Full Version: Titan BINGIE MOD v1 (UPDATED - 07/24/2020)
(2020-10-12, 23:00)tankman37 Wrote: [ -> ]
(2020-10-12, 22:23)DROIDshield Wrote: [ -> ]I used this picture from Nazim12. So I guess credits to him.
https://drive.google.com/file/d/1IH8BtyY...p=drivesdk
I've highlighted the icon's. I have my movies in my library with what I belive is the right codecs, meta data etc. The settings are set to show but these icons never show up. I've done searches allover the net. Is it a guarded secret?
Hi DROIDshield, actually the picture is mine..not sure why it posted that way..what is it on my setup that you want to replicate.
Well then I salute you sir. The pic was just a bit up from this message under his name.. hope it was OK for me to use it to highlight the sound icon's you have showing up. Ie Dolby digital, 7.1, atmos etc. No matter what I put in the folder with the any said film they don't show.
I know I have the settings in Titan correctly set. So it must be what I'm putting in the folder or im missing another set of meta data?
(2020-10-12, 23:15)DROIDshield Wrote: [ -> ]
If you’re still using multi source addons like the banned one you’ve mentioned several times, it’s never going to show that info on the details row.
How would the skin even know what info to display before you’ve even chosen the source?
(2020-10-12, 23:36)HugoL Wrote: [ -> ]
(2020-10-12, 23:00)tankman37 Wrote: [ -> ]Hi DROIDshield, actually the picture is mine..not sure why it posted that way..what is it on my setup that you want to replicate.
Since the last runin I have setup folders and put movies into each. I mentioned this in my earlier post. I also mentioned putting the meta data files in the folders too.
Before I got hammered for mentioning addons I learned it won't work that way so I have gone the legal route and still getting shot down.
I'm just hoping for some help?
DROIDshield.  All my media is local, scraped with 'the movie database ' and ' artwork beef ' addons, no seperate folders, no .nfo. Some movies don't have logos, or menu items dont have an appropriate icon  so I make them myself, but that's about it.
(2020-10-13, 00:07)DROIDshield Wrote: [ -> ]
(2020-10-12, 23:15)DROIDshield Wrote: [ -> ]Well then I salute you sir. The pic was just a bit up from this message under his name.. hope it was OK for me to use it to highlight the sound icon's you have showing up. Ie Dolby digital, 7.1, atmos etc. No matter what I put in the folder with the any said film they don't show.
Are your movies local?
(2020-10-13, 00:14)tankman37 Wrote: [ -> ]
Thank you. You just told me what I needed to know. You make your own logo's etc.
I have watched a tutorial on this so now I can get this issue sorted out. I thought I was putting stuff in the wrong folders as I now have a 5 T drive to house my media. All other detail show apart from sound icon's. So I will deal with now.
(2020-10-13, 00:24)HugoL Wrote: [ -> ]
(2020-10-12, 23:36)HugoL Wrote: [ -> ]If you’re still using multi source addons like the banned one you’ve mentioned several times, it’s never going to show that info on the details row.
yes all local now. I building up a library.
(2020-10-13, 00:29)DROIDshield Wrote: [ -> ]
(2020-10-13, 00:07)DROIDshield Wrote: [ -> ]Since the last runin I have setup folders and put movies into each. I mentioned this in my earlier post. I also mentioned putting the meta data files in the folders too.
Ok. Play a movie and then check the details row.
If nothing shows up, remove any nfo file you’ve created for that movie and try the first step again.
(2020-10-13, 00:27)DROIDshield Wrote: [ -> ]
The technical info about the movie ( HD/UHD, Dolby,  ACC, 5.1, 7.1 etc ) should be encoded in the movie file itself. I haven't had to do anything extra to get the ratings/HD/5.1/Dolby icons to show. The logos I mentioned are the big title Logos eg..name of the movie
It doesn’t work like that. Creating your own logos won’t fix the issue.
When you say “apart from sound icons” are you now saying it’s only the audio codec that’s not displaying? So resolution is working and audio channels are working?
(2020-10-13, 01:24)HugoL Wrote: [ -> ]
(2020-10-13, 00:14)tankman37 Wrote: [ -> ]DROIDshield.  All my media is local, scraped with 'the movie database ' and ' artwork beef ' addons, no seperate folders, no .nfo. Some movies don't have logos, or menu items dont have an appropriate icon  so I make them myself, but that's about it.
Your versed in the terminology. Im getting ratings, and tomatoes.. and IMDb / TMDB stuff. What i don't get is if a movie is 4K, Dolby Atmos 7.2 that bit doesn't show even though the skin and TMDB are looking at the movie on my drive.
So im guessing artwork beef isn't setup correctly or it doesn't output the detail from the movie it self. So I may have to make my own artwork as was said.
I have a Panasonic DP-UB9000 blu-ray and if i play the same movie the details are shown on screen so I know its my settings but I'll get around it eventually. Just got to get it in my head what the skin does. Artwork beef and tmdb with api installed.
(2020-10-13, 00:57)tankman37 Wrote: [ -> ]
I've got it atlast. I reset the skin back to default and setup again. Its now showing full detail in the top row.
I did what HugoL said and took all the files i added to the folders and ran the movie. All details are shoeing up. Thank you both. I know its like pulling teeth, but their is no full tutorial online. But I know where I'm going now. Thank you both for your perseverance. I can start building my library and putting my stamp on how the skin looks.
(2020-10-13, 01:58)DROIDshield Wrote: [ -> ]
(2020-10-13, 00:27)DROIDshield Wrote: [ -> ]Thank you. You just told me what I needed to know. You make your own logo's etc.
Holy hell playing every movie and tv show in my library even for just a few seconds sounds like a daunting task to get the audio details in the top row. Wish there were an easier way but I know there really isn't.
This is not true if your add-on is integrated into your library the audio details will show after playing an item from said add-on. It will show the audio details from whatever source you chose to play from the add-on.
(2020-10-13, 03:29)cscott1 Wrote: [ -> ]
Not true if you don't have physical media in your library you can't show video audio details in advance because it will depend on results.
