? How's the sound bar sound?
(2020-08-05, 22:07)jirake Wrote: [ -> ]
(2020-08-05, 04:15)AchillesPunks Wrote: [ -> ]
(2020-08-04, 19:02)jirake Wrote: [ -> ]Firstly thanks to all contributors of this amzing skin.
There is an isuue with progress bar for resume buttons in IncludesDialogVideoinfo.xml
With tv-series don't shows the correct percent played in the progress barImage
Instead with movies it shows the correct percent played in progress barImage
I'm not sure what the issue is for the resume button? What am I looking at here?
So,i have enabled "Set Default Select Action To Show Information(only applies to widget)" in "Homescreen Layout"-->"Widget"
When click on a widget on homescreen:
I have this,and that's what i meant for issue in progress bar:
By the way the same episode clicking on "more episodes":
Instead with movies there is no issue:
I'm unable to recreate the issue your showing. Mine are showing properly.
Landscape single fanart added with animated discart.
Image Image
(2020-08-06, 22:58)AchillesPunks Wrote: [ -> ]
Looks really nice. Yes please do share the file. I just had my first day off and should finish uploading everything to the GitHub today. I added your three lines for text and more views with fanart. Also have the clearlogo set bigger. Home set to 60, views to 50.
It’s an LG C8 OLED TV. The soundbar is an LG ATMOS SK9Y. Still love the TV but the soundbar is mixed. Really love the front sound but I guess I was a bit hopeful thinking you’d get decent upward firing ATMOS from a soundbar but then again, there is a noticeable difference with ATMOS content. Sidefiring speakers don’t really give you a great sense of surround in my living room but it’s OK. Again, probably being too hopeful when it’s just a soundbar. Think you can add rear speakers if you want proper 5.1. If it was cheaper, I’d be very happy with it.
About the XML’s, I’m not sure to be honest. I’ve had to make small changes to a few xml’s just to make the font work which is fine but it only works properly for that particular font. It would take some additional effort to make it work for all the other fonts if you want to keep them. It’s mainly because of the height adjustments I made to text boxes to only display 2 lines of text. Other fonts have different line spacing requirements to make them fit. I also completely removed the code for the tagline (just movies).
The MPAA flags need to be added to the extra’s folder in the skin which is fine but I’ve removed the code for the original MPAA flag box/text so there’s no fallback and no user options to change them. Remember this is a UK rating system so probably not going to be of interest to a lot of people. I’ve made a few other small changes relevant to me like changing the text colour in the xml’s rather than via the settings menu so custom colour settings may not work as expected. And god knows what else I’ve messed around with in my rumblings!
I think the best thing would be to share the relevant .pngs and font files and then some relevant lines of code (Which I never even bothered to take note of!) in the xml’s rather than the whole xml’s I guess. Then maybe you can work your magic and make it user friendly somehow like adding a user option for the ratings icons?
(2020-08-07, 00:00)AchillesPunks Wrote: [ -> ]Landscape single fanart added with animated discart.
Image Image
Looks lovely! Kinda stuck in my bingie views now for continuity of the homescreen.
I need to try and get out of that mode and explore some views soon.
(2020-08-07, 00:17)HugoL Wrote: [ -> ]
Image Image
I do not use these views either. Just did this for people that do.
(2020-08-07, 00:11)HugoL Wrote: [ -> ]
Yes I would like to play with it for sure. If that's not a problem. You can send it to my email if you don't mind.
Do you plan on upgrading your speaker setup then? Or your content with the sound bar?
How can I change clearlogo size
(2020-08-07, 02:50)trkselim Wrote: [ -> ]
Im uploading it to the Github. When I'm finish just download it it.
Can you put up a link for the github please, I went looking but couldn't find it...no doubt my wife would find it in 5 mins😂
changing the aspect ratio of the poster would be really cool
thank you for your superb work
(2020-08-07, 06:50)tankman37 Wrote: [ -> ]Can you put up a link for the github please, I went looking but couldn't find it...no doubt my wife would find it in 5 mins😂
Links on first page. (Titan Bingie Mod) its in blue. Says Link click the below Titan Bingie Mod
Github has been updated with all new changed.
#1. Landscape views now have fanart.
#2. Landscapesingle has animated discart.
#3. The plot has beed adjusted adjusted to 3 lines on home, and view. Thanks to @HugoL for this adjustment.
#4. Clearlogos are a little bigger now for HOME, and Views.
