(2020-10-19, 12:37)Jooode Wrote: [ -> ] (2020-10-17, 23:03)HugoL Wrote: [ -> ] (2020-10-17, 13:12)haicaoboi87 Wrote: [ -> ]like this : the redline in the top right corner show total films (tv show)
thank you alot
OK but do you actually want that in red, and in that position? Because it looks kind of terrible.
What about this, next to the header?
I think I'm going to keep this myself. It's not anything I thought I needed before but since it's not offensive and I guess it's useful enough so it's staying!
hello friend could you tell me how i get this, i love it
Bingiemainlandscape.xml
Search for <!--Content Header--> and replace the header textbox control with the following 2 textbox controls.
xml:
<!-- Content Header -->
<control type="textbox">
<width>100%</width>
<height>40</height>
<font>Bold31</font>
<align>left</align>
<textcolor>$INFO[Skin.String(ViewDetailsTextColor)]</textcolor>
<label>$VAR[BingieMainContentHeader] $INFO[Window(Home).Property(TVshows.Count),(,)]</label>
<visible>Integer.IsGreater(Container(523).NumItems,0)</visible>
<visible>String.IsEqual(Container.FolderPath, videodb://tvshows/titles/)</visible>
</control>
<width>100%</width>
<height>40</height>
<font>Bold31</font>
<align>left</align>
<label>$VAR[BingieMainContentHeader] $INFO[Window(Home).Property(Movies.Count),(,)]</label>
<visible>String.IsEqual(Container.FolderPath, videodb://movies/titles/)</visible>
</control>
Bingiemainposter.xml
xml:
<animation effect="slide" start="0" end="0,-15" time="0" condition="Skin.HasSetting(View526_DisableFixedBingieFrame) + Skin.HasSetting(View526_EnableZoomEffect)">Conditional</animation>
<width>100%</width>
<height>40</height>
<font>Bold31</font>
<align>left</align>
<visible>Integer.IsGreater(Container(526).NumItems,0)</visible>
</control>
<width>100%</width>
<height>40</height>
<font>Bold31</font>
<align>left</align>
</control>
(2020-10-19, 14:03)HugoL Wrote: [ -> ] (2020-10-19, 12:37)Jooode Wrote: [ -> ] (2020-10-17, 23:03)HugoL Wrote: [ -> ]OK but do you actually want that in red, and in that position? Because it looks kind of terrible.
xml:
<width>100%</width>
<height>40</height>
<font>Bold31</font>
<align>left</align>
</control>
<width>100%</width>
<height>40</height>
<font>Bold31</font>
<align>left</align>
</control>
xml:
<width>100%</width>
<height>40</height>
<font>Bold31</font>
<align>left</align>
</control>
<width>100%</width>
<height>40</height>
<font>Bold31</font>
<align>left</align>
</control>
Thank you so much friend how always great job
https://drive.google.com/file/d/1KMITo38...p=drivesdk
I was playing with some settings last night an I think I've gone too far.
The posters are small pics and text on them the title is normal bold font.
Short of a reset and start again... what have I done here. Anyone?
(2020-10-19, 17:13)DROIDshield Wrote: [ -> ]https://drive.google.com/file/d/1KMITo38...p=drivesdk
Is it just on that widget?
(2020-10-19, 19:16)HugoL Wrote: [ -> ] (2020-10-19, 17:13)DROIDshield Wrote: [ -> ]https://drive.google.com/file/d/1KMITo38...p=drivesdk
No it's system wide. Had it been just that widget I would had deleted it and start again. But I've messed up the hole system. Is it worth delete and start again?
(2020-10-19, 20:57)DROIDshield Wrote: [ -> ] (2020-10-19, 19:16)HugoL Wrote: [ -> ] (2020-10-19, 17:13)DROIDshield Wrote: [ -> ]https://drive.google.com/file/d/1KMITo38...p=drivesdk
Was this something done in the xmls or just in the settings menu?
(2020-10-19, 22:16)HugoL Wrote: [ -> ] (2020-10-19, 20:57)DROIDshield Wrote: [ -> ] (2020-10-19, 19:16)HugoL Wrote: [ -> ]Is it just on that widget?
No this is done in the settings not the xml. Im not skilled enough to play in that area, which is why I don't understand when making changes to the settings the images never change back to normal or any kind of change. Hence why I'm thinking wipe start again but do backups as I go along. What do you think?
(2020-10-20, 02:06)DROIDshield Wrote: [ -> ] (2020-10-19, 22:16)HugoL Wrote: [ -> ] (2020-10-19, 20:57)DROIDshield Wrote: [ -> ]No it's system wide. Had it been just that widget I would had deleted it and start again. But I've messed up the hole system. Is it worth delete and start again?
If it was just a setting you changed you can try installing it on another user profile and comparing the stock settings to yours
That looks like you are pointing to the folder the movies are in before they are scraped. What does the movie /TV libary look like, and does the libary look good in the default skin.
If it's just skin settings you've changed (not sure what skin settings would cause this) you can start fresh by selecting "reset skin to default" under Backup and Restore
(2020-10-20, 08:30)tankman37 Wrote: [ -> ] (2020-10-19, 17:13)DROIDshield Wrote: [ -> ]https://drive.google.com/file/d/1KMITo38...p=drivesdk
Correct the videos are in the library, what they look like i cant really tell as this is on the shield so I can't really browse them like being on a pc.
I have pointed artwork beef to the library but it doesn't seem to make a difference.. im still at it though before doing a full reset as HugoL has agreed with me but if I can get it to work I'll have learnt something.
Why doesnt it show imdb rating, metacrictic rating at footer.. It oly shows tmdb rating.. I even enabled in media flags settings.. Still it doesnt show imbd rating. Can some1 help me?
