Full Version: Titan BINGIE MOD v1 (UPDATED - 07/24/2020)
(2020-10-31, 21:09)HugoL Wrote: [ -> ]
(2020-10-31, 21:03)iirishguyi Wrote: [ -> ]
(2020-10-31, 14:07)johnsonsteven1986 Wrote: [ -> ]Just tried using the downloader app. I typed in Bingie Titan Mod in the url box and clicked the link to this thread. I then clicked the link for the mod and it brought up the option to download
Really need your help again guys, so I've installed the newest updated Bingie plus the mod file and first thing that comes up is the Netflix intro...which is weird but okay so now the skin is showing and there are no widgets on the new mod....is this right? So what now I have to create my own? I'm so confused and wish someone would explain how this skin works. Thank you guys
You do have to create your own widgets but there should be several widgets already built in to start you off.
You need a library otherwise you won’t have any widgets on display.
Okay so I'm guessing I'll have to set up my library on the Crew addon? seeing as how it's the only addon to start you off it looks like
@iirishguyi
Please do not use or even mention video piracy add-ons, a.k.a. banned add-ons, on this forum.
We've had our reputation smeared enough already in the last couple of years.
(2020-10-31, 22:16)iirishguyi Wrote: [ -> ]
(2020-10-31, 21:03)iirishguyi Wrote: [ -> ]Really need your help again guys, so I've installed the newest updated Bingie plus the mod file and first thing that comes up is the Netflix intro...which is weird but okay so now the skin is showing and there are no widgets on the new mod....is this right? So what now I have to create my own? I'm so confused and wish someone would explain how this skin works. Thank you guys
You will get no help from anyone on this forum if you mention banned add-ons.
(2020-10-31, 19:33)HugoL Wrote: [ -> ]
(2020-10-31, 18:58)minhgi Wrote: [ -> ]How do the stop the widget title group name from scroll up and disappear. It then reappear 10 seconds later.
You have to disable plot scroll for now. I’ll fix it for the new update
I couldn't find that option. But I can wait the next release.
(2020-10-31, 22:48)minhgi Wrote: [ -> ]
I fixed it for the update but you really should find that option anyway! Plot scrolls look terrible.
Go to skin settings>general skin settings>disable auto scroll for plots.
(2020-10-31, 22:33)Klojum Wrote: [ -> ]@iirishguyi
Look I'm very sorry I had no idea, I assumed because some people who shall remain nameless created this Bingie skin and mod, so I assumed they would know what was already on it. Anyway I have set up my library I guess and I am still not seeing any widgets. If you care to help me just let me know or perhaps there is some other way for us to communicate. Thanks
(2020-10-31, 23:10)iirishguyi Wrote: [ -> ]I assumed because some people who shall remain nameless created this Bingie skin and mod, so I assumed they would know what was already on it. Anyway I have set up my library I guess and I am still not seeing any widgets. If you care to help me just let me know or perhaps there is some other way for us to communicate.
The answer is simple. As long as no banned / blacklisted add-ons, repos, wizards, builds or other less than 100% legal inclusions are used for your setup questions, all is fine here. Otherwise you can find yourself a group chat solution outside this forum.
(2020-10-31, 23:10)iirishguyi Wrote: [ -> ]Look I'm very sorry I had no idea
A lot of forum visitors "forget" to read our forum rules (wiki), which include the piracy policy (wiki).
“What was already on it”? You’re very confused. Neither the original Bingie or the mod contain video addons of any kind.
Update is live.
1.08 Changelog
Spotlight
  • New brighter spotlight widget diffuse.
  • Spotlight Widget now hides plot on idle (with a slide animation)
  • New metadata sublabel on spotlight widget (and on home & Bingie views)  Spotlight sublabel now includes top 250 on IMDB and Director metadata (Director metadata is only displays on films and only for spotlight, not bingie views).  Can be disabled via (Settings>Homescreen Layout>Details Options).
Menu
  • New menu icons for sideblade and slim menu. Increased sideblade menu width to allow for longer labels (had to alter the submenu position for this to work so it sticks out further than usual.
  • General tidy up of sideblade menu and slim menu/indicator.
  • Menu now displays a max of 6 short cuts/hubs at any time, so you can have as many as you like without affecting the look of the menu.
Details Row
  • New Option fake resolution codec.  If enabled and if your resolution and audio metadata is missing, a fake “Ultra HD 4K” flag will appear.
  • New Option for displaying TV show status (ended, cancelled or continuing)
  • New option for Audio Codecs to display only the Atmos metadata (like Netflix) providing you have the existing metadata and when Audio Codecs are enabled.
  • Removed all other audio codec logos. It’s only text & flagbox now for non ATMOS audio Codecs
  •  Added TVDB rating to the IMDB/RT details row option (RT for films, TVDB for shows)
  • General details row tidy up
OSD
  • Added the option to switch between  either ClearLogo or ClearArt when OSD is paused.
  • Added option to switch between ClearLogo or ClearArt for OSD infopanel
  • Added option to remove the current time, start time and duration of movie on OSD
  • Added option to have jump indicator show when skipping video scenes.
  • Added option to remove the discart from OSD Infopanel
  • Changed the diffuse on the OSD infopane to help highlight the infopanel better.
Other changes
  • New Circular Navigation option – Removed access to the old version. New option keeps the same layout as noncircular navigation. Sideblade Menu access is on Back command only.  We will hopefully implement menu access from position 0 On Left in the next update.  Option found via (Settings>Homescreen Layout>Widgets).
  • New Total video count in bingie library views next to header.
  • Fixed bug with widget focus position changing when more than 28+ widgets are loaded.
  • Fixed widget header scrolling when Plot Scrolling is enabled.
  • Changed the left side diffuse on home so menu icons are more visible when there is a widget directly behind it.
  • Adjusted widget heights for bingie library views (poster and landscape)
  • Tidied up Continue watching widget
  • Tided up Plots & Critics in Video Info dialogue
  • Tidied up Cast in Video Info dialogue
  • Added a season greetings Snow effect option Settings>homescreenlayout>seasons greetings
(2020-10-31, 22:06)nazim12 Wrote: [ -> ]
(2020-10-31, 19:36)HugoL Wrote: [ -> ]
(2020-10-31, 19:05)nazim12 Wrote: [ -> ]Bingie home widgets moment is a little shaky , but I foud when I go to my source library movies that section widget moment is a little better, widget moment is smoother there but not in home or hub.
Are you meaning to say movement? Shaky movement? Still not very descriptive of the issue but mine are fine.
Are you still using 300+ widgets on home? :p
A little shaky while surfing widgets horizontally, the more description is compare it to Netflix native app,
surfing horizontally is smoother in library movies not in Home and Hub
Oh. You’re talking about the frame animation I believe.
You need the enable fixed frame option for smooth scrolling but it's kind of broken! We need to solve the fixed frame issue not registering multiple layouts. But if you only have one layout for your homescreen, you can use it and get smooth scrolling.
Definitely something I’d like to see fixed!
(2020-10-31, 23:42)HugoL Wrote: [ -> ]
Okay look am I just crazy or am I seeing things?! I swear to you when I installed either the Bingie skin or the mod there was an addon that came with it. And I did not have anything installed prior, especially since I did a fresh install when I installed the Bingie skin. I'm so confused help me out here......
So please just tell me how to set up my library so I can get some widgets on the homepage, because I still can't figure out how this skin works. Thank you
(2020-10-31, 23:19)Klojum Wrote: [ -> ]
Can you please just tell me where to go or how I can find out then which builds or addons are banned so I know what not to say next time. Thank you
(2020-11-01, 03:39)HugoL Wrote: [ -> ]Update is live.
1.08 Changelog
Spotlight
Menu
Details Row
OSD
Other changes
Great work big jump for this mod
really i like it
Keep up
1.08 Changelog
Spotlight
Menu
Details Row
OSD
Other changes
Excellent job on all of your work @HugoL
(2020-11-01, 07:29)AchillesPunks Wrote: [ -> ]
1.08 Changelog
Spotlight
Menu
Details Row
OSD
Other changes
Our work, considering a lot of the work is yours!
